E46 Xi Forum
Old 10-23-2012, 08:20 PM   #1
bikesandcars
My Ride: 2002 325xi-sport pkg
how do i know if my 325xi has sport package?
I just noticed my new 2002 325xi has a broken rear spring. I'd like to get a stock replacement, but I'm not sure if I have the regular or sport package. How do you know?
Nothing in the owners manual / paperwork tells me from what I noticed.
I have the higher option power seats and 17" "spoke" type alloy wheels if that helps
bikesandcars is offline   Reply With Quote
Old 10-23-2012, 08:30 PM   #2
Snapasaurus
My Ride: 2005 325i SULEV
If I'm not mistaken, if you have a 3 spoke steering wheel, then you have the sports package. If you have a 4 spoke, then you don't.
Snapasaurus is offline   Reply With Quote
Old 10-23-2012, 08:32 PM   #3
bikesandcars
Oh, well all signs point to sport package then. Thanks!
I saw conflicting information about there being a sport package suspension, one post said there was no sport suspension in xi's. ebay and another place said there was a sport spring set on xi's.
This probably sounds dumb to you guru's... I just don't want to order the wrong part
Thanks for any help
Old 10-23-2012, 08:34 PM   #4
Foxtrot_Uniform
My Ride: 325Xi
Do youself a favor and order the Eiback springs... And get some Koni shocks while you are at it.
I was doing my brake pads, rotors and brake lines and noticed the same thing... Broken rear (passenger side) spring.
Just gotta rebuild them all the way around.
Foxtrot_Uniform is offline   Reply With Quote
Old 10-23-2012, 08:39 PM   #5
bikesandcars
As luck would have it my struts are shot, so in my garage I have new strut mounts plus new bilsteen's ready to put on... Unfortunately no springs though.
I don't want to lower the car or change it's comfort at all (high mileage dd), so unless someone makes a more comfortable stock height aftermarket spring I think I'm leaning towards stock. Thanks for the advice though.
Old 10-23-2012, 08:50 PM   #6
SamDoe1
My Ride: 4cyl of fury
Thanks for any help
Suspension on all Xi models is exactly the same with or without the sport package.
Old 10-23-2012, 08:55 PM   #7
bikesandcars
Thanks Sam, Any recommendations for the "Heavy Duty" versus "Regular" ?
Pelican for example sells both, and they say both fit all models (325i, xi, etc)
http://www.pelicanparts.com/bmw/cata...pg6.htm#item30
I'll do some forum searching too
Old 10-24-2012, 07:13 AM   #8
bikesandcars
Ordered 2 new Suplex "heavy duty" stock type rear springs 06164-M636. I'll let you know how they work out.
I'd actually like an aftermarket "rally" kit for my tractor as ground clearance is a bonus and the BMW handles great as it is, but I couldn't find one. I didn't want a 1" drop and couldn't find a 1/2" drop or less from a reputable mnfr.
Old 10-24-2012, 09:15 AM   #9
SamDoe1
One is for use with lowering springs, the other is for stock ride height. I don't remember which is which but I'm sure you can figure it out with a little searching. Also, it's not "Regular". They are called "Sport".
Old 10-24-2012, 10:37 AM   #10
bikesandcars
Sorry if I was confusing (bilstien with springs)
I ordered regular Bilstien's for struts a couple weeks back (in anticipation)
I just placed an order for 2 stock rear springs made by Suplex, there are 2 options for spring (regular and heavy duty), I purchased heavy duty
Old 10-24-2012, 12:22 PM   #11
bikesandcars
Ok, just got a call from Pelican, evidently the springs advertised as fitting several models including 325xi / 330xi aren't really a fit for the xi's, rep told me they are "too short"
So I guess the XI has a taller than non-xi spring package? Makes sense looking at it.
Anyone have suggestions for stock (or near stock) springs? Factory springs are $175 each... not going there.
I looked online and saw the eibach kit for the xi is different than for the non-xi. maybe due to the ride height or front springs.. that seems to be the recommended setup.
Also saw Hotchkis springs that supposedly had less of a drop for sale through summit racing, but no reviews and not on the mnfr website so I'm unsure on them
Old 10-24-2012, 03:47 PM   #12
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Heavy Duty Bilstiens are the stock length where as the Sport Bilstiens are for lowering springs.
tomoyer is offline   Reply With Quote
Old 10-24-2012, 03:56 PM   #13
SamDoe1
Get the Eibachs.
Old 01-22-2013, 01:45 PM   #14
EDWAGON
My Ride: 2004 325xiT
What did you end up doing for springs?
EDWAGON is offline   Reply With Quote
Old 01-22-2013, 02:29 PM   #15
SamDoe1
Wish I would have caught this earlier but Xi springs are actually SHORTER than RWD springs. The increased ride height comes from other sources.
Old 01-22-2013, 04:08 PM   #16
Kubica
My Ride: 2003 325xi
Sam, I'm pretty sure rear xi springs are taller than RWD springs.
Old 10-28-2013, 10:08 PM   #17
dragondrpr
My Ride: 03 325xi
how do i know if my 325xi has sport package? Reload this Page Reply to Thread
pull out seats and 3 spoke steering wheel
dragondrpr is offline   Reply With Quote
Old 11-04-2013, 07:54 PM   #18
neutron325
My Ride: 03 325xi
From what I have gathered they are the same height in the rear. The ride hight difference is from an extra 10mm thickness in the rubber perch. (the 10mm at the spring becomes 17mm at the wheel due to the length of the control arm)
03 325xi sport appearance, cold weather, Harman Kardon audio, etc
neutron325 is offline   Reply With Quote
Old 11-06-2013, 07:21 PM   #19
mitchstade
My Ride: 2002 325xi
I have a 2002 325xi with the sport package and it has
-3 spoke steering wheel
-10 way adjustable bucket seats
-pretty sure it also came with style 73 wheels
And the seats are still heated
I thought the Xi models actually had lower suspension then the RWD ones?
mitchstade is offline   Reply With Quote
Old 11-06-2013, 07:38 PM   #20
neutron325
My Ride: 03 325xi
The XI's version of the sport package doesn't get a special suspension. They are all 17mm higher than the standard "i". The quick tell is the steering wheel and the sliding thigh pad on the sport seat.
I was trying to say that the springs are the same height (length) and that the ride height difference (in the rear) is due to the perch being shimmed.
The suspension has a shorter stroke to prevent bottoming out on rough roads and to limit travel on the front CV joints.
