New rollers don't spin freely? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-23-2012, 09:44 PM   #1
PaulSChapman
My Ride: 2002 BMW 330 Ci
I just bought a new BMW deflection roller, and a new belt tensioner for my 2002 330Ci. I noticed that the roller wheels do not spin freely; they are actually pretty tight. Is this normal? The current ones on the car spin like a top, so I assume that they will free up after installation? I am replacing my current ones due to noise from at least one of them currently.
Also, does anyone know the torque specs for attaching these? I can't find any reference in the Bentley manual.
Thanks.
PaulSChapman is offline   Reply With Quote
Old 10-23-2012, 09:51 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Yes. If they were loose, that would be a worry.
Old 10-23-2012, 09:55 PM   #3
Stinger9
My Ride: '04 330Ci
+1 for totally normal
Your current ones are shot; replace all at the same time.
High wear part as they spin at 2X engine speed.
Old 10-24-2012, 02:16 AM   #4
e4603
My Ride: #3 bus
A couple of hours ago I installed 2 new INA mechanical tensioners at 20 lb-ft and the idle pulley at 35 lb-ft.
e4603 is offline   Reply With Quote
Old 10-26-2012, 10:44 AM   #5
PaulSChapman
Thanks guys - appreciate the help!
Old 10-26-2012, 10:48 AM   #6
jdstrickland
My Ride: '94 325iC & '00 323i
Thanks.
They do not spin freely, that's a sign of a new roller. Old rollers spin freely when they are old and need to be replaced. New rollers (pulleys) are tight and smooth and do not spin at all.
Old 10-26-2012, 10:53 AM   #7
///MPR77
My Ride: 2002 M3 Three Pedals
I believe that the torque value for the mechanical tensioner bolts are 16ft/lbs.
You probably have a hydraulic one...not sure if different spec.
DIY | Bleed Cooling System
belts, tensioner/pulley
