Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 09-08-2012, 07:27 AM   #21
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
Send a message via Skype™ to Jonas@JAWS
Originally Posted by Cipri View Post
Tell us more about the piston/rod combo you will have.
"Togheter with DP in europe JAWS has produced the best Piston and Rod combo avaible today for the S54.
Billet Turbo Drag Boxed Pistons machined to perfection, weight matched with Swedish quality Uddeholm orvar supreme H13 tool steel pins.
Forged Cross H Beam Reinforced Drag Rods with Swedish quality Uddeholm orvar supreme H13 tool steel bolts equal to 245Ksi like ARP L19īs.
All products are manufactored in small batches to ensure highest accuracy.
Our pistons is +0.5 mm over std bore and a special gasket for this bore just like OEM are used and comes with the kit, full instructions comes along. (other bores and/or specifications can be done)
This is a kit we sell upon request and will be using on our customers E46 M3 turbo/supercharger trackday carīs.
Price for the combo with headgasket are:
$3900
Only 10-14 days delivery time!!.
We recomend the use of L19 ARP head bolts for this combo."
Jonas@JAWS is offline   Reply With Quote
Old 09-23-2012, 01:11 AM   #22
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
Exclamation
So all parts have arrived, once we had it the engine was done in 3 days!!
DP billet pistons - Turbo drag boxed/bridged design
DP drag rods w/high tq bolts similar to L19 - Cross H-beam Reinforced Drag
Weight matched and meassured into block and induvidual honing for exact spec.
Engine block is bored/honed and resurfaced to perfection.
NEW OEM gaskets is used everywhere incl OEM steel head gasket..
Coated main and rod bearings from VAC Motorsport.
Main ARP bolts and L19 headbolts from Horsepowerfreaks
OEM flywheel with SACHS heavy duty clutch kit.
Engine is assambled and finished within 72hrs!
The NEW Novi 1500SL supercharger is also in place, capable of 825hp
Engine is taken place in car as i write and dyno session is booked, more info will come! -Update - Its started and runs perfect
Only thing missing now is the Snow Performance Stage 2 Meth kit!
Name:	Stg3 parts.jpg
ID:	470503   Click image for larger version
Name:	Stg 3 parttts.jpg
ID:	470504   Click image for larger version
ID:	470505   Click image for larger version
Old 09-25-2012, 05:34 PM   #23
BDUB328I
My Ride: bmw 328i sedan (E46)
i saw you have a 5 bar FPR along with upgraded fuel pump.....
it was my understanding that the stock m3 fuel pump was good for 5 bar... why the upgrade? just in case?
CHECK OUT MY M3 SEDAN SWAP!!
http://forum.e46fanatics.com/showthr...978&highlight=
AND MY 328I PARTS FOR SALE
http://forum.e46fanatics.com/showthr...057&highlight=
SPONSORS: |Good 'N Plenty Restaurant, 150 Eastbrook Road Smoketown, PA| |http://www.thebmwpartstore.com/ | | http://www.advancedclutch.com/ |
BDUB328I is offline   Reply With Quote
Old 09-26-2012, 12:01 AM   #24
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
Hi!
You need to add boost into the calculations, if we have 0,8bar of boost its 5bar+0,8bar, almost 6bar tot.
Pressure and flow is 2 diffrent things as well, and the stock fuel pump doesnt like to support fuel for 600+ crank horsepower.
Regards
Old 09-26-2012, 12:15 AM   #25
Tchleung
My Ride: 02 M3
Regards
I agree with you on the stock fuel pump! What do you think about the factory sized feed lines? Do you think they are adequate?
02 Carbon Black M3 6MT
456whp/312wtq @ 8psi, No #'s yet at 9.5psi
4.10 / Headers / ESS VT2-550+ / Tuned by Evolve
Tchleung is online now   Reply With Quote
Old 09-26-2012, 12:22 AM   #26
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
For our stage 1 & 2 they are doing the job, im pretty sure we will see a diffrent story when maxing out our Stage 3 capable of ++600whp.
We could or should have changed lines allready but we wanted the stage 3 uprunning fast before the end of this season, so its still in the testing phase for us.
Old 09-27-2012, 01:48 AM   #27
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
New intercooler is coming on the car, this has also 3" piping and a 4" thick core, will support a 1000hp.
Tonight we will add a second Bosch Motorsport fuelpump and wire up the Snow Performance meth kit.
Old 09-27-2012, 12:03 PM   #28
Bdave
My Ride: M3 HPF Stage 3
Your support plate and Novi supercharger both look MASSIVE. I am really impressed what you are doing with super charging the BMW M3.
I have never been a fan of supercharging our cars until I see what you guys are doing. I see so many plates FLEX on USA builds. If you tug on the compressor and it moves even a small amount, then the belt will not wear correctly and is more prone to slipping. It looks like your units dont move a fraction of a millimeter. How thick ARE your plates?
You Swedes do NOT mess around. LOL. I really like all the strength you put into these builds, especially your Stage 3. I cant wait to see what it will do.
best of luck. We are all enjoying your photos and updates.
Bdave is offline   Reply With Quote
Old 09-28-2012, 01:06 AM   #29
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
Yesterday it was a battlefield in the shop 4 guys working in the car so we can be done for the race tomorrow 550km away down south!
Today we have a oilchange and some minor issues to fix
ID:	471407   Click image for larger version
Old 09-28-2012, 01:26 AM   #30
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
Thank you for the kind words!
Bracket? Hm..abt 0,8-0,9 inch thick.
Old 10-09-2012, 01:45 PM   #31
7to3_enthusiast
My Ride: '04 LSB 6spd M3
Any updates?
04 LSB M3
6sp, BSW stage 1, 19" Forgestar, PSS's, MXP exhaust, K&n intake, h&r springs, koni shocks.
87 rx7 tII 6266 BB .84 a/r in the works
00 Saturn sc2, DD, 36+ mpg
7to3_enthusiast is offline   Reply With Quote
Old 10-24-2012, 12:16 AM   #32
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
Originally Posted by 7to3_enthusiast View Post
Any updates?
Sorry for late reply!!
100-200km/h 6,6sec and 60-130mph on 7,7 on pumpgas NO methanol yet!
Will dyno car with and without meth injection in a few days!
Old 10-24-2012, 02:09 AM   #33
MarcusLSB
My Ride: BMW's
Well done!
youtube.com/marcuslsb -- Photography by Gheybe!
Old 10-24-2012, 11:25 PM   #34
Sweed
My Ride: 07 6.0L / 04 M3
What kind of costs are we looking at for shipping these pistons and rods all balanced and ready to go to Canada, looking to build my S54 in the next couple months.
AA HKS Stg 2 / Nitrous Express
Sweed is offline   Reply With Quote
Old 10-24-2012, 11:55 PM   #35
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
Approx $2700
Old 10-25-2012, 12:11 PM   #36
Sweed
Approx $2700
Nice, can these pistons also be teflon coated for use with nitrous, I guess the ring lands are the weak link when spraying with the stock piston.
The coating would be done via 3rd party.
Old 10-25-2012, 04:04 PM   #37
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
I would say the skirts are the weak link due to the force when boosting stock engine.
Coating can be done, DP are looking into the best option but still not offered in house.
Old 10-25-2012, 04:17 PM   #38
Sweed
Thanks for the fast response, making my christmas list early this yr. I will send you a pm on this from here on out.
Old 10-25-2012, 04:19 PM   #39
Jonas@JAWS
Past Sponsor
My Ride: Bmw M3 E46
Hehe , you are welcome!
Old 12-07-2012, 11:14 AM   #40
M369
My Ride: M3 E46 SUPERCHARGED
no news ?
M369 is offline   Reply With Quote
