#41 | |
Care to comment on this, since I mentioned that I think your advice is bad?
#42 | |
#43 | |
Platinum Plus Quality
I recommend bleeding the cooling system with the car off and cold. Whether you listen to Metallica or Snoop Dogg while doing it is your choice!
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#44 | |
#45 |
BMW TIS:
Important! The vehicle may only be raised at the four reinforced supports!
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs Last edited by Mango; 10-25-2012 at 11:54 AM. |
#46 |
#47 | |
![]() Practice > theory. Your method of doing one side at a time is dangerous at best. By the way, have you ever seen the material under the jacking pads? Surely you've replaced them as part of your PM regimen. It's pretty thin, in fact, thinner than the material on the "rails" I bet.
#48 |
I figure the next time I need to jack my car up I'll just use the center jack point in the frong. Crushing a little, from what everyone's said, doesn't do anything terrible. Last time I lifted it using a jack and put a stand under the control arm incase of jack failure, but next job is suspension so that won't really work.
#49 | |
BTW: As I said, four jacking points, front subframe jacking point (if applicable--M3 or earlier non-M E46s), or rear subframe jacking point.
#50 | |
My advice is: don't.
#51 | |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
The green location is welded to the Front Engine Support (which is also a major impact absorber), as evidenced both here:
![]() and here: http://tis.spaghetticoder.org/s/view.pl?1/04/55/01 Quote:
![]() Front Engine Support is an extremely rigid structural component of the car, and is one of the reasons why our cars are so safe. The green location is essentially where that weld begins, which is why it feels so solid and rigid. It is also part of the mount for the shock absorber: ![]() Those engine supports are not just for the floor pan, and probably do little to support the floor pan overall. Those two rails that are in the center, however, do seem to directly support the floor pan and are connected right to it. That is not a place to lift from. You will bend the floor pan guaranteed if you lift from those center points. If you lift by the green location, or as close to it as possible, you will be just fine. After doing my own research and calling a few shops, that is what I have concluded. If anyone has a solid rebuttal as to why the front section of Rear Engine Support would be a bad location to lift from, your comments are welcome and appreciated.
E46Fanatic's resident mathemagician
![]() Last edited by Zell; 10-25-2012 at 01:20 PM. |
#52 |
You can't justify lifting the vehicle from a certain point simply because it's welded to another point.
You guys are overthinking this. Lift the vehicle safely only from reinforced or solid points designed for the task. Don't create your own jacking points just cause "I've been doing it for years," or, "it seems fine." Four jack pads, rear subframe, or front subframe central point, if applicable. Period.
#53 | |
The rest of this does not exactly apply to the E46: As another rebuttal to that, yes you can lift a vehicle from a certain point just because it is welded to another point. Pinch welds, for example, are good jack stand locations and jacking points (with the right adapter). I am sure car manufacturers do not advise lifting from the front or rear tow hook, yet it is common practice in nearly every shop to jack from that point if they do not have a lift. They then usually put the jack stands under the pinch welds. I've been doing a lot of reading into this the past few days just to make sure.
![]() Last edited by Zell; 10-25-2012 at 01:26 PM. |
#54 | |
#55 |
This argument seems pointless. Both ways work, although my opinion is that yours is dangerous and your opinion is that my floor pan is totally crushed. Try, really hard, to remove your ego from the discussion. There is no "period." There is no "barnyard behavior." Both ways work. Mine is safer. If you can't prove me wrong without insults, I think people will form their own conclusions.
An e30, but note how the "frame rails" are similar, and capable of supporting the vehicle. This is widely documented. ![]() Done arguing, so ciao.
#56 | |
#57 |
Fully Deeked Out
Real men lift the car up by hand and place jackstands under the appropriate points. I'm not going to tell you what I use for an impact hammer.
#58 |
#59 |
Fully Deeked Out
Oh no, brother. I mean lift it with your hands. Literally. Or dig a pit with your bare hands. That'll work, too.
#60 | |
I'm with choxor, although I usually just hold it up for whatever work I doing. Real men don't need jack stands. I'll set it on my knee if its going to be a lengthy job
-Mike
** Removed ** Ask an Insurance Adjuster Anything Cup of Joe for a Joe! http://www.greenbeanscoffee.com/coj/ buy my O.Z. Ultraleggeras! |
