Old 10-22-2012, 08:28 PM   #1
GMELT1
My Ride: 2003 BMW 325I
Poor lighting
Can or has anyone on here changed there projector xenon lights out and went with halogen instead. Im looking at removing the whole assembly and going with a halogen assembly and was wonding if any wiring has to be changed. This is on a 2003 325i
thanks for any info.
GMELT1 is offline   Reply With Quote
Old 10-22-2012, 11:44 PM   #2
Dean | KHOALTY, Inc
Past Site Sponsor
My Ride: BMWs
I would start changing your bulbs out? Checking for burned projector bowls? There's no way you would get a benefit going from OE Xenon to aftermarket halogen.
Dean | KHOALTY, Inc is offline   Reply With Quote
Old 10-23-2012, 05:07 PM   #3
Beamer Creamer
My Ride: 2005 bmw m3
Agreed. No halo will be as good. Especially oem
Beamer Creamer is offline   Reply With Quote
Old 10-24-2012, 09:53 AM   #4
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Bad move. Can you take a pic of your lighting at night?
What color are the bulbs emitting? Are they leveled properly? Do you have AL or ZKW lights?
Old 10-24-2012, 09:01 PM   #5
GMELT1
the lights are factory 4300k phillips d2s 35w. i just changed them to a aftermarket 6000k d2s 35w bulb but could not tell any difference so i put the original bulbs back in. the lighting is very dim on the car,is there any way to check the ballast?
Old 10-25-2012, 02:12 PM   #6
Wh33lhop
My Ride: douchemobile
You have the ZKW headlights and your reflector bowls are burnt out, so they are not reflecting light forward through the lens and you are getting very poor output. It has nothing to do with your ballasts or bulbs.
If you don't mind getting your hands dirty you can retrofit some AL projectors in there and it will be much, much better. It requires a pair of AL projectors (~$100/pr on ebay), a pair of bixenon solenoid control circuits ($16/pr from here), disassembly, cutting up and drilling of your housings. Here is a how-to: http://www.zhpmafia.com/forums/showt...r-Retrofit-DIY
Wh33lhop is offline   Reply With Quote
