Old 10-25-2012, 08:02 PM   #1
louiecat
My Ride: 2000 Bmw 323ci
Fuel Pump question 00 323ci
Hello, I am trying to get my car started I beleive it's the fuel pump I removed rear seat and it seems to have 2 pumps,Can someone let me know what is up are these both pumps? Thanks.
louiecat is offline   Reply With Quote
Old 10-25-2012, 08:04 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Passenger side. The driver's side is just a passive jet sucking pump.
Old 10-25-2012, 08:09 PM   #3
louiecat
what does the passive jet sucking pump do?
Old 10-25-2012, 08:14 PM   #4
Stinger9
My Ride: '04 330Ci
On the passenger side is a fuel pump combined with a fuel level sensor.
On the driver's side in the US there is only a fuel level sender unit.
Connecting the two sides of the twin saddlebag tank lobes is a sucking jet pump. This keeps the fuel level high in the pump side to insure you have gas available to pump to the engine.
You'll most likely want to replace the right side pump only and also do the fuel filter which is located under the car, approx in the driver's seat area.
Do you know enough to know what you are doing?
Old 10-25-2012, 08:29 PM   #5
louiecat
well I am learning. I bought this car a few months ago with a cracked head and since have helped put another motor in car, I am having problem getting car to start, I tried carb cleaner in the hose and car started but would not rev. I dont know much about imports or newer cars But I really appreciate your Help ThankYou!
Old 10-25-2012, 08:33 PM   #6
99_323i_Steve
My Ride: 1999 BMW 323i
Just out of curiosity how much did u pay for the car with the cracked head?
Sent from my SPH-M820-BST using Bimmer App
I've learned some people think their a mechanic when they can do their own oil change. Don't always believe what you read.
99 323i. Factory:Harmon Kardon Hi-Fi, Winter Package w/ heated sport seats, and Sport package with Sport steering wheel and Sport suspension.
Aftermarket: 16" rims, LED Angel Eyes, LED license plate lights, LED tails, LED depos, Black kidney grill, and DICE Aux jack input, 20% tint.
99_323i_Steve is offline   Reply With Quote
Old 10-25-2012, 08:35 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the 2nd link below in my signature.
Old 10-25-2012, 08:36 PM   #8
Stinger9
My Ride: '04 330Ci
louiecat
Sounds like you're on your way with some major projects!
Best of luck to you and keep us informed.
We're a better resource than you may think. Next time tell us all the facts and see if we can't help you in the diagnosis rather than saying what you intend to do to solve whatever problem.
What do you know and what do you not know about your current problem?
Old 10-25-2012, 08:37 PM   #9
louiecat
1,350
Old 10-25-2012, 08:44 PM   #10
louiecat
Originally Posted by Stinger9 View Post
louiecat
I just joined this Form a few mins ago and it is awesome! I hope I can get this car running it is starting to worry me, Could you tell me where the fuel pump fuse is? I've been told it may be in glove box area or under Hood on Drivers side near the firewall.
Old 10-25-2012, 08:49 PM   #11
99_323i_Steve
fuel pump fuse is in glove box, you can interchange it with your horn relay, test...if no horn, clearly that relay is the issue.
Old 10-25-2012, 09:13 PM   #12
Stinger9
My Ride: '04 330Ci
Open glove box and drop the fuse lid with two thumb screws.
Should be this fuse chart in there to guide you.
