FSU or Other Problem? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-25-2012, 08:42 PM   #1
OHP
My Ride: 2003 325i
I regret that my first post is concerning a problem with our 325i that we have had for less than a week. The A/C blower quit tonight while the control panel shows that the fan speed should be changing. I've read through several threads, all of which point to a bad FSU. Before I order a $60 part I wanted to ask if there are any other likely candidates that would cause this? I tried the fuse reset with no success. The car is an 03 but only has 88,000 miles. The blower was not making any chirping noises before it quit. Thanks for any help and the wealth of info on this forum.
OHP is offline   Reply With Quote
Old 10-25-2012, 09:02 PM   #2
///MPR77
My Ride: 02 ///M3 Tri-Pedal
Try getting into the panel where you will soon be replacing the FSU.
Wiggle the connection to the FSU while fan is on, and see if it comes back on. I'm not suggesting this as a fix, but a method of troubleshooting.
Achtung...the FSU gets really hot, so be careful, or be aware.
GL.
Old 10-25-2012, 09:16 PM   #3
OHP
My Ride: 2003 325i
Thanks for the input. I actually read a thread that said to unplug it and clean the contacts. I plan to do that tomorrow before ordering the part.
Old 10-25-2012, 09:26 PM   #4
Stinger9
My Ride: '04 330Ci
At this point a used e46 is very likely a neglected BMW.
Please brace yourself to consider $60 one of the cheaper maintenance items you will undertake.
Get yourself an updated FSR and put this problem behind you.
Now focus on your cooling system. What's the story there?
Read up on CAB's yet? Know about CVV oil separator?
Know about the vanos Beisan update?
Old 10-25-2012, 09:33 PM   #5
OHP
My Ride: 2003 325i
I am aware of all of those issues. Cooling parts ordered from pelican, installing next week. CAB's will be done as needed. Driver window reg is in the near future, or the zip tie fix. Vanos is an easy fix, only time consuming.
I bought the car from the original owner, dealer serviced, it's in excellent condition. I know there are maintenance items to address. I thought it was worth asking if it could be anything else before ordering the FSU.
Old 10-25-2012, 09:38 PM   #6
Stinger9
My Ride: '04 330Ci
Sounds like you're on top of it.
CAB's are bad unless PO has already done twice if using oe parts.
Sounds like you might even have the coveted service history with receipts!
Old 10-25-2012, 09:40 PM   #7
cityjohn
My Ride: 2001 M3
Yes, they are different. Don't know why but the new ones have more porcupines than the ones the cars were built with. (These were from an E36 but they're pretty much the same)
cityjohn is offline   Reply With Quote
Old 10-25-2012, 09:48 PM   #8
OHP
My Ride: 2003 325i
In fact I do. Every receipt since new.
Old 10-25-2012, 09:50 PM   #9
Stinger9
My Ride: '04 330Ci
Most fortunate man!
Old 10-26-2012, 01:51 PM   #10
OHP
My Ride: 2003 325i
I did this fix today and thought I would pass some info along to the forum. I needed the FSU ASAP because my wife and kids don't care to ride around with no A/C or heat. (My blower quit completely) I called NAPA to see if they could get the part because ordering online was of course going to take a few days. They indeed were able to get it, quickly. I called at 9am and they had it by 11:30. The part came from a company called Altrom. I asked the Napa guy how they compare to OEM parts. He informed me that Altrom doesn't manufacture anything. Instead they buy overstocked parts from other suppliers and repackage it in there boxes. He said the part I get could be from various different manufacturers. Turns out the one I got is a Behr. I followed one of the DIY's on here and the blower now works perfect.
Thanks for the DIY info.
Old 10-26-2012, 05:50 PM   #11
Stinger9
My Ride: '04 330Ci
Lucked out with Behr. Name brand. Does it look like the updated version pictured above?
Others with lesser brands have repeated the repair within months.
Old 10-26-2012, 08:00 PM   #12
///MPR77
Glad to help.
....And, + friggin 1
