Old 10-26-2012, 04:48 PM   #1
E462005
My Ride: 2005 325
Fuel filler door
I've searched on here about the fuel door actuator. My fuel door doesn't shut when I try to push it to close. I have to hold it in so when I lock my car the pin holds it shut. Now whenever I unlock my car the fuel door just pops open. Any one have any ideas as to what this is? I can post pics if anyone wants to see what Im trying to explain.
E462005 is offline   Reply With Quote
Old 10-27-2012, 04:06 AM   #2
MJLavelle
My Ride: 2001 BMW 330ci
Pics would help, because your explanation is a little confusing.
Old 10-27-2012, 04:46 AM   #3
cityjohn
My Ride: 2001 M3
Classic BMW issue. Caused by the squiggly wire spring next to the hinge. That spring is the only thing that holds the door shut; the actuator just secures it from being pulled by a thief. Over time the spring weakens, at which point you just go the dealer (they're less than a dollar) and you're back in business.
cityjohn is offline   Reply With Quote
Old 10-27-2012, 04:50 AM   #4
GLOK1132
My Ride: 2002 325i
Just a worn out spring, really cheap from dealer and really easy to replace.
GLOK1132 is offline   Reply With Quote
Old 10-27-2012, 04:50 AM   #5
cityjohn
My Ride: 2001 M3
Here's more info including pic and part no.
http://forum.e46fanatics.com/showthread.php?p=14213068
Old 10-28-2012, 03:47 PM   #6
E462005
My Ride: 2005 325
That's how it stays opened.
Old 10-28-2012, 03:47 PM   #7
E462005
My Ride: 2005 325
Also sorry for taking so long to post pics
Old 10-28-2012, 03:49 PM   #8
E462005
My Ride: 2005 325
The locking pin works just fine, whenever I lock the car. But I have to push it and hold it so the pin locks it.
ID:	475823   Click image for larger version
Old 10-28-2012, 03:58 PM   #9
E462005
My Ride: 2005 325
Ok Thks, that helped out. So that is what I have to change then.
Old 11-30-2012, 04:34 PM   #10
E462005
My Ride: 2005 325
Update on my fuel filler door problem I change that little spring on the right side and it's working perfect thanks guys
