Health & Fitness
Discuss any topics related to heath and fitness here. |
#81 | |
I am a creature of habit. I don't just like routines, I require them to function. I have a routine for everything, and I feel a sense of success when I follow the routine to completion, no matter how small. For me to be successful at this, I need to have a routine for everything built up front, that I fully understand the objective etc. I'm a personal trainers wet dream, they build me a program and I follow it religiously lol. So I kind of need help from the "personal trainer" perspective. I need a routine built for me (I like the one I tweaked and posted earlier, open to suggestions) and I have no problem throwing in conditioning... just need to know some examples (or where to look, google is an appropriate response lol) and how to apply those examples to my current routine.
#82 | |
#83 | |
#84 |
My logic behind goals was to increase the bigger lifts by 100lbs, and the smaller lifts (bench/press) by 50 lbs. Sounds like that was a little too crude
![]() Honestly in simple terms, my 1 year goal is to cut down to decently visible abs, add 10 lbs or at least significant muscle mass, and create better symmetry in my physique.
#85 |
My current routine is a mix of a lot of consistency but also let's me do whatever conditioning work I want as long as it fits the requirements.
My workouts to many people will seem very random but when you look at them you'll see whatever my strength lifts are will be complimented by the metcon. Some weeks ill hit things harder but I try to hit everything twice a week if possible. |
#86 |
Alright, I'm confident this will work for me, so feel free to plug in conditioning workouts... it is very much appreciated. I made exact reps to strive for, trying to keep in the 8-10 rep range as I've personally seen my best gains from that volume/weight. Tried for 25-30 total rep volume per set.
Ignore all my calculations its just for myself to make sure im not in gym 3+ hours a day. Monday - Shoulders / Triceps : 24 Sets = 51 Minutes Shoulders : 15 Sets = 37.5 Minutes DB Press - 4x6 : 120 rest Military Press - 4x6 : 120 rest Side Laterals - 3x8 : 120 rest Rear delts cables - 4x6 : 120 rest Triceps : 9 Sets = 13.5 Minutes Skulls - 3x8 : 60 rest Press Downs - 3x8 : 60 rest French Curls - 3x8 : 60 rest Tuesday - Back / Calves : 26 Sets = 60 Minutes Back : 19 Sets = 49 Minutes Deadlifts - 3x8 Reps : 180 rest Pull Ups - 4x7 Reps : 120 rest Bent over rows - 4x8 Reps : 120 rest Wide Lat Pull Downs - 4x6 Reps : 120 rest Seat rows - 4x8 Reps : 120 rest Calves : 7 Sets = 11 Minutes Leg Press Calves - 4x10 : 60 rest Seated 21s - 3x21 : 60 rest Thursday - Chest / Biceps : 25 Sets = 53.5 Minutes Chest : 16 Sets = 40 Minutes Incline DB Press - 4x8 : 120 rest Flat Bench Press - 4x8 : 120 rest Pec Dec - 4x8 : 120 rest Low Cables - 4x8 : 120 rest Biceps : 9 Sets = 13.5 Minutes Preacher Curls - 3x8 : 60 rest Incline DB Curls - 3x8 : 60 rest Concentration curls - 3x8 : 60 rest Friday - Quads / Hamstrings : 28 Sets = One Hour 12 Minutes Quads : 16 Sets = 42.5 Minutes Squats - 5x12,10,6,6,8 : 180 rest Leg Press - 4x10,8,6,10 : 120 rest Lunges - 3x8 : 120 rest Extensions - 4x10,8,6,10 : 120 rest Hamstrings : 12 Sets = 30 Minutes Straight Leg Deads - 4x10,8,6,10 : 120 rest Seated Hams - 4x10,8,6,10 : 120 rest Lying Hams - 4x10,8,6,10 : 120 rest
#87 | |
If conditioning will make me a better hockey player (which I'm sure it will) I'm stoked to add it to my training. Just don't want to spend more than an hour and a half in the gym unless im working out on a weekend day... which is rare for me. But sounds like its just an additional 10-15 minutes a workout.
#88 |
Today I did conditioning only, so it didn't really have a focus on anything in particular and wasn't heavy. That's usually what I do when I'm not doing any lifting.
Here's what I did. This is the kind of thing you could add in when you do your mini cuts. 1000m row Rest 2:00 200 doubleunders Rest 2:00 50 burpees Rest 2:00 50 30lb slamballs Rest 2:00 Run 800m Brutal... Sent from my SCH-I535 using Bimmer App |
#89 | |
AKA....X5_Scribe
My Ride: X5/M3/848/128i
Just a key point... ....make sure that you really focus on the eccentric/concentric portion of all of your lifts/movements (..mind/muscle connection). I would personally extend the reps on movements such as the reverse cable flies, lat pull downs, pec deck/low cables, etc. simply for the aesthetic, muscle building benefits. For movements like those I typically stay in the 10-12 rep range while increasing weight incrementally. Have at it, and let us know how it goes.
#90 | |
AKA....X5_Scribe
Which press are you referring to bro? I can't imagine any of your presses being that low considering that you put up some really big numbers.
#91 | |
What is yours? Put all your numbers into strstd.com and it will show you where each of your lifts are in comparison to averages of people your own size who lift. Sent from my SCH-I535 using Bimmer App |
#92 |
Here's a video:
My press is pretty average with where the rest of my lifts are. |
#93 | |
AKA....X5_Scribe
Good question. I've never performed a standing shoulder press; I usually perform the seated military press. My strict military press max is unknown, but I can toss around 200 lbs. pretty easily (..usually 4 x 10 reps). I'm going to start going up in weight though. I think that I'm going to try a standing shoulder press to see where I'm at. I'm guessing that it's in the 175 range. Per the website you suggested, it stated:
I used the elite figure for the Bench/Squat/Overhead press number because I can already lift the weight estimated in the advanced column. I chose advanced for the deadlift number because I have already exceeded the intermediate number. The estimates were based on being able to bench 335 lbs., squat 350 lbs., deadlift 350 lbs. and shoulder press 200 lbs. I considered using my 460-ish lb. 1RM on the squat from 07', but I haven't squatted more than 375 lb. since I began my program, and I'm unsure if I could do 460 lbs. today.
#94 | ||
Found a goldmine of short metcons (I'll keep up to date with sollys and others etc as well) http://www.board.crossfit.com/showthread.php?t=35062 Quote:
![]() Thanks again for all the help!
#95 |
My standard strength was the following (used last workout reps/weights):
175 lb Male (I found it curious they don't ask height??) Bench: 190 1RM, 6 lbs shy of intermediate level. Squat: 262 1RM, right at beginning of intermediate Deadlift: 345 1RM, 25% of the way to advanced Press: 136 1RM, Just into intermediate I thought I had achieved "intermediate" status, looks like that was a decent assumption. Would be nice to be just before / at advanced level in a years time. Edit: More realistic goals to get close to advanced status for each (I'll revisit this in a years time and see where im at) Current: 5 reps of 160 lbs Bench 5 reps of 225 lbs Squat 5 reps of 280 lbs Deadlift 5 reps of 115 lbs Press Goals: 5 reps of 225 lbs Bench (+65 lbs) 5 reps of 305 lbs Squat (+80 lbs) 5 reps of 350 lbs Deadlift (+70 lbs) 5 reps of 135 lbs Press (+20 lbs)
![]() Last edited by dabears; 10-31-2012 at 11:22 AM. |
#96 | |
#97 |
good progress man. i wish i had some old pics to show cause i too was skinny fat
>>*David*<< R.I.P ![]() ![]() |
#98 | |
I've reached 10 weeks of training hard / eating big. I am at 176.1 lbs, and scale reads 17.1%. Having had a caliper test in the past, I believe I have just started to go over 15% bf, which means its time to try my "mini-cut" experiment. For the next two weeks (or more if required) I am going to weight lift intensely 3 times a week, and do conditioning workouts two times a week. I am going to give intermittent fasting a shot, as I've researched a lot on it and its very fascinating stuff. Heres my macros/calories for next two weeks if anyones interested: ![]() I'm taking before and after pictures and putting them side by side, I'll post them to see if two weeks can make any visual difference in BF % (because I feel a visual difference in the past 10 weeks of bulking). Looking to lose 2-3 lbs, and get down to just above 174 lbs again. Based on the calc, it will take minimum 4 weeks... but I think (knowing my body) I can shred it off quicker.
![]() Last edited by dabears; 11-06-2012 at 04:54 PM. |
#99 | |
Black and Proud
this thread needs more pictures
![]() Quote:
buy my sedan rear seats (gray leather) sell me sedan pillars!! (black fabric) |
#100 |
AKA....X5_Scribe
