Old 10-31-2012, 07:57 PM   #1
GaM3cocks
My Ride: Nothing for now
Would you buy a 04 330 that is S/C with 100k???
Well just like the title stats...would you??
I have the opportunity to buy an 04 330 with an active autowerkes stage 1. Also has M3 exhaust and headers...the buy part is it has 100,000 miles.
The previous owner bought it from the original owner already s/c'd so I am unaware of when it was installed....
I'm going to get a compression test, anything else I should be concerned about?!? Thanks guys...new to E46's but not BMWs I've had a few MInis!!!
GaM3cocks is offline   Reply With Quote
Old 10-31-2012, 08:01 PM   #2
j_block
My Ride: 2003 325i
How much is the car?
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 10-31-2012, 08:03 PM   #3
WALKD U
My Ride: Just Fast!
Make sure its not lean up top (RPM range)...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 10-31-2012, 08:15 PM   #4
GaM3cocks
9k....has M3 front and rear bumpers and csl trunk...
How to I check if its too lean?
Old 10-31-2012, 08:34 PM   #5
323tom
My Ride: 2 turbo e46's
does it have boost/AFR guages? most important is AFR but boost is useful as well, if it has a AFR guage you can easily tell if the tune is good or not, your AFRs should be around 12ish under WOT with a supercharged car and 14ish when cruising
323tom is offline   Reply With Quote
Old 10-31-2012, 08:35 PM   #6
fraser19
My Ride: 2004 330CI M sport.
For 9K it seems good.
However that can also be the too good to be true kinda deal.
fraser19 is offline   Reply With Quote
Old 10-31-2012, 08:37 PM   #7
GaM3cocks
Yes it has both gauges...I'm taking it for another drive soon. Anything else guys?!
Old 10-31-2012, 09:39 PM   #8
GaM3cocks
Oh my lord!!!! i found the EXACT car on this very site!!!! i knew i would, just a little research!!!! This is the car, i guess with only 4,000 more miles. So i guess after finding this, the guy I'm buying it from is the 3rd owner....hopefully ill be the 4th hahaha. let me know what y'all think!?!?!?!
http://forum.e46fanatics.com/showthr...480&highlight=
Old 10-31-2012, 09:48 PM   #9
ANREC330
My Ride: C6 Vette & M3
That car is amazing. I would get it if I didn't just by a car!
ANREC330 is offline   Reply With Quote
Old 10-31-2012, 09:51 PM   #10
GaM3cocks
haha don't even think about it!! this isn't the FS thread. Im buying it from a Guy who bought it from this guy haha...he only had it for 6 months or so....Do y'all think i should buy it for $9000
Old 11-01-2012, 05:26 AM   #11
GaM3cocks
Ttt
Old 11-01-2012, 09:56 AM   #12
WALKD U
My Ride: Just Fast!
Get it all check out. Most cars run lean up to with the ms54 DME...
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 11-01-2012, 12:13 PM   #13
douglas_ngo
Europrojektz Southeast
My Ride: Hamann Widebody
Are you buying it from blown330ci? I have seen this car in person. He bought it from Savannah Toyota dealership.
douglas_ngo is offline   Reply With Quote
Old 11-01-2012, 12:28 PM   #14
GaM3cocks
Nope I'm buying it from a guy who bought it from blown330....I PM'd blown to ask him all the mods since the guy I'm buying it from Isn't sure...I will 100% get it looked at.
Old 11-01-2012, 12:29 PM   #15
GaM3cocks
What were you thoughts on it Douglas?
Old 11-01-2012, 12:58 PM   #16
Bdave
My Ride: M3 HPF Stage 3
Do a compression and a LEAK down test at your expense. Find out how much oil it burns per 1000 miles. That is very important.
Bdave is offline   Reply With Quote
Old 11-01-2012, 03:38 PM   #17
douglas_ngo
I saw the car when blown330ci has it. Met him a few times at car meets (great guy). Car run great but I know that he has a check engine light on it due to the O2 sensors. Not sure if that was fix or not. After he bought it from the dealership, he added the CF hood, CSL bumper and BBS LM rep. I haven't seen it in a while (over a yr) so I can't comment on it. Go with what the other guys suggested to check.
BTW, you probably won't get a response back from blown330ci.
Old 11-01-2012, 03:53 PM   #18
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
also check subframe for cracks.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 11-01-2012, 04:04 PM   #19
Minnoe07
My Ride: 2004 BMW 330Ci
9k seems too good to be true. Be wary. Cars without superchargers cost more for the same amount of miles.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 11-01-2012, 04:15 PM   #20
GaM3cocks
Ok thanks guys for the great advice...I'm getting the subframe checked as well after doing a few hrs of research the past few days. Ill let you know all my test updates!!! Wish me luck
