Sponsored by BimmerWorld
Old 10-31-2012, 06:28 AM   #1
mario-g
My Ride: 323ci
Suspension Question
When putting in Super Low King Springs do I really need to change shocks?
Anyone had the Super Low setup on their e46 for a while?
Whats the ride like etc?
mario-g is offline   Reply With Quote
Old 10-31-2012, 06:48 AM   #2
pawelgawel
My Ride: 330CI
anytime you put on lower springs you should use proper shocks to get the proper handling. If you use your oem shock, it will prematurely fail very quickly.
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 10-31-2012, 09:10 PM   #3
mario-g
My Ride: 323ci
thanks for the response
any tried and tested shocks that people recommend?
Old 10-31-2012, 09:23 PM   #4
Snik
Snik's Avatar
My Ride: IR M3 Vert.
They say typically, any drop ideally should have matched dampers, but it is commonly accepted that anything up tp 1.4" you can run stock dampers and still ride ok... but youre still shortening, the stock dampers lives by doing so...
Then the norm is, anything over 1.5" drop you want matched dampers, that are preferably shorter also... Do people always do that? absolutely not, but usuall when u get aggressive springs you accpet that the ride wont be the best and youre gonna swap for better matched dampers ASAP.
Do you ride a sportbike?
Old 10-31-2012, 11:38 PM   #5
mario-g
My Ride: 323ci
yeah ive heard stories of shocks giving way a month or so after a drop
any brands you recommend?
Old 11-01-2012, 05:28 AM   #6
Snik
Snik's Avatar
I've had Bilstein sports before. Now running Koni yellows.
Love em.
