E46 Xi Forum
Old 10-25-2012, 05:16 AM   #1
dmhonda
My Ride: 03 325xi/03 636ninja
weird noises
so out of nowhere my car starts making a chirping noise like a cricket is under my hood. when I first start the car it is consistent but once you start driving it goes away and will come back every once in awhile.any suggestions
Sent from my ADR6400L using Bimmer App
dmhonda is offline   Reply With Quote
Old 10-25-2012, 05:47 AM   #2
lucky_doggg7
My Ride: 2005 M3
Shooting from the hip, my guess is a worn out bearing on a tensioner pulley or idler pulley.
Old 10-25-2012, 05:54 AM   #3
325xittt
My Ride: 2003, 325 XIT
Could be a loose belt, or a bearing going. Try to isolate where the sound is coming from. Use a 3ft section of tubing like a stethoscope. Hold one end to your ear and carefully probe the running engine with the other end. Be mindful of moving parts and electric fans that may start suddenly.
325xittt is offline   Reply With Quote
Old 10-25-2012, 06:25 AM   #4
Foxtrot_Uniform
My Ride: 325Xi
THIS... With maybe a bad belt thrown in...
Foxtrot_Uniform is offline   Reply With Quote
Old 10-25-2012, 06:29 AM   #5
lucky_doggg7
My Ride: 2005 M3
Hey Rick, we might be completely off base... What if the OP had an infestation of crickets under the hood of his Bimmer?
Old 10-25-2012, 09:02 AM   #6
Kubica
My Ride: 2003 325xi
So it was easier to join the forum and start a thread, than to open the hood and have a quick look to see if you can pinpoint where the noise is coming from?
Old 10-25-2012, 11:27 AM   #7
Rickna
My Ride: '01 330xi - '09 IS-F
Ok, this is very strange-I had a similar noise (like very loud crickets), you could hear it out of either side when the windows were down. Driving me crazy! It mostly happened at hiway speeds, but not while accelerating. Shifting into N didn't make any difference, nor did turning the steering wheel. Turns out I had a broken stud on one of the downpipes to the catback. I had to drill out the remainder and use a bolt & nut. Problem solved.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 10-25-2012, 04:26 PM   #8
murac14
My Ride: 2001 325i
Had same thing you need to change the whole tensioner I'm 99% sure that is it take a hose or pipe and put it on your ear and pinpoint it
Sent from my PC36100 using Bimmer App
murac14 is offline   Reply With Quote
Old 10-25-2012, 09:39 PM   #9
dmhonda
The sound is coming from the back of the intake. The car has 130k miles is there anything else I should look in to fixing?
Old 10-26-2012, 04:47 AM   #10
Rickna
Cracked intake boots, vaccum lines.
2001 BMW 330xi
2009 Lexus IS-F
Old 10-30-2012, 05:55 AM   #11
dmhonda
So I figured out what the noise was.. and no it wasn't a cricket infestation...lol that's a good one tho. It's called a disa adjustment unit its on the intake manifold and its right above the throttle body. Thx for all the advice
Old 10-31-2012, 05:40 AM   #12
DINxiAN
My Ride: Is black
I put on a brand new Maserati belt on like two weeks ago...every time the car sits and cools below freezing...it squeaks for a few mins on startup. Cold belt ~ stiff rubber... = squeaks
DINxiAN is offline   Reply With Quote
Old 10-31-2012, 06:36 AM   #13
Rickna
I rebuilt my DISA with a kit from German Auto Solutions. Better components than OEM. It will outlast a brand new unit. Easy to do.
Sent from my PH44100 using Bimmer App
2001 BMW 330xi
2009 Lexus IS-F
Old 10-31-2012, 10:04 AM   #14
Dahmwern
My Ride: 2005 BMW 325xi 5spd.
Send a message via AIM to Dahmwern
I had this chirping noise when I bought the car. It came on with the AC. I noticed this mostly started happening in the cold.
I think replacing the pulley and belt solved the issue IIRC.
| CSL 18" Reps | H&R Coilovers | UUC EVO3 Short Shifter | Conforti Shark Injector | Magnaflow exhaust | TMS Power Pulleys | CAI w/ Custom Built Box | Drilled\Slotted Rotors | ZHP Shift Knob | Brushed Metal Trim | ECS Carbon Fiber Brake Handle | Black Grilles | Angel Eyes | DIY Clutch Stop | DEPO Smoked Corners | DEPO Sidemarkers | DEPO Smoked R/C/R Tails | DIY AUX input | DIY Red Needle Mod | CDV Delete | Front Plate Delete | Debadged |
Dahmwern is offline   Reply With Quote
Old 11-01-2012, 05:19 PM   #15
dmhonda
well thanks but I live in Florida so I'm not going to have an issue with a cold belt and its most definitely the disa unit it's coming from the top of the engine not the front of the car
