Sponsored by BimmerWorld
Old 10-29-2012, 06:17 PM   #1
NicenLoW
My Ride: E46 JB AA S/C
Raceland coilovers popping noise.
So I installed these on my 02 330ci and I'm getting a popping noise drivers side. The coil sounds like its binding and popping. I jacked up drivers side and moved spring around to mimic the sound.....seems like the upper coil is rubbing the top cap. Is there supposed to be a spring pad between these parts? It looks to me that there should be one?
E46 M3 AA S/C
E53 X5 3.0i
NicenLoW is offline   Reply With Quote
Old 10-29-2012, 06:26 PM   #2
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Aren't Raceland coilovers supposed to make all kinds of horrible popping noises?
SpeedDemon is offline   Reply With Quote
Old 10-29-2012, 08:45 PM   #3
fth001
My Ride: 325i, e36m3, s13
Check to see if the washer between the upper spring perch and strut mount is installed. That noise is from the strut mount bearing not seated correctly so the mount makes contact with the spring perch causing the spring to rotate on the coilover itself. Or it just might be Cause Raceland.
fth001 is offline   Reply With Quote
Old 10-29-2012, 10:20 PM   #4
FoxEyes
My Ride: 328i & M5
the poping is the system clicking into sport mode, it means you will be able to corner faster and harder, push it to the limit
FoxEyes is offline   Reply With Quote
Old 10-30-2012, 01:33 AM   #5
E40SICK
My Ride: 2001 330ci
endlinks? i had issues with mine being lose.
E40SICK is offline   Reply With Quote
Old 10-30-2012, 06:13 AM   #6
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
The popping noise is your coil over saying, "I'm a piece of sh1t".
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 11-01-2012, 07:14 PM   #7
NicenLoW
The passenger side is perfect. There's something I don't on different I guess. Is there supposed to be a washer between the top hat of coilovers and the strut mount?
Sent from my SCH-I500 using Bimmer App
E46 M3 AA S/C
E53 X5 3.0i
Old 11-01-2012, 07:15 PM   #8
NicenLoW
And once that sound is fixed ill be very pleased with these coilovers.
E46 M3 AA S/C
E53 X5 3.0i
Old 11-02-2012, 11:57 PM   #9
NicenLoW
Bump.
Need to figure out if I need the washer or not?
E46 M3 AA S/C
E53 X5 3.0i
Old 11-06-2012, 09:53 PM   #10
fth001
Originally Posted by NicenLoW View Post
Bump.
Sorry bro just got back from SEMA. Yes you do need that washer in there. It's part #5 and 6 and goes between the upper strut mount and upper spring perch. http://realoem.com/bmw/showparts.do?...08&hg=31&fg=10
Old 11-08-2012, 12:07 AM   #11
NicenLoW
I just can't find this popping. Almost sounds more like spring binding. I checked over everything, strut mount bearing seems good. Any ideas?
E46 M3 AA S/C
E53 X5 3.0i
Old 11-08-2012, 12:14 AM   #12
E40SICK
My Ride: 2001 330ci
have you checked to make sure you endlinks aren't lose?
Old 11-08-2012, 12:48 AM   #13
NicenLoW
Yeah double checked all bolts/nuts everythings tight.
E46 M3 AA S/C
E53 X5 3.0i
Old 11-08-2012, 12:50 AM   #14
E40SICK
My Ride: 2001 330ci
dont race lands need short endlinks to begin with?
Old 11-08-2012, 08:51 AM   #15
TnT817
My Ride: 01 330ci
That binding noise is because your strut bearing isn't pressing on the center of the bearing allowing the coil-over to rotate freely. You need to put the proper sized washer in there for the noise to go away. Proper size is enough to touch the inner bearing race and not touch the outer race.
TnT817 is offline   Reply With Quote
Old 11-08-2012, 09:51 PM   #16
NicenLoW
I used my oem washers. Seems to only touch inner race. Basically covers the size of the bearing dust shield. Note* this is only on one side. This weekend I'm a take it all apart again and start from beginning
E46 M3 AA S/C
E53 X5 3.0i
Old 11-26-2012, 07:34 PM   #17
CoupeMagic323ci
My Ride: 00 323ci
aaand? prob will get these for xmas. cheap ass gf. oh well better than nothing lol
PS3N ID: siberiasurvivor
CoupeMagic323ci is offline   Reply With Quote
Old 11-27-2012, 12:46 AM   #18
jamex
My Ride: 2005 325Ci
Popping and clunking going straight and not turning and it's not your end links.
Trying to think back to my race land experience. Front end clunk you either didn't torque your strut mounts down proper or you may have included or excluded a washer between the coilovers and the strut mount.
Unbolt one end link if you want to eliminate end kinks as your culprit. Easiy way of knowing if your preloaded from longer end links than you need. Don't drive like a maniac but try to generate the clunking again. Still clunks and it's something else.
jamex is offline   Reply With Quote
Old 11-28-2012, 12:37 PM   #19
Jesse M
My Ride: 05' ZHP
Jesse M is offline   Reply With Quote
Old 09-06-2013, 11:24 AM   #20
nrob1323
My Ride: 320i e46
Was a missing washer the cause of the clunking/binding noise? I am having the same issue with my RL struts
nrob1323 is offline   Reply With Quote
