Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 05-10-2012, 11:36 PM   #41
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by MotorMan View Post
What's the current plan and how far along are you? I've been dieing to get back working on mine but I don't see that happening for a while.
I stopped working on the 330Ci in 2010, and started working on a 330i turbo street car.
Old 11-04-2012, 04:20 PM   #42
richyboycaldo
My Ride: Mx5 300zx 240z 330c
how's the tranny holding?
richyboycaldo is offline   Reply With Quote
Old 11-05-2012, 11:14 PM   #43
WALKD U
My Ride: Just Fast!
Doesn't even run yet...hehe
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 11-05-2012, 11:30 PM   #44
always-there
My Ride: 2002 BMW 330I
I agree, it's always good to have someone to bounce numbers off of.
I've got my own spreadsheets, but I also use Larry Meaux's software.
Here's the finished piston design, which is even more extreme than you thought:
Valve relief was for really big cams....300/296 custom design from Schrick:
You don't want to oversize the exhaust valve....unless you've got a heat issue and need the extra surface area to dissipate heat back into the head. I had a head ported for 30.5mm and another head ported with 31.5mm valves, and the smaller valve flowed a little bit more up top.
Those are some serious pistons.
Old 05-03-2013, 11:05 AM   #45
doricar
My Ride: E46 330 / E36 318SC
What am I doing wrong?
Trying to calculate the compression ratio of my M54...Well what I mean to say is...I'm trying to figure out how different thickness headgaskets will affect my comp ratio, and then work out (if running 1.5bar of boost on a TD06-25G turbo) will equate to what boost compression ratio.
Basically trying to figure out what gasket to order to make my life as easy as possible. Don't want to over/under compress my engine. Hoping to find a gasket size with a sweet spot ready for my turbo setup.
Here's a screenshot of the comp ratio calculator i'm using. I just cant seem to get it right. It either displays the 100% stock engine as 7:1 or 13:1 I can't seem to enter the correct settings to get it to the 10.2:1 or whatever stock is...
doricar is offline   Reply With Quote
Old 05-03-2013, 09:28 PM   #46
MotorMan
My Ride: e39
A couple of quick questions:
  • Since you said you are trying to make your calculations match the stock engine, can I assume that you are basing your numbers off of stock pistons?
  • If you are basing your numbers off of stock pistons, I don't think you have the right numbers. My data shows the piston at .118" below deck and the valve reliefs are so small that you can pretty much ignore them.
  • You show a dome volume of 17.4cc's. The stock piston is a flat top, which would mean 0.0cc's in that cell, or a slightly positive number if you include the tiny valve reliefs.
I get a stocked "measured" CR for the 3.0L M54 of 10.0/1, which seems to be consistent with other peoples measurements.
Gary
MotorMan is offline   Reply With Quote
Old 05-03-2013, 09:32 PM   #47
doricar
Hi Gary,
Thanks for that. I guess what I read on the internet about the cc's wasn't correct. My engine is 100% stock. Actually, I'm not building it myself. I am driving for a team here in Japan, but due to BMW's not being popular in Japan I am trying to do the research and source the parts from the US for the guys here.
At the moment, we are only planning on ARP rod bolts, head studs, and a thicker head gasket. We're not going crazy on power, so hoping that it will be good enough for now. In the future, obviously we will be going for proper pistons, rods, crank, headwork etc. but for now we just need to get the engine running properly at around 400 crank hp.
I'm currently trying to figure out what size headgasket is the best to order. VAC (I think) has a lot of different options, so I want to work out which will be best for us. The mechanic here just said get a 2mm gasket, which is about 0.080", but I want to keep the engine response good, and off-boost characteristics nice.
Thanks for your help.
Old 05-05-2013, 12:03 AM   #48
doricar
If the stock CR is roughly 10:1, what thickness head gasket would be best for lowering the CR to around 9:1 ? I guess a 0.080" / 2mm would be best suited.
Old 05-05-2013, 12:09 AM   #49
MotorMan
My Ride: e39
Yes, a 2mm gasket would yield 9.0/1 on a stock m54.
Gary
Old 05-05-2013, 12:36 AM   #50
doricar
Thanks Gary...time to grab the boss' credit card then
Old 06-06-2013, 09:17 AM   #51
numnkaznc
My Ride: 330ci
M54B30 Specs and Measurments
Firstly HI.
I have 330ci smg gearbox 200.000k
My engine wear is too bad l must replacing and l want incresing engine compression ratio but modded engine parts very expensive for me. please help me. Anybody dont know M54B30 spec. Anybody cant help me.
l want incresing 11.1:1 my engine ..
My guess l skim block surface gor this comp ratio
But l dont know which size skim..??
and l afraid pistons hit the cylinder head or valves hit the piston.
Can l increasing comp ratio this method..??
if this method is true , what should l do..??
Please give me your experience and knowledge please help me..
numnkaznc is offline   Reply With Quote
Old 06-06-2013, 02:25 PM   #52
Iceman00
Banned User
My Ride: E90 6MT
I can't see the CR causing any notable increase in power.
Old 06-06-2013, 02:46 PM   #53
SK330ci
My Ride: 02 330ci w/ 3 Pedals
I hear what you're saying,......but.
It's like any of the N/A mods that we do: CAI, Catback, Power Pulleys, and Tune. It's worth the 3whp to 6whp that any of those will give you, as long as he can justify the price.
If he can pull off "decking the block" to get 11:1 compression, it will make a little more whp. But I'd go a different route.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 06-13-2013, 05:32 PM   #54
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Originally Posted by numnkaznc View Post
Firstly HI.
With an 84mm bore, you have 55.38 cm2 area.
I found 17.4cc area inside the bore @ TDC, which works out to an "average" of 3.1mm depth.
To get 11:1 compression, you'd need to create 11.3cc area inside the bore, or reduce the deck height by approximately 1.1mm.
I have no measurement for valve clearance with this....but I've heard that it can be done.
Old 06-14-2013, 11:08 AM   #55
Iceman00
Banned User
My Ride: E90 6MT
From what I've seen, higher compression doesn't add any power at all, I could be wrong, but it's what I've seen so far. I would spend money on the head and crank personally.
Old 06-15-2013, 02:23 PM   #56
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
It works, you just need a fuel that can take advantage of it.
There are diminishing returns though; going from 9:1 to 10:1 will give you greater gains than say 10:1 to 11:1.
Old 08-28-2013, 09:36 AM   #57
daniel_f.
My Ride: 330iC
Bringing this back to life:
Does one know how thick the liners are? is it possible to bore the block to 86.5mm? whithout using new liners?
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-28-2013, 02:27 PM   #58
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
84mm bore, with 1.5mm think liners IIRC stock...so there would be nothing left of the liners if you did it.
In the racing environment, 84.5mm is as far as I've seen M54 blocks go...and engine builders didn't advise going past that.
In contrast, most sleeve vendors like to start @ 3mm thick.
I would stick with OEM liners unless you are planning to run a TON of boost.
Old 08-28-2013, 03:02 PM   #59
daniel_f.
My Ride: 330iC
Well, my intention was to build a 3,3L M54 which should have been build by several companies here in germany, but sadly no one gives specs.
i wanted to use 86,5mm pistons and 93,8mm stroke. but if there isnt enough material left, i will charge the engine
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-29-2013, 05:18 PM   #60
se93
My Ride: BMW 328ci AW MTECH2
Daniel
Would be a real treat to have an Alpina E46 3.3liter powerplant under the hood!!!
Regards
Nark
Regards,
Mark Perez
se93 is online now   Reply With Quote
