Engine & Performance
Old 10-13-2012, 08:53 PM   #1
e.usaf
My Ride: '05 330i / '01 330Ci
FS - BNOB Mechman HO Alternator - 300a+ - $575
Hello, all. I have a brand new Mechman alternator for sale. If you are looking to run some serious electronics this is what you need. I purchased it with intent of supporting a very large amplifier but have switched my goals, thus have no need for it any longer.
Since Mechman doesn't usually support BMW applications, I had it custom made to fit my '05 330i. Luckily Eric @ Mechman happened to have his E46 for test fitting. It should bolt on to anything with an M54 in it, more than likely any I6 E46's.. The unit was sold to me as a 270a, but "benched over 300a". Maximum output is achieved before 1800rpm. It's idle output is over 165a. Awesome unit! 14v, of course.
I have email traffic from Mechman for the whole process. They have a very solid reputation for high quality stuff. I also have instructions from the company on how to install it included. 0ga ofc wire can also be negotiated if needed.
Feel free to inquire with anything. $575 shipped.
e.usaf is offline   Reply With Quote
Old 10-14-2012, 02:15 AM   #2
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
contact "bobm3", he was looking for a H.O. alternator
itscoo2pyopants is offline   Reply With Quote
Old 10-14-2012, 03:32 PM   #3
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
thanks for geting in touch with me
you are alittle to late my ice guy send mind out already . i don't need one now.....thanks anyway.....
bob
bobm3 is offline   Reply With Quote
Old 10-21-2012, 03:32 PM   #4
e.usaf
bumpp..
Old 10-22-2012, 01:34 AM   #5
TrippinBimmer
My Ride: Just Fast!
Could you scan the instruction. I want to know how this fit as I have a s/c and might now work
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 10-22-2012, 08:16 AM   #6
e.usaf
Sure thing. I will get that up tomorrow for you.
Old 10-24-2012, 06:15 PM   #7
e.usaf
See attached for instructions. Sorry it took me a bit longer to scan it than expected, I've been swamped at work
Old 10-29-2012, 06:25 PM   #8
e.usaf
$560 shipped. I need funds for my new laptop before I deploy!
Old 11-06-2012, 12:09 PM   #9
e.usaf
Counting the days until I leave now.. I will not be able to ship for 6 months if it isn't sold soon..
Old 11-08-2012, 08:09 PM   #10
ault786
My Ride: 330ci
It will not fit supercharged engines. I bought one and am going to end up selling it for this reason. Will fit NA engines perfectly
ault786 is offline   Reply With Quote
Old 11-08-2012, 09:01 PM   #11
TrippinBimmer
My Ride: Just Fast!
Alpine White M3
MaximumPSI Stage4
Old 11-09-2012, 12:04 AM   #12
e.usaf
May I ask what exactly of your FI system inhibits your alternator installation? I am honestly not sure if the case size is any larger than the oem.. research time!
Old 11-09-2012, 01:22 AM   #13
TrippinBimmer
My Ride: Just Fast!
It seems like it alter the position of the Pulley. On my FI unit there is a hole in the bracket for the pulley to be in its OEM position. With this alternator and its custom mount bracket. The pulley might not be in the same position and will cause issues...
Alpine White M3
MaximumPSI Stage4
Old 11-09-2012, 08:55 AM   #14
e.usaf
This unit alters nothing to my knowledge. There is no custom bracket to mount it. It is a direct replacement for the oem unit from what I have been told. The only thing I do not know is if the case is larger. However, I doubt a slightly larger case would prevent this from fitting..
Old 11-09-2012, 09:06 AM   #15
TrippinBimmer
My Ride: Just Fast!
That is that Big Aluminum Block that is bolted to the Alternator? Also, the bracket for the FI uses the Hole Mounting surface to mate up to for support.
Alpine White M3
MaximumPSI Stage4
Old 11-15-2012, 12:33 PM   #16
ault786
My Ride: 330ci
Exactly! Well put. That is exactly the fitment problem on FI.
It fits perfect on NA engines.
Old 12-08-2012, 08:46 AM   #17
bizrar
My Ride: 2001 bmw 330ci
Lightbulb
Hello, if you're still in the us... Do you still have this for sale?
bizrar is offline   Reply With Quote
Old 12-08-2012, 02:30 PM   #18
e.usaf
It is still in my possession. I leave this Monday morning so I may still be able to get it out if you are interested.
Old 12-09-2012, 01:07 AM   #19
bizrar
Thanks for responding so quick! I'm interested but at the moment i'm trying to get my car back on the road so i purchased the voltage regulator, for now... I might get back to you if I absolutely can't find any other alternatives. Thanks bud and good luck on your endeavors.
Old 04-13-2013, 02:10 AM   #20
bizrar
do you still have this?
