Old 11-09-2012, 09:23 AM   #1
volcamp55
My Ride: 1993 325is
Xenon vs HID vs H7
I currently have Xenon headlights (with type Bosch AL ballasts) in my 2002 330i. Both headlights have problems. My question is this .. if I were to find some HID headlights or H7 headlights, would these be suitable replacements for the Xenon (type Bosch AL) headlight assemblies I currently have. I'm getting ready to sell the 330i and I really don't care if the headlights are Xenon, HID, or H7 .. I just want the cheapest way to fix it and have working headlights. Thanks .. Rick
volcamp55 is offline   Reply With Quote
Old 11-09-2012, 09:53 AM   #2
Grande D
My Ride: E36 M3
The car will have to be coded if you go from xenon to halogen. HID is xenon technically, although HID often refers to cheap kits people put in Halogen lamps. Do not do that. It's tacky and distracting for other drivers.
It will change your life!
Old 11-09-2012, 09:55 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Read this
http://forum.e46fanatics.com/showthread.php?t=925497
What is wrong with the headlights? You can either fix the issues or get halogen headlights and put in Morimoto mini projectors (coding won't be needed)
Old 11-09-2012, 12:01 PM   #4
volcamp55
My Ride: 1993 325is
Thanks for the info, guys! I initially had the driver's side ballast die, due to moisture getting into the electronics. I got a used ballast replacement and had it installed, and problem was fixed .. for 4 days. Then it went out again. had my mechanic thoroughly swap out and test everything from ballast, igniter, and bulbs, as well as continuity in the wiring. He couldn't find anything wrong, except that the ballast must be out. After this testing, the passenger headlight started going on and off and random. I feel like it's all related and that there might be a short in the wiring somewhere. Any ideas? Thanks in advance for your help.
Old 11-09-2012, 02:31 PM   #5
haurelio
My Ride: 2001 bmw 325i
hmmm. just like you mention, it could be a short somewhere.. there are some test that can be done but not sure which ones.. if thats the case, even if you switch to halogen, the problem might still persist because of the short..
Contact me if you need to unlock your phone.
Also can code your car
