Best replacement for OEM shocks & struts? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 10-01-2012, 08:32 AM   #1
EdwardSkribLHndz
My Ride: 2001 BMW 325xi Wagon
Looking for best oem replacement, ride quality, comfort. Not coil overs.
I have Bilstein Sport with H&R springs. Love the handling, hate the bumps. Want to go back to oem feel.
2001 325xiT
EdwardSkribLHndz is offline   Reply With Quote
Old 10-01-2012, 10:02 AM   #2
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
I'm replacing my shocks and struts with Sachs, per the Sachs part catalog. I believe at one point were or currently are the original shock/strut supplier to BMW. They should give you what you need, at a lower price than the Original BMW branded parts.
http://www.zf.com/na/content/media/u...cks_Struts.pdf
Old 10-01-2012, 10:16 AM   #3
ZHPinthe103
My Ride: 325i Black on beige
Bilstein HDs with stock springs. pretty much stock feel/ride height
ZHPinthe103 is offline   Reply With Quote
Old 10-01-2012, 11:32 AM   #4
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
No question about it.... I've used pretty much every suspension setup that is available for the E46 and you hands-down want to get the Koni FSD struts and just use your H&R Springs with them.
SpeedDemon is offline   Reply With Quote
Old 10-01-2012, 01:11 PM   #5
EdwardSkribLHndz
Hmm, I've always heard bad about Koni.
Old 10-01-2012, 01:18 PM   #6
SeanC
My Ride: 330i
Koni Yellows.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 10-01-2012, 05:25 PM   #7
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Koni's are a good bang for the buck shock that will be close to factory feel. If you get Koni adjustable (top adjust) you can play with the damping to get a little more personalization/customization out of the driving experience.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 10-01-2012, 05:35 PM   #8
erice46
My Ride: 2002 325I
How do the compare top hotchkis springs
erice46 is offline   Reply With Quote
Old 10-02-2012, 10:22 PM   #9
Roach
My Ride: 2005 325iT
Just put on the Koni FSDs with stock sport springs. Feels like stock only with slightly better control when cornering hard. Highly recommended.
Roach is offline   Reply With Quote
Old 10-04-2012, 11:58 AM   #10
SpeedDemon
FSD is not the same as other Konis. Read up and trust the guy who has had 4x E46s and has used every piece of suspension. /thread
Old 11-09-2012, 02:36 PM   #11
ZHPSteve
My Ride: 2004 330i ZHP
Would you also recommend these for a 330i ZHP? I have 120K Miles on what I think are the original shocks/springs so it's definately time to replace.
ZHPSteve is offline   Reply With Quote
Old 11-21-2012, 02:29 PM   #12
austin335i
My Ride: Pre-LCI E90
I just installed Monroe OESpectrum front and rear. Feels softer than stock and doesn't control the rebound as well as stock. Probably a good choice for someone who doesn't know any better, seeing as they were affordable and readily available, but I would stick with koni str.t or FSD if you have the money.
austin335i is offline   Reply With Quote
Old 11-21-2012, 03:47 PM   #13
boongsin12
My Ride: none
I too am looking for OEM replacement for struts and shocks. I came across the Meyle brand struts and shocks and they are much lower in cost. Has anyone tried them? Seems like a good deal since Meyle is an OEM supplier.
boongsin12 is offline   Reply With Quote
Old 11-21-2012, 05:23 PM   #14
SeanC
My Ride: 330i
Since when Meyle is an OEM supplier?
Sent from my SGH-I997 using Bimmer App
Old 11-21-2012, 05:43 PM   #15
boongsin12
My Ride: none
Oppps. I think I am incorrect. OE? manufacturer? right?
Old 11-21-2012, 08:31 PM   #16
SeanC
My Ride: 330i
Meyle is an aftermarket supplier for BMW. Sachs is the OE brand for shocks.
Old 11-21-2012, 08:43 PM   #17
boongsin12
My Ride: none
OK I understand now. But still want to know if anyone has used them.
Meyle shocks are around $40 from BMA parts
http://www.bmaparts.com/item.wws?sku...MEYLE&weight=4
The struts are about $75 each also from BMA parts
http://www.bmaparts.com/ShopByVehicl...sembly&mode=PA
I might also have a deal for Bilstein HD shocks and struts for $500. Should I get them or should I just go for stock sports suspension? I use my e46 as a daily.
