#1 |
Car Repair
So I dropped my car off at BMW Norwood yesterday for a tail light recall and an oil change, this is what I get from them today...it's an 8 page breakdown with all of the problems with my car, to the tune of $5081.33!!! Any adivce? I honestly feel like this is a scam because the car seems to be running fine. I did notice the tire, but outside of that, this is nuts!!! Thanks again all.
Original Customer Requests The following is what you requested we perform or investigate regarding your vehicle: A. TOP OFF WASHER FLUID PER CUSTOMER REQUEST B. 0063220100 B63 06 11, E46 sedan tail light ground C. PERFORM A WORLD CLASS MULTIPOINT INSPECTION. D. THIS RESERVATION CREATED BY MATT 595 E. Oil and Filter Change (Unscheduled/Customer Requested) (OEM) F. CUST STATES WASHER FLUD LEAK POSSIBLE BMW Gallery of Norwood World Class Package Results Inspection Failed Task Observation Recommendation Inspect accessory drive belts Found all drive belts cracked Replace all drive drive belts Inspect overall tire and wheel wear and condition Found bubble in sidewall Mount and balance 1 new tire (right front) Check engine oil level and condition and check for leaks Found engine oil leak • Reseal oil filter housing • Replace vanos hose • Replace valve cover gasket Cautioned Task Observation Recommendation Inspect axles, driveshaft(s) and CV joints/boots • Found left outter CV boot rotted • Found right outter CV boot dry rotted • Found left inner CV boot leaking • Found right inner CV boot leaking • Replace both front inner CV joint boots • Replace both front outer CV joint boots Measure left front tire tread depth 4mm Measure right front tire tread depth 4mm Measure right rear tire tread depth 4mm Measure left rear tire tread depth 4mm Check power steering fluid level and condition and check for leaks Found power steering fluid seep Replace power steering hose (pump to rack) Check brake fluid level and condition and check for leaks Found brake fluid to be dirty/contaminated Perform brake system fluid service BMW Gallery of Norwood 918 Providence Hwy Norwood, MA ***9679; (781) 762-2691 ***9679; www.bmwgallerynorwood.com 647573 2 ** The following section may contain instructions for servicing various components of your vehicle. These are an overview of the process that will be performed by a skilled technician in our shop. They are not intended to be a guide for a “do-it-yourself” operation. Passed Task Observation Recommendation Check and adjust all tire pressure Set tire pressures to recommended psi - Check tire pressures monthly Measure front brake pad total thickness Greater than 5mm Measure rear brake pad total thickness Greater than 5mm Passed Tasks Inspect engine mounts Inspect air cleaner element Fill windshield washer fluid Inspect hazard light operation Inspect brake light operation Inspect back-up light operation Inspect taillight, turn signal, side marker, and license plate lights Inspect taillight, turn signal, and side marker assemblies for cracks and damage Inspect fog lights and headlight low and bright beam operation Inspect windshield wiper and washer operation Check horn operation Inspect heat and air conditioning operation Inspect dash and interior lights Inspect instrument panel warning lamps Inspect all vehicle wiper blades Perform battery performance check Inspect battery terminals and cables Inspect ignition wires and spark plugs (if equipped) Inspect cabin air/HEPA micro filter (if equipped) Inspect all hoses and clamps Inspect front windshield and rear window condition Inspect power locking system operation Inspect power window and mirror operation Check and adjust all tire pressure Measure front brake pad total thickness Measure rear brake pad total thickness Inspect exhaust system for leaks, damage, and loose parts Inspect wheel bearings Inspect transmission mount(s) Inspect transfer case fluid level and condition (if equipped) Inspect rear differential for leaks Inspect fuel tank, lines, and connections Brake Caliper Siezed Inspect front differential for leaks (if equipped) Inspect steering and sway bar components Inspect suspension components Check clutch adjustment Check engine coolant level and condition and check for leaks Inspect transmission for leaks Additional Observations Recommendation R/R DIRECTIONAL OUT. AFTERMARKET TAILLAMPS INSTALL FACTORY TAIL LAMPS Below is information we feel would help you better understand some of the reasons for taking preventive maintenance steps -- steps that help to ensure the reliability and safety of your vehicle for you and your family. Additional Information BMW Gallery of Norwood 918 Providence Hwy Norwood, MA ***9679; (781) 762-2691 ***9679; www.bmwgallerynorwood.com 647573 3 ** The following section may contain instructions for servicing various components of your vehicle. These are an overview of the process that will be performed by a skilled technician in our shop. They are not intended to be a guide for a “do-it-yourself” operation. The accessory drive belts on your vehicle perform many functions. The power steering system, alternator (charging system), and AC system are all driven by accessory drive belts. On some vehicles, accessory drive belts also drive the water pump, engine cooling fan, and air injection pump (emission control). Accessory drive belts wear during normal engine operation, and need to be checked and replaced periodically; you can lose one or more systems if a belt is broken. A broken fan or waterpump belt can cause severe overheating which could result in expensive repairs, or even total engine failure. A broken power steering belt can result in the loss of your vehicle's power steering system, which could make your vehicle very difficult to steer. A broken alternator belt could cause your vehicle to lose all of its electrical power, and could eventually result in a dead battery. Significance: Worn accessory drive belt New accessory drive belt AI-11 Loosen the drive belt tensioner and remove the old belt. Inspect the tensioner and idler pulley bearings for noise or signs of wear. Inspect tensioner and idler pulleys. Install the new belt. Start the engine, and after a minute or so, shut the engine off. Recheck the belt tension and make final adjustments as necessary. Operation Description: Belt replacement - serp, acc, fan, drive, v Advantage: Make sure that the drive belts on your vehicle are in good condition. This is an important point to keep in mind as you attempt to keep your vehicle reliable and safe. Drive belt replacement is recommended at certain mileage intervals. This step can also save you money by avoiding possible engine damage and costly engine repairs. BMW Gallery of Norwood 918 Providence Hwy Norwood, MA ***9679; (781) 762-2691 ***9679; www.bmwgallerynorwood.com 647573 4 CV joints allow your drive axles to transmit torque to the wheels, while still allowing the wheels to turn left or right when steering the car. CV joints also allow the suspension to function normally, while still allowing the drive axles to move your car down the highway. The CV joint boots cover the CV joints protecting them from dirt, debris, and water. A torn or damaged CV joint boot allows the CV joint grease to collect dirt and debris, which will quickly destroy the joint. A worn out CV joint will start to make noise, and will eventually break, leaving the vehicle disabled. Often times, other vehicle damage will result when a CV joint breaks, resulting in an expensive repair. Significance: Damaged CV joint New CV joint AI-21 Remove the CV axle with the damaged joint from the vehicle. Remove the worn-out CV joint from the axle shaft. Pack the new CV joint with the proper grease, and install it onto the axle, along with a new CV boot. Reinstall the CV axle assembly onto the vehicle. Operation Description: CV joint and boot replacement Advantage: Nobody wants to be stranded by the side of the road with a broken-down vehicle. Replacing a worn-out CV joint will help ensure that your vehicle stays reliable. You will also save money by avoiding additional damage and expense that can be caused by the CV joint breaking completely. Your vehicle's tires are the only connection between your vehicle and the road. Safe vehicle operation depends on your tires being in good condition. If your tires are neglected, the tread can wear completely away, leaving the tire bald and often exposing the steel cords. Not only is this condition dangerous, it is also unlawful in many states. Tires with an abnormal tread wear pattern can cause the vehicle to shimmy and vibrate, and can adversely affect the manner in which your vehicle performs. A tire with an abnormal tread wear pattern will no longer contact the road the way that it was designed to, and this condition can be dangerous, especially during adverse road conditions. Significance: Signs of irregular tire wear New tire AI-23 Raise the vehicle using an automotive lift. Remove the rim and tire assembly from the vehicle. Remove the tire from the rim. Install a new valve stem assembly. Install a new tire on the rim. Inflate the tire to recommended pressure. Balance the tire and rim assembly on a computer-aided dynamic tire balancing machine. Reinstall the tire and rim assembly onto the vehicle. Torque the wheel retaining nuts to the vehicle manufacturer’s specifications. Operation Description: Tire replacement Advantage: Replacing worn tires is part of vehicle maintenance that is necessary to ensure that your driving experience is as safe as possible. Besides the obvious safety benefits, tires that are in good condition and properly inflated to the correct air pressure can increase the overall fuel economy and help provide a comfortable ride. BMW Gallery of Norwood 918 Providence Hwy Norwood, MA ***9679; (781) 762-2691 ***9679; www.bmwgallerynorwood.com 647573 5 Does your vehicle’s brake pedal feel “spongy”? Brake fluid becomes contaminated over time and use. Heat and moisture can cause brake failure. Contaminated fluid leads to expensive repairs. Significance: Harmful deposits on brake master cylinder piston assembly Brake fluid before and after service AI-63 One of our skilled technicians will check the condition of your vehicle’s brake fluid and, if necessary, remove contaminated fluid from the brake lines and master cylinder, replace the old fluid with appropriate brake fluid. The entire brake system will be inspected for leaks, master cylinder corrosion, worn pneumatic parts, harmful varnish build-up, broken or rusted bleeder valves, worn rotors and drums, and air in the brake lines. Operation Description: Brake fluid exchange service Advantage: Worn-out, oxidized brake fluid causes corrosion and harmful deposits and varnish build up. A brake flush service should be performed when your brake fluid shows contamination or every 30,000 to 40,000 miles. Over time, the gasket that seals the valve cover to the head assembly wears and eventually fails. Typically this allows oil to leak from the valve cover, but sometimes the leak occurs in the spark plug wells. If the dipstick is reading low and there's no sign of oil smoke, you may have an oil leak. One common place for oil leaks is from where the valve cover meets the cylinder head. Significance: Removing a valve cover to replace gasket New valve cover gasket AI-105 Remove valve cover bolts and valve cover. Clean out excess oil. Clean all mating surfaces. Replace valve cover gasket and inspect interior O rings. Inspect all surfaces for cracks and deterioration. Operation Description: Valve cover gasket replacement Advantage: Intake and exhaust valves open and close rapidly while the engine is running. This extreme mechanical activity requires oil for lubrication. All this happens under the valve cover. The valve cover gasket seals the oil between the engine and the valve cover. After time and many miles, the valve cover gasket can dry out and crack. When this happens, all the oil flying around inside the valve cover will escape, leaving you with an ugly oil leak. BMW Gallery of Norwood 918 Providence Hwy Norwood, MA ***9679; (781) 762-2691 ***9679; www.bmwgallerynorwood.com 647573 6 Many BMW engines have a mechanism that allows for variable advancing of the camshaft timing. This component has an oil feed line (hose) that will begin to leak with age. It is not uncommon for this hose to weep oil and leak it on top of the engine. Significance: A leaking vanos hose A new vanos hose AI-213 Replacing a vanos hose is a complex operation and requires several specialized tools. It requires removal of the engine's intake manifold to gain access. We replace the hose and the aluminum sealing rings and reinstall the intake manifold and related components. Operation Description: Replace Vanos hose Advantage: Replacing any pressure hose prior to complete failure saves you at the very least from an oily engine and garage floor. A hose failure can leave you stranded, possibly with a complete engine failure due to oil loss. Our technicians recommend the following services for your vehicle. Recommended Services Original Customer Requests Status Cost Declined Approved A. TOP OFF WASHER FLUID PER CUSTOMER REQUEST $0.00 X B. 0063220100 B63 06 11, E46 sedan tail light ground $0.00 X C. PERFORM A WORLD CLASS MULTIPOINT INSPECTION. $0.00 X D. THIS RESERVATION CREATED BY MATT 595 $0.00 X E. Oil and Filter Change (Unscheduled/Customer Requested) (OEM) $143.53 X F. CUST STATES WASHER FLUD LEAK POSSIBLE $0.00 X Subtotal $143.53 $143.53 Inspection & Additional Recommendations Insp Status Cost Declined Approved Reseal oil filter housing (Found engine oil leak) x Fail $574.02 Replace all drive drive belts (Found all drive belts cracked) x Fail $232.83 See AI-11 Mount and balance 1 new tire (right front) (Found bubble in sidewall) x Fail $547.00 See AI-23 Replace valve cover gasket (Found engine oil leak) x Fail $543.91 See AI-105 BMW Gallery of Norwood 918 Providence Hwy Norwood, MA ***9679; (781) 762-2691 ***9679; www.bmwgallerynorwood.com 647573 7 Inspection & Additional Recommendations Insp Status Cost Declined Approved Replace vanos hose (Found engine oil leak) x Fail $293.74 See AI-213 INSTALL FACTORY TAIL LAMPS Fail $744.08 Subtotal $2,935.58 Replace power steering hose (pump to rack) (Found power steering fluid seep) x Caution $485.91 Replace both front outer CV joint boots (Found right inner CV boot leaking) x Caution $618.98 See AI-21 Replace both front inner CV joint boots (Found right inner CV boot leaking) x Caution $618.98 See AI-21 Perform brake system fluid service (Found brake fluid to be dirty/contaminated) x Caution $149.00 See AI-63 Subtotal $1,872.87 Totals, Taxes and Fees Cost Declined Approved Estimate Subtotal $4,951.98 $0.00 $143.53 Environ. Charges $25.00 $7.80 Tax $104.35 $4.10 Estimate Total $5,081.33 $155.42 For "See AI-" items see the "Additional Information" section BMW Gallery of Norwood 918 Providence Hwy Norwood, MA ***9679; (781) 762-2691 ***9679; www.bmwgallerynorwood.com 647573
![]() 2004 Sapphire Black Metallic 330xi 6MT Cold Weather Premium Sport Package |
#2 |
how many miles does the car have on it? Most of that stuff is wear and time... You have a 6+ year old German car... all of that stuff will go eventually and probably needs to be done sooner than later... Of course, you'd have to be nuts to have it done at the dealership...
![]() 2004 330i ZHP (me) 2006 X3 (wife) 2004 325xi (sold) 2001 325i (passed on to DavidJay) MY DIY write-ups MY Garage (all the mods) |
#3 |
I agree with Steve here....most of this you can DIY saving lots of money....
![]() 2004 TiAg ///M3 2003 Imola Red 330i ZHP 1999 Electric Red 323i - SOLD |
#4 |
Take this estimate to an independent shop such as BPG, Boston Motor Werks, etc and see if they can cut you a deal.
#5 |
I agree, go to the DIY section for most of the work. Recently, there were some things I needed to get done to my car that I couldn't DIY. I went to Turner Motorsports. They have loaner cars for the day if you need one as well. Highly recommended.
2002 E46 330xi Active Autowerke Stage I Supercharger Magnaflow 11378 exhaust Bilstein shocks/struts + H&R springs Style 71s Soon to be installed Bimmerbrakes headers + LC1... ![]() |
#6 |
My Ride: gobbles oil like a B
holy sh*T bro. Seeing things like this makes me so glad that I DIY everything on both of my E46's and I should print this out and show it to my wife.
Here's a few ballpark savings for you based on the price to DIY: Oil Filter Housing Gasket replacement: Gasket costs $6-12 at the DEALER, cheaper on line, and that's your cost. The $500+ is all for labor, and this isn't an incredibly difficult job. Valve Cover Gasket change: Gasket with all grommets costs about $60 online, OEM BMW parts, and that's it, so the $500+ is for labor, but again, this isn't a particularly difficult job, just time consuming. Replace one tire, ONE TIRE and they want to charge you that? #1 I though the dealer NEVER EVER EVER Recommended replacing one tire, at a minimum two, and I honestly though that all dealers would tell you to replace all 4 of them, even if one was bad, based on the tread depth. WTF?? Replace taillights with factory tail lamps? HAHAAH, WTF is that, and I am sure they would charge you $500+ for a nice set of OE orange tails. If you do not want to have to go out and purchase new (rebuilt) half-shafts, which are around $400 a pop, and you have FOUR OF THEM, then you should get the boots replaced at a reputable indy shop as mentioned above. Then again, you could easily go buy 4 new ones, install them yourself, and you're still saving $3800 over the price of what they said!! this is just nuts. NUTS> What an azz raping they gave you. At least you declined, thank god! Love how they call it a "world class inspection" now too, what is that, a marketing term used to reel in rich people to unload their wallets for simple, mundane procedures? Sorry, this is all the DIY mechanic in me speaking out. If I had to rely on prices like this to fix my E46, I surely would not own one, or two even.
#7 |
Yea what he said ^. I did the VCG and belts for under $100 very easy job took 4 hours or so.
My baby's a DD. 1st BMW so learning the ropes. Going for 200k; currently 101k.
#8 |
Norwood & World Class. Ha. Their Body Shop "repaired" my wife's X5 after it was hit on front pax door. Upon p/u...2 miles out & a few bumps, the right-hand mirror & housing fell completely off. Returned car & got it back 5 days later. Airbag light kept coming on. Took it to Herb Chambers...Norwood "forgot" to install the pax side door airbag. Went back to Norwood & got the car back 4 days later. World Class? Maybe they ought to @ least have a mouse in the shop perform 2 mins of quality assurance on all work. Norwood is a joke. I think they are now part of Herb Chambers? Whatever.
