Old 11-11-2012, 07:38 AM   #1
jimmy325i
My Ride: 325 sedan
exhaust fume resonating sound
What I originally thought was tappet noise, is actually exhaust fumes resonating in the exhaust manifold. This is accordaing to a BMW specialist. And I think I belive him because I came across a 330 and heard the same sound. However, is there anyway of damping or cancelling this horrible sound out?
jimmy325i is offline   Reply With Quote
Old 11-11-2012, 08:01 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Sometimes the exhaust mani heatshield gets loose and rattles. This is the first I've heard of someone having an issue diagnosed as such.
A tape of sound would probably help...and so would you using a stethoscope or hose as stethoscope to isolate the sound.
Try techron to clean up the fuel system...make sure you're using a proper LL-01 oil. See if that gets you anywhere. Also, some just rip off the heat shield...but I'm not so sure about that myself.
GL...hth
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-11-2012, 09:08 AM   #3
HiHoBrian
My Ride: 05 M3
It may be the sound you hear is a leak AT the manifold,not IN the manifold. I know from installing headers on different cars and trucks when the gasket fails it sounds like a ticking valve or lifter. IMO your head to manifold gasket has failed. It's a pretty involved job. The only ways to correct it is to diy,or pay up for gasket replacement.
Edit: definatly confirm that it is a leak before pursuing a repair.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 11-11-2012, 09:13 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Also check your spark plugs for any looseness. That causes a ticking sound too.
Old 11-11-2012, 10:13 AM   #5
jimmy325i
My Ride: 325 sedan
not the spark plugs for definate. Gonna look in to the other possibilities. Thanks
