Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
Display Modes |
#221 |
My Ride: 04 IR/IR 6MT M3
Car will be on the dyno again Monday pending an installation error on the shops part gets fixed. They damaged one of my o2 sensors so need to replace it.
2004 E46 ///M3 Imola/Imola 3 pedals |
#222 |
Video was just for sound comparison.
#223 |
When are they coming out ?
#224 |
+1 Also interested in the release date on these.
I might jump in on a set.
![]() 2005 BMW 330i ZHP |
#225 |
He already said sometime in the beginning of the year.
Sent from my SGH-T959 using Bimmer App
#226 |
February.
Sent from my DROIDX using Bimmer App
#227 |
Need a set now, engine would be out this week
Sent from my DROID RAZR using Bimmer App |
#228 |
It takes a whopping 15 minutes max to strap a car down and do a pull... how did they not have time? It's hard to tell how much of an impact a weeks time of driving, adaptive learning, weather change, etc will have. Also, is the test car really swapping exhausts prior to the re-test? That makes it even more apples to oranges...
Also, that's a very veeeerrryy slow pull. I feel sorry for your engine. I dyno'ed mine on a Mustang setting the weight as 2,500 lbs and aero to 10hp and even then it seemed to take forever. Did they have it set up for curb weight or a timed pull? We always had to set the weight to 70-80% of the actual curb weight otherwise the pulls were too long and too taxing... |
#229 | |
The Brake Newbie!
-Anthony@BimmerBrakes |
#230 | |
if all of that concerns you it shouldn't - you'd be seeing much more conservative gains in this case rather than some over stretched gains when they added the performance parts - not took them off. besides a tse-3 muffler and stock muffler aren't doing much performance wise anyway - the tse-3 was just welded behind the stock resonators. as for the adaptations - car wasn't driven at all as they bend one of my o2 sensors so I left it in the garage until I went back. I don't work the dyno (either does Anthony). They do whatever they do because thats how they do it I suppose. They said they wanted a more accurate run in 4th gear so I let them do that instead of 3rd. I assume the weight has SOMETHING to do with the calculations of power and if it doesn't then whatever - it is a 60-120mph pull.
2004 E46 ///M3 Imola/Imola 3 pedals Last edited by UdubBadger; 11-08-2012 at 11:53 PM. |
#231 |
Udub- On a Mustang chassis dyno if you use the "vehicle simulation" it uses the weight and the aero losses you input to calculate the load needed to be applied by the Eddy brake to simulate the acceleration of the vehicle as if it were on the road. Using timed runs or slightly overloading is good for tuning because knock events are more likely to register but in doing power pulls it's not really warranted. I operated a Mustang dyno for over two years and just wanted to shed some light on how they operate. I also don't like seeing cars abused unnecessarily...
Edit to clarify: They are correct in using fourth gear because it's the closest 1:1 trans ratio on a MT. They can speed up the pulls though... I look forward to the results. Last edited by SH4DY; 11-10-2012 at 10:51 PM. |
#232 |
My Ride: 2004 330ci ZHP 6MT
In for results. Curious
![]() 1995 325i 5mt ArcticGrey/Dove - SOLD 2004 330ci ZHP 6MT SilberGrau/Black - SOLD 2001 330i M-Sport 5MT StaulGrau/Grey - SOLD 1992 Accord LX Sedan 275k miles all original - DAILY 2002 Chevy Suburban LT Autoride - TOY HAULER 2005 GMC Sierra 2500HD SLT - RACE TRUCK! |
#233 | |
And to be fair we were tuning on these runs also. Supposed to get the graphs emailed to me soon so ill post them up.
2004 E46 ///M3 Imola/Imola 3 pedals Last edited by UdubBadger; 11-10-2012 at 11:35 PM. |
#234 |
Updates!
///UNDER CONSTRUCTION 323i///
18X9.5 Et33 V710 ![]() |
#235 |
#236 |
I screwed up and can't post
So Still no dyno?
#237 |
Banned User
#238 |
I need these, lol
#239 |
trying to get the shop to send me the correct files. I got a zip file today but it was all text data and no graphs. He said I had to download the mustang software which I did, but it didn't show me anything with the files he sent.
I will say this shop has proven to me why they are going out of business... so inefficient.
#240 | |
Banned User
