2001 m3 accelerates on its own - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 11-11-2012, 07:11 PM   #1
Mircea's M3
My Ride: Bmw M3 2001
Hello, I've had my m3 for a couple months now and had no real major issues until the other day, when I got on the highway entrance ramp, I was rolling down the ramp in 4th gear without touching the gas, hovering above brake pedal and all of a sudden I felt it pull so I clutched in and the engine was revving up to 4-5k rpm, I pumped the gas and went down.
I noticed it does this mostly on ramps when I turn quite a bit
Car has k&n intake which I know it affects rpm but it hasn't done that before.
Changed the battery the day before (battery wasn't recommended by BMW but it had over the specs that it requires)
I read something about sticky throttle but I'm not sure if that could be it, it just doesn't seem similar to my problem
Any help would be much appreciated
Mircea's M3 is offline   Reply With Quote
Old 11-11-2012, 08:26 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
I believe your car is drive by wire so there is no physical connection between the gas pedal and the throttle body.
I see you live in Canada as well.
A very common problem with many cars is the floor mat. Do you have a Winter floor mat or is the standard floor mat Velcro backing torn loose and/or are you missing the plastic inserts that screw into the floor?
Old 11-11-2012, 08:41 PM   #3
PH03NIX46
My Ride: 2003 M3
Search the car for these badges:
Report back with details.
Eibach | Sportline | OEM Euro Headers | TTFS
PH03NIX46 is offline   Reply With Quote
Old 11-11-2012, 08:47 PM   #4
Mircea's M3
That was my first thought as well! But that's not it, I kept testing it to see in what conditions it does it and its only in big turns such as highway ramps or big roundabouts any gear doesn't matter.
I know the car is drive by wire so there is no cable to get stuck anywhere so that's what gets me so lost.
My floor mats are properly set in place
Thank you for your input tho much appreciated
Old 11-11-2012, 08:48 PM   #5
Mircea's M3
Hahaha none found they must be hidden lol
Old 11-11-2012, 08:57 PM   #6
scarede46er
My Ride: 2001 BMW 325i ZSP
If you live in Canada, it is possible that thanks to the snow, water has contaminated the TPS potentiometer in your accelerator pedal. In most cases, you can take it out and dry it. Else you may need a new one.
Old 11-11-2012, 09:12 PM   #7
Blocked Out
My Ride: Imola 330i M-Sport
you sure you're not just hitting your cruise control buttons(stored/reactivate)???
Original BMW Teile ///
IMG_1725
Old 11-11-2012, 09:14 PM   #8
Blocked Out
Rubbish !!!
None of what you said makes any sense. And sounds kind of racist actually
IMG_1725
Old 11-11-2012, 09:26 PM   #9
M3LIKECHIPS
My Ride: Prius
Check for toyota parts
M3LIKECHIPS is offline   Reply With Quote
Old 11-11-2012, 09:39 PM   #10
scarede46er
Originally Posted by Blocked Out View Post
Rubbish !!!
dafuq?
Old 11-12-2012, 01:24 AM   #11
M3LIKECHIPS
My Ride: Prius
dafuq?
YOUR A RACIST, DAMMIT.
Old 11-12-2012, 01:59 AM   #12
berserker
My Ride: 2000 328i stick
You do not have drive-by-wire, your throttle just got stuck, has happened to me as well. You can find that behind the firewall, drivers side, my cable fell out at 5400 rpm - never happened again, just a freak thing.
berserker is offline   Reply With Quote
Old 11-12-2012, 05:50 AM   #13
Mircea's M3
I also thought of the cruise control but once I got on the highway I tried the cruise and it didnt work which I thought might be related, it worked before.
Lol no Toyota parts already checked haha
And no this car hasn't been driven in the snow and it hasn't snowed this year yet.
I will check behind the firewall but I find it weird that it only does it on big turns
Thanks everyone for the input
Old 11-12-2012, 05:53 AM   #14
Mircea's M3
And it happens every time
Old 11-12-2012, 09:23 AM   #15
DSilk56
My Ride: M-3 Convertible
It wouldn't be the cruise control, since depressing the clutch immediately disengages it.
DSilk56 is offline   Reply With Quote
Old 11-12-2012, 09:34 AM   #16
Dreamwerke
My Ride: 2001 m3 6spd
Mine did the EXACT same thing two days ago after getting a flat tire and only have 16" to put up front..
Dreamwerke is offline   Reply With Quote
Old 11-12-2012, 09:36 AM   #17
Dreamwerke
It has to be a sensor. It was the weirdest thing. I live in Delaware and it only does it in 3rd and 4th gear
Old 11-12-2012, 09:44 AM   #18
Mircea's M3
Wow that's weird because I had a flat on front right and I put 17 inch wheels on front and that was a few days before
Damn that's weird that makes no sense
Thanks for mentioning that
Old 11-12-2012, 09:49 AM   #19
Mircea's M3
And I have 19 inch rims in the back,
So I wonder if because they don't spin at the same rate the computer gets confused
Old 11-12-2012, 09:52 AM   #20
Dreamwerke
That's what my friend that works for BMW said something about compensating for the wheel spin. Ill be putting 19s back on today or tomorrow ill keep you posted.
