///M3 Forum
The BMW E46 ///M3 is the M version E46 and puts out an amazing 333 HP and 262 lb-ft of torque at stock specs! There are an amazing amount of modifications for both the coupe and convertible models so read up and get started modifying your cars today! |
#1 |
2001 m3 accelerates on its own
Hello, I've had my m3 for a couple months now and had no real major issues until the other day, when I got on the highway entrance ramp, I was rolling down the ramp in 4th gear without touching the gas, hovering above brake pedal and all of a sudden I felt it pull so I clutched in and the engine was revving up to 4-5k rpm, I pumped the gas and went down.
I noticed it does this mostly on ramps when I turn quite a bit Car has k&n intake which I know it affects rpm but it hasn't done that before. Changed the battery the day before (battery wasn't recommended by BMW but it had over the specs that it requires) I read something about sticky throttle but I'm not sure if that could be it, it just doesn't seem similar to my problem Any help would be much appreciated |
#2 |
My Ride: '06 330CiC, '03 M5
I believe your car is drive by wire so there is no physical connection between the gas pedal and the throttle body.
I see you live in Canada as well. A very common problem with many cars is the floor mat. Do you have a Winter floor mat or is the standard floor mat Velcro backing torn loose and/or are you missing the plastic inserts that screw into the floor?
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#3 |
Search the car for these badges:
Report back with details.
#4 |
That was my first thought as well! But that's not it, I kept testing it to see in what conditions it does it and its only in big turns such as highway ramps or big roundabouts any gear doesn't matter.
I know the car is drive by wire so there is no cable to get stuck anywhere so that's what gets me so lost. My floor mats are properly set in place Thank you for your input tho much appreciated |
#5 |
Hahaha none found they must be hidden lol
#6 |
If you live in Canada, it is possible that thanks to the snow, water has contaminated the TPS potentiometer in your accelerator pedal. In most cases, you can take it out and dry it. Else you may need a new one.
#7 |
you sure you're not just hitting your cruise control buttons(stored/reactivate)???
#8 | |
None of what you said makes any sense. And sounds kind of racist actually
#9 |
Check for toyota parts
#10 |
#11 |
#12 |
You do not have drive-by-wire, your throttle just got stuck, has happened to me as well. You can find that behind the firewall, drivers side, my cable fell out at 5400 rpm - never happened again, just a freak thing.
#13 |
I also thought of the cruise control but once I got on the highway I tried the cruise and it didnt work which I thought might be related, it worked before.
Lol no Toyota parts already checked haha And no this car hasn't been driven in the snow and it hasn't snowed this year yet. I will check behind the firewall but I find it weird that it only does it on big turns Thanks everyone for the input |
#14 |
And it happens every time
#15 |
It wouldn't be the cruise control, since depressing the clutch immediately disengages it.
#16 |
Mine did the EXACT same thing two days ago after getting a flat tire and only have 16" to put up front..
#17 |
It has to be a sensor. It was the weirdest thing. I live in Delaware and it only does it in 3rd and 4th gear
#18 |
Wow that's weird because I had a flat on front right and I put 17 inch wheels on front and that was a few days before
Damn that's weird that makes no sense Thanks for mentioning that |
#19 |
And I have 19 inch rims in the back,
So I wonder if because they don't spin at the same rate the computer gets confused |
#20 |
That's what my friend that works for BMW said something about compensating for the wheel spin. Ill be putting 19s back on today or tomorrow ill keep you posted.
