EML Light Issue - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 11-10-2012, 01:44 PM   #21
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
I just took out the disa,ICV, cleaned both also cleaned the throttle body and I cleaned the connectors as well, I'm gonna go head and clear the code and see what I would in the next couple of days , keep you guys posted
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 11-10-2012, 03:28 PM   #22
03E40sick
So here is the deal .. I cleaned the ICV, the throttle body, the disa, and the MAF sensor .. Let everything dry then drove to the gastation to get gas which is not even half a mile.. All three lights come on... Ugh so aggravating.
Old 11-11-2012, 10:01 PM   #23
Dippinwandy
My Ride: 325i
Sucks man. Were on the same boat. Im doing the job right now.. I have 2 icv in my hand my original and a used on from another car. I shake them and i can hear both of them opening and closing but my original sounds different than the new (used) one.. It sounds like its "looser" . Im not sure which one to put back in my car?
Dippinwandy is offline   Reply With Quote
Old 11-11-2012, 10:15 PM   #24
NFSx328ci
My Ride: TiAg E46
I had the same thing happen to me once before, it was cool night out and i was running the car hard, EML light came on aswell as the Traction Control light when i downshifted to get off the highway. The car ran like crap while trying to accelerate. It did not accelerate very well at all. Parked the car, read the code, same as yours, turned the car back on and it was gone. Weird tho. Never had this happen before and it has not came back on since then, 2 months ago.
My babies; Supercharged 328ci, 2009 Alpine White 135i.
625awhp 99 GSX(SOLD), Straight Piped 2011 Grand Cherokee (SOLD)
NFSx328ci is offline   Reply With Quote
Old 11-12-2012, 10:45 AM   #25
03E40sick
I honestly don't know which one , don't even know how loose it should be but I am going to change the ICV to a new one .. And if that doesn't help then I have no idea what the problem is
Old 11-17-2012, 03:53 PM   #26
03E40sick
I changed mine to a new one and it didn't help :/
Old 11-17-2012, 06:15 PM   #27
Dippinwandy
My Ride: 325i
Just curious, what intake/air filter do you have ?
Old 11-17-2012, 08:05 PM   #28
03E40sick
I have the stock elbows with aftermarket filter directly connected to the MAF , would that makes any diff?
Old 11-18-2012, 08:34 PM   #29
Dippinwandy
My Ride: 325i
That might be the problem there. I am coming to a conclusion that some intakes/ filters are causing this and many other problems.
I also have an aftermarket intake.
Try going back to your stock intake and filter see if that fixes anything.
Old 11-18-2012, 11:29 PM   #30
03E40sick
I will try and do that and will let you guys know what happens , anything new with anyone ?
Old 11-19-2012, 11:04 AM   #31
illfx
My Ride: AA330i
HI Guys,
Looks like a few of us have the same problem. My eml light came on after I replaced my MAF. The first time it went off the car was running horribly, barely staying alive. After I let it sit and cool down for an hour it was fine. Since then the eml w/ limp mode would only come on when I hit 6 grand. Ive googled this and found this link. They mentioned that it was a tube that failed and after replacing the car ran fine. Any thoughts?
http://www.bmw-driver.net/forum/showthread.php?t=15140
330i,AA STGE 1, Tein coilovers. TMS front/ rear sways, KMAC camber plates, TMS trailing arms, Rouge Engineering CF strut bar, Brembo cross drilled, UUC steel braided lines,
Meyle control arms, Powerflex bushings, AA Gen 3 HI FLO exhaust. AA headers, BAV AUTO high performance coils, AA stage 2 clutch/ flywheel kit...
Linea Corse LMs
19 x 8 front
19 x 9.5 rear
illfx is offline   Reply With Quote
Old 11-19-2012, 06:10 PM   #32
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
Originally Posted by alinfaraonu View Post
I hawe problem ENGINE, EML and DSC,hand brake on all yellow.U find the problem pls help me
the last 3 are all related to dsc system, you have a bad wheel sensor, need an indy with carsoft or the like to find which one
the cel, is prob the bad sensor code
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 11-19-2012, 06:25 PM   #33
03E40sick
The three lights come on after the fourth or the fifth gear and to be more specific, when I'm cruising .. Idk im leaning towards the throttle body
Old 11-21-2012, 02:52 AM   #34
Dippinwandy
My Ride: 325i
Well .......... My lights came back on
Old 11-21-2012, 01:25 PM   #35
03E40sick
Where you cruising when it came back on?
Old 11-21-2012, 01:31 PM   #36
Dippinwandy
My Ride: 325i
Yup. I was driving at a constant 40mph.
Now its coming on more often than last week.
Old 11-21-2012, 01:33 PM   #37
03E40sick
Yes mine is doing exactly the same thing :/ throttle body ? Did you repackage your ICV ? Do you a check engine light on ?
Old 11-21-2012, 01:39 PM   #38
Dippinwandy
My Ride: 325i
It might be throttle body. But i never touched mines. Im pretty sure my icv is fine i cant see anything wrong with it. I always have my check engine light on because i have aftermarket headers. But my eml, traction, and yellow brake light come on at the same time.
I also have aftermarket intake so im going to try to get a stock one to see if that fixes the problem.
Old 11-21-2012, 02:17 PM   #39
03E40sick
Man you have exactly what I have.. I mean EXACTLY ... Aftermarket headers and aftermarket intake .. And ICV seems very clean and nothing is wrong with it .. I am leaning towards the throttle body, do you have any programming done ?
Old 11-21-2012, 03:02 PM   #40
DrkSide_RbL
My Ride: 99' 328i Sport Sedan
Send a message via AIM to DrkSide_RbL
EML usually relates to Throttle body. Flaps may be getting stuck by built up gunk. Remove throttle body and clean both sides of the flap with tb cleaner. If that doesnt work then your tb may be faulty. It could also be your pedal sensor if your tb is drive by wire and not mechanical.
check my thread below...a lot of useful info:
http://forum.e46fanatics.com/showthr...686&highlight=
I still haven't fixed the problem btw. I figured I need a new tb but its so expensive
Sent from my SAMSUNG-SGH-I727 using Bimmer App
DrkSide_RbL is offline   Reply With Quote
325i, emission, eml, error code
