#1 |
WHY should you change your fuel filter?
I have read on many occasions that fuel filters should be replaced and I have thought "Ok. When its been on there for a while I guess it wouldn't do any harm I suppose". But then another voice in my head says "Hey. We are talking about petrol here. There can't be anything cleaner outside the passenger area than the fuel tank and the petrol you pump into it. So where's the advantage?". Right? So where would the alleged crap come from to block up the filter?
Anyway. I went out and bought a new filter. Exactly the same as the old filter. Got it home. Took it out of the box and, just out of curiosity, blew through it. There was absolutely no resistance to me blowing at all. Like it wasn't there. Its now on the car and I have the old one in my hand, drained of petrol of course. So I have blown through that to see if there is any difference. Knock me down with a feather!!!!! Have you ever tried to blow up a balloon? You know that tough bit where you have to get it to start off and the air goes everywhere except into the balloon? Well not as bad as that but not far off. So there is a CONSIDERABLE resistance to air flow in the old one. So much so that I wouldn't like to be the fuel pump having to push fuel through it towards the injectors. That's got to be hard work. I am suddenly aware that this must inevitably have an impact on performance. In fact, having been for a run, it now goes like sh*t off a shovel. (That's a British expression. Means FAST. It comes from the olden days. Days of terraced houses and untethered dogs what used to roam the streets sh*tting at liberty. The solution was to scoop up the crap on a shovel and flick it into a the realm of the dog's owner. Preferably so that it hits the front door keyhole. I was an expert. Its all in the wrist action!) I suppose it will be injector O-rings next (the ones on the inside of the injector not the outside) unfamiliar, as they must be, with having to confront an unrestrained fuel pump. I shall keep an eye on them. Dribbling may be imminent. So there you go. Mine eyes have been opened. Change that fuel filter guys. This still doesn't explain where the crap comes from. I am going to try and split the old one open and see what's in there. I will post some pics of the guts of the old one in due course. Last edited by RayPooley; 11-12-2012 at 08:01 AM. |
#2 |
The crap comes from the petrol tank at the station.
It wouldn't hurt to clean the pick up on the pump if you change it again in 60k and find the same amount of resistance.
![]() 2002 TiAg M3 OEM 19s/Fiamm triple air horn/Valentine V1/Uniden BCD396T/Uniden XL 520 Pro/Lightwerks TFX with 55 watt kit/Mediabridge 1500/Pro Fit iPhone bracket and holder |
#3 |
My Ride: '06 330CiC, '03 M5
You will find next to nothing in the pump pick up screen. The screens are far more coarse than the fuel filter element.
I am a firm believer now that you really need to change the fuel filter every 30k miles as the paper element is rather fine and picks up all sorts of crap. If you bother to cut open a fuel filter, you will likely find the inside element caked in a black sludge. Depending on how dry the filter is, the black will be an ultra fine powder that you can scrape off. You will be surprised how thick this black gunk will actually get.
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#4 | |
#5 |
Stay stock my friends!
...and a couple of other reasons to change it:
I read here that one fanatic had a no-start issue because of an original fuel filter not being changed up to 130K miles. Also, when I did mine after an indefinite period of time (got the car as third owner), I got an extra 1.5 mpgs., so even if you pay someone to do it, you get a pretty short payback time. If you don't know when it was done, start logging your mpg/mph data, change the filter, and compare the difference...bet you'll find a noticeable one. Jfoj, I'm not sure about the 30K mile interval though...I'm thinking it's an Inspection II item, which I believe means 60K miles.
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#6 | |
Mine is from late 2009 so I'd assume it has about 60k on it Last edited by daves325in2012; 11-12-2012 at 08:12 AM. |
#7 |
Weagle Weagle
Mine has 67k on it. I might keep it around to cut it open as well. I imagine mine is ****ed. I need new pressure regulator vacuum fittings as well.
#8 |
Platinum Plus Quality
This guy is starting to see the PM light.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#9 |
Weagle Weagle
Indeed.
It's funny that this is overlooked so often. There is a filter there for a reason, and that is gas is actually pretty dirty. Anything that's a filter, fluid, or moves/rotates a lot will always wear out at some point. |
#10 |
#11 |
It's both a night light to help you find your way to the bathroom at night, and it's the light you see, when your car is properly preventatively maintained...and you can bask in the glow from the security it gives you. Kind of makes me cry what a warm feeling that is!
This, btw, is not to be confused with the Mango light, which spells doom and foreboding, especially if you ignore it. We've lost many e46s because of failure to see 'this' light...aka the low coolant warning light. The PM light is a spiritual light--only believers can see it!
#12 |
Registered Gadfly
In a manner of speaking, it's also a kind of a Kool Aid light, if you're old enough know what that reference is about. It's pink, and it only comes on once, usually rather late in life.
Engineers do it with a torque wrench
#13 | |
![]() Yes there was even a short-lived thread about it! http://forum.e46fanatics.com/showthread.php?t=937253
#14 |
#15 |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
Gas isn't perfectly clean, of course you'll need to change it every 60k or during Inspection II.
Also I wouldn't put my mouth on it
E46Fanatic's resident mathemagician
#16 |
No. That would be the color of your fuel.
#17 |
#18 |
Preventative maintenance? Oh good heavens NO. Not at all. I replaced the fuel filter because I have an intermittent problem that I am trying to fix. Started Thursday last week. According to the Mango school of car maintenance I would have to replace the filter, the pump, the injectors, the petrol, in short, everything between injectors and tank on a just-in-case basis. In fact, if I remember correctly, isn't that the advise you gave to some poor unsuspecting schmuck last week? Can't remember what his problem was. A leaky 23 cent injector O-ring or something like that. The mango solution would set him back about $700 in parts alone. So certainly no hint of a conversion here and never will be.
As it happens, I also replaced the crankshaft position sensor today. And here's the rub. The one I replaced has only been on the car for 7 months. Why's that you ask? Well. Its because in March this year I had a misfire situation. Codes lead me to suspect intake camshaft sensor. So I replaced the intake camshaft sensor AND also replaced the exhaust cam position sensor and the crank position sensor. The very definition of your PM principle wouldn't you say? IF IT AIN'T BROKE, FIX IT! Isn't that your mission statement? Yet here I am 7 months later replacing the crank position sensor. Chances are, had I left the original one in place I wouldn't have had to do that today. So all in all I reckon that takes your IF IT AIN'T BROKE, FIX IT PM strategy firmly by the throat and gives it one straight up the backside. Its nonsense. And I really do wish you would stop pushing it on people who know no better. Last edited by RayPooley; 11-12-2012 at 11:37 AM. |
#19 | |
![]() I needed a laugh today. Thank you!
#20 | |
Weagle Weagle
I am an extreme moderate. I believe all those not in favor of moderation ought to be hanged. My strategy of waiting for a mild issue and then replacing everything that's convenient while I'm there works fairly well if you're not made of money. Last edited by WDE46; 11-12-2012 at 12:13 PM. |
