Old 11-12-2012, 02:17 PM   #1
ballroom
My Ride: e46 320d year 99
Lose oil?!?!
Hello!
here i am again this time with a doubt about oil!!!
My car, 320d 136cv, loses oil.
Is this normal?
How much?
in 11 000 Km, the distance on oil measurement, between max and min, it's on middle!!!.
Is this normal?
Hum, it has a repro to 150cv, but doen't leave smoke, no oil on floor at morning, and does have not oil marks on engine... I'm sad! What's happening!?
Thanks a lot,
Best regards
ballroom is offline   Reply With Quote
Old 11-12-2012, 02:21 PM   #2
Platinum Plus Quality
My Ride: M54B30
I don't know what a 320d is but whatever engine you have, it could be anything. you need a full maintenance package done on the car. start there.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 11-12-2012, 02:25 PM   #3
ballroom
Thanks,
320d is e46, engine 2000cc, 136cv year 99.
what do You mean about full maintenance package?
11000Km back in time, i've changed filters, oil, air filters thermostat.
Old 11-12-2012, 02:26 PM   #4
lcoleman
My Ride: '79 Massey Ferguson
You may have a leak which makes this worse, but ~1/2 quart per 11K km isn't bad as far as consumption goes. Even a quart wouldn't really be too bad in that distance.
Old 11-12-2012, 02:27 PM   #5
My Ride: M54B30
Originally Posted by ballroom View Post
Thanks,
Your engine likely has at least one dozen oil seals or gaskets that potentially need addressing.
Old 11-12-2012, 02:40 PM   #6
ballroom
yep, i imagine that!
not good news !
Gonna open the engine and check then.
maybe could be engine gasket damaged....
Now i know that this is not normal, and gonna study and learn
Thanks a lot for your help
Old 11-12-2012, 02:45 PM   #7
WDE46
Weagle Weagle
WDE46's Avatar
My Ride: 2004 330Ci OBM
not good news !
If you open the engine, you need to replace any seals you opened to get there...
Old 11-12-2012, 04:44 PM   #8
ballroom
Thanks,
i will make a plan first with the help of autodata, so i can buy all to open
Old 11-12-2012, 05:16 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
WAIT!!!
You are half way down (between the upper and lower marks on the dipstick) after 11,000 kilometers?
I'm not sure that you are consuming oil at a rate that even starts to be a problem. How far is that in miles? Seems to me it should be 7,000, give or take. That's not a problem at all. There is absolutely no problem with burning a half-liter of oil over that distance.
Old 11-12-2012, 05:34 PM   #10
ballroom
Originally Posted by jdstrickland View Post
WAIT!!!
Hello,
yes it's about 6800 miles, and yes half way down on dipstick (finaly i know how to call this in english )
so i should consider this a normal thing?
Hum, in that case i won't open!!
Thanks a lot for your reply
Old 11-12-2012, 05:41 PM   #11
ballroom
thanks a lot for reply
Old 11-12-2012, 06:03 PM   #12
jdstrickland
Hello,
Yes, it's normal.
Indeed it is not normal at all, it is far _better_ than many other people get. Your oil level is fine anywhere between the two marks on the dipstick.
You should check the oil before engine start. Pull the dipstick out and wipe it clean. Put it back in completely and pull it out again. The oil can be any place between the two notches and is considered to be okay. If the oil it at the lower notch, then a full quart/liter is needed to bring the oil to the upper mark.
Old 11-12-2012, 06:54 PM   #13
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.03809 mu
Mango is after your car being factory fresh, but most can't really do that.
1/2 qt. loss of oil over 7K miles is fine. Better than most I'd wager...and I'd be right.
But, you can do other stuff on the car. Find any leaks you have by cleaning up engine well and look for leaks with good led flashlight with around 100 lumens or so. Then realoem.com for every Part Number you'll ever need.
tis.Spaghettidecoder.org will get you bmw tis's.
Tell us more about the car and we'll give you other places to spend money and time...like belts, pulleys, cooling system stuff like therm, ET, wp...maybe a few hoses. Mango will be upset you're not rebuilding your engine, but you can appease him by at least replacing some cooling system parts!
This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe."
The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax
Old 11-13-2012, 12:23 PM   #14
ballroom
Thanks,
ok. Good news .
belts are new, change when change oil and all the filters, back 7k miles.
water thermostat and egr thermostat also changed.
I haven't changed anything else, and don't know when they are changed in past .
Sometimes i think to chage water motor and auxiliary water reservatoir.
But i see no leaks on water circuit for now...
Now about oil leaks i found one vey small... this could be my problem.
Send attached one pic to show where is...
Is in that hole where a screw is attached...
And now i don't know how to close the hole!
If screw removed, that is used to attach engine cover, and motor is running, i can see a little oil smoke getting out!
Strange thing... i think the old owener used a bigger screw that he can...
To fix i think i nedd to open valve cover and close from inside... so that motor suction does not open again the hole.!
Maybe this is enought to explain my oil leak...
Name:	fuga motor.jpg
Old 11-13-2012, 12:29 PM   #15
WDE46
Weagle Weagle
WDE46's Avatar
I wouldn't just open the valve cover for exporatory surgery just yet. I'm gonna search around and see if I can't find what goes in there for a 320d.
Old 11-13-2012, 12:36 PM   #16
ballroom
Ok, thanks.
i think to use silicone, but i don't know... afraid that engine suction suck that for inside :S
Old 11-13-2012, 12:40 PM   #17
cposk
My Ride: 08' E90 M3
Thanks,
ok. Good news .
I love the new cooling system terms and will be using them from now on.
cposk is offline   Reply With Quote
Old 11-13-2012, 12:45 PM   #18
ballroom
lol.
i'm sorry, but is the best english that i have :S
but could be maybe water pump?
or, maybe reservatório de água do radiador and bomba de água...
google does not translate that very good..
sorry
water pump should be that makes the water circulate...
and reservatório de água do radiador, should be that thing where you put the coolant...
Old 11-13-2012, 01:40 PM   #19
cposk
My Ride: 08' E90 M3
lol.
sorry
No need to apoligize... I knew exactly what you meant making the translation functionally successful.
Old 11-13-2012, 02:07 PM   #20
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
After 11,000km, having the dipstick level come from Max to the middle is perfectly acceptable.
Max to Min difference is about 1quart of oil.
Stiggles is offline   Reply With Quote
