Old 11-12-2012, 08:09 PM   #1
QwiksilverA4
My Ride: Audi
How to remedy this?
I just bought a m3 and this is what is going on w the driver side angel eye. How so I go about fixing this??
QwiksilverA4 is offline   Reply With Quote
Old 11-13-2012, 05:24 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
The solder joint is bad on the back of the circuit board or the connection from the ring to the wire harness is bad. If you have only one positive and ground wire for both angel eyes on one side then it's the solder issue. You can fix it by taking out the old solder from the back of the ring and put in new.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
