Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
Display Modes |
#301 | |||
#302 |
Banned User
Ice Man you got a PM. Need your help with my dyno runfiles
Name: Flashtwosix Car/Engine E46 323i w/ M54B30 ZHP Engine running on MS42 328 Tune (90,000 miles). ZF Automatic Transmission Mods: Shark, AFE CAI, Technik Gen2 Headers, Rogue Engineering Under Drive Pullies, UUC TSE3 exhaust, Plasma Ignition Coils, Shark Injector Dyno type: Dyno Jet Peak numbers: 199HP /197 Ft/Lbs |
#303 |
Very healthy numbers for an M54 on a M42 DME with an automatic.
The curve of the graph doesn't look like the computer is getting too screwed up and pulling crazy timing in places or anything like that either.
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. Last edited by jared_wiesner; 11-13-2012 at 08:50 AM. |
#304 |
flashtwosix if you had a 3.0l tune imagine how much hp you would pick up, or is is not supported on ms42?
#305 | |
Banned User
sent from my dahc-6900 using Bimmer App |
#306 |
Did you get my PM?
#307 |
Banned User
#308 | |
Banned User
thank you for the assurance. my biggest concern was timing issue also. e-mail sent. Feel free to keep and use the run files for your archives |
#309 |
I did the math, the numbers on the screen are incorrect and are likely do to the spike at the beginning of the dyno. Torque = (5252*hp) / RPM.
#310 |
FYI, those numbers are EXTREMELY healthy, and about 20whp down on a manual counterpart. I don't think there is too much to be gained by changing the software, the biggest losses are do to drivetrain.
#311 |
Banned User
Iceman, that is why u t the expert. Thanks
#312 |
Iceman, do you see a consistent drop in power between summer and winter blended fuel? I may have dynoed with winter fuel and that could partially explain my numbers.
#313 |
I've never heard seen anything of the sort. Do we know the dates when the blends are specifically changed? I've taken dynos year round, and it has been fairly consistant.
#314 | |
I asked my buddy at the gas station and he said that they switched a few months ago. He mentioned something about switching between 7lb and 9lb fuel (per gallon). I live in Kansas. |
#315 |
As someone who lives in Canada, yes, winter fuel will hurt power output. Most winter fuels are "winter fuel" because their ethanol content has been bumped up close to the maximum allowable. This is to help prevent freezing in the gas line. Iceman likely hasn't had to deal with this living in Florida, I'm talking -5 F and colder temps being a concern. I deal all winter with people coming into our dealership complaining of poor mileage compared to their summer mileage. Between the slush on the roads and the fuel it's to be expected. That being said, you'd might still make more ultimate power on a dyno because you won't have to worry about heat soak. I tend to notice my car feels the fastest in the spring and fall when temps are cooler and I'm not using winter gas.
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. |
#316 | |
#317 |
What's up everybody!? Alright, thought we'd give it one more go on the dyno just for good measure...before I tear it back down again. We pulled a little more fuel up top and played around w/the timing a little bit too, and well...I think the results speak for themselves!?!? We managed to eek out a few more ponies, and torque is now up to 275ft lbs. The car is making 300HP by around 6,000ish rpms and then hitting 360+HP @ 7,700rpms and holding it all the way to 8,500rpms. The car is running very, very well!
'04 AW/IR Not Stock |
#318 |
Holy S hit! Those numbers are fantastic for a N/A M3!
#319 |
Tempted to follow?
#320 |
Thank you sir!
Do it, no regrets!
| Tags |
| dyno, dynoed |
