Old 10-24-2012, 11:32 AM   #1
E46iT
My Ride: 2004 325i Touring
have DRL on at all times
is it possible to have my drl lighs on at all times even when i have the Xenon lights on?
E46iT is offline   Reply With Quote
Old 10-24-2012, 11:41 AM   #2
chris98891
My Ride: '01 325i
Send a message via AIM to chris98891
You want them on when your headlights are on? That's going to blind oncoming drivers if you run them at night time. They're pointed significantly higher than your main headlight. And as far as I know it isn't possible in the computer. Probably with hardware modification
-Chris
chris98891 is offline   Reply With Quote
Old 10-24-2012, 11:53 AM   #3
E46iT
how does having drl on blinds on-coming traffic they only operate at 20-30% power.
Old 10-24-2012, 12:07 PM   #4
chris98891
My Ride: '01 325i
it's still pointed directly at them
-Chris
Old 10-24-2012, 12:13 PM   #5
E46iT
again drl run at 20% to 30% power which is not blinding to oncoming traffic.
Old 10-24-2012, 12:52 PM   #6
Drewfus2101
My Ride: '03 330i
No, can't be done.
Drewfus2101 is offline   Reply With Quote
Old 10-24-2012, 01:49 PM   #7
pinoybmr3
My Ride: low and slow
use angel eyes instead of DRL, its on all the time...
pinoybmr3 is offline   Reply With Quote
Old 10-24-2012, 02:52 PM   #8
chris98891
My Ride: '01 325i
personally, i wouldn't do it. its your car, but i wouldn't say for sure it doesn't blind oncoming traffic until you see it from an coming cars point of view at night time. my opinion, not gospel. i double checked my LSZ's option, and there isn't a way to code it in my car.
-Chris
Old 11-01-2012, 02:53 PM   #9
Nick_M3
My Ride: 2005 325ci
NO! You will ruin your xenons. Your lcm is coded specifically to have them off with xenons because your ballasts need 12v power. Besides that what would be the point?
Nick_M3 is offline   Reply With Quote
Old 11-01-2012, 03:26 PM   #10
E46iT
i do not need your opinion on this as to what is the point of having my DRL to run at full power. if anyone knows a work around on how to have the DRL run at full power while xenon lights are on please share...
do not share your opinion or legality of this... my headlights are modified and running the DRL at full power does not effect the oncoming traffic.
Old 11-03-2012, 04:52 AM   #11
Nick_M3
My Ride: 2005 325ci
Woah calm down buddy I wasnt providing an opinion I was just asking why you wanted to do it in the first place. You didn't say in your original post that you wanted to run them at full power you asked if they could "be on at all times" I was just trying to warn you that running them would ruin your xenons however at full power that wouldn't be an issue.
now that you have made it more clear, I haven't seen a way in the coding system to do this and am not sure there is a program written to do it. So unless you can write software yourself to recode the computer then I think your pretty much outta luck.
Old 11-03-2012, 11:32 AM   #12
THECLEANERBEAMER
MR.CLEAN ;)
THECLEANERBEAMER's Avatar
My Ride: 2002 325i
At full power just turn your high beams on same thing since drl are just high beams at 20-30%
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 11-11-2012, 06:11 PM   #13
Gasman208
My Ride: 325 Xi, 128 coupe
I too would like to run the inner halogens (at full power) along with the bi-xenons when on high beam.
This would give better light penetration down the road, I find the xenons illuminate the road in front of the car
and landscape on either side well enough, but not enough light is focused straight ahead.
I can see a way to do this with relays, but re-programming the lighting controller might be easier.
Gasman208 is offline   Reply With Quote
Old 11-11-2012, 07:34 PM   #14
KaliVertBoy
My Ride: M3 Vert 6MT
I could've sworn I seen someone do this already, I may be wrong
KaliVertBoy is offline   Reply With Quote
Old 11-13-2012, 09:57 AM   #15
E46iT
i have bixenon
Old 11-13-2012, 10:08 AM   #16
THECLEANERBEAMER
MR.CLEAN ;)
My Ride: 2002 325i
I know I realized that after I stated that just to lazy to edit it lol.
Old 11-16-2012, 06:57 PM   #17
Noodle555
My Ride: M3 Cabriolet
This can be done by coding the car using software such as NCS Expert. However, I believe it will only allow for highbeam to come on at same time as xenon, not reduced power drls.
M3 Vert TiAG/Blk - with every option
Mods: Clear Bra | Tints | Hardwired Passport SRX | Painted Bumper Reflectors | Keyhole Cover | 6000k Predator Chromiums | 6000k Philips Ultinons | 6000k HID Fogs | Philips Silvervision Corners | OEM LED Tails | Trunk Lip Spoiler | Eisenmann Race | CSL Diffuser | CD/DVD Swap | Small Antenna | Blackout Grille and Gills | Smoked Corners
Mods ready to install: Paddle Upgrade | ZCP Rotors | CF Interior Trim
Noodle555 is offline   Reply With Quote
