Old 11-09-2012, 11:21 AM   #1
Gasman208
My Ride: 325 Xi, 128 coupe
xenon + Halogen Main beam
My 2004 325Xi has bi-xenon headlights, that is, the outer xenon lights are used for low beam and high beam. The inner halogen lights are used for "flash" and daylight running only. I propose to install changeover relays to enable xenon + halogen - (all four lights) for high beam.
anyone else tried this ?
Gasman208 is offline   Reply With Quote
Old 11-09-2012, 01:28 PM   #2
haurelio
My Ride: 2001 bmw 325i
this can be coded with ncs expert but it depends on your LCM module..
Contact me if you need your att iphone unlock. Also can code your car
Old 11-09-2012, 03:56 PM   #3
Gasman208
Interesting, Re-coding sounds better than re-wiring.
Is this ncs expert a BMW service department tool ?
Old 11-09-2012, 06:32 PM   #4
haurelio
not sure they have ncs expert; but they'll have similar software..
Old 11-11-2012, 02:08 PM   #5
Gasman208
I might still go with using relays instead of re-coding, it's a physical and easily reversible modification,
and could be switched so I could have 2 or 4 light high beams.
just need to find a wire that's hot only when high beam (bi-xenon) is on.
Old 11-11-2012, 09:19 PM   #6
Cyanide72
My Ride: 2002 325i
I believe you can do this with PASoft.
Cyanide72 is offline   Reply With Quote
Old 11-13-2012, 04:42 AM   #7
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Not with pasoft
Old 11-13-2012, 10:18 AM   #8
haurelio
as jake pointed out. it can be done with ncs or similar software..
Old 11-13-2012, 02:05 PM   #9
TerraPhantm
My Ride: 2005 M3 Coupe
If you really want to do it with wiring, just use the bixenon shutter's wire as the trigger. I do think coding is a better way to go about it. Get a $10 cable, download some software, and flip the bit.
Old 11-15-2012, 12:58 AM   #10
eneka
My Ride: 2003 325i
you make it sound so easy
though I have to say that I have a 64bit system which complicated things...and now I'm on windows 8 so I don't even have the virtual pc anymore haha. Need to find some time and reinstall everything..
eneka is offline   Reply With Quote
Old 11-18-2012, 08:53 AM   #11
Gasman208
Does anyone know which wire is the low/high beam shutter, the big connection in the middle is the halogen.
Name:	Xenon connections (1).jpg
