Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 11-13-2012, 12:30 AM   #13741
.DatBlackBM.
My Ride: 2003.5 M3 6spd
Originally Posted by sjacoby112 View Post
looks great. minor suggestion. cut the ends of your load bars (I did mine looks so much better/cleaner) and fix your fairing. looks like your inside 2 clips are in the wrong position, seems like it's bowed in and not out. could be the photo but idk just a suggestion. that's a sick winter set up
- Thanks a lot man, i'm really happy with the winter set-up as well. As for the fairing, yea i have to play around with it a little. How much did you cut your bars from each side? i was actually debating doing that before..
.DatBlackBM. is offline   Reply With Quote
Old 11-13-2012, 12:41 AM   #13742
CarbonFanatic
My Ride: 323I
Slap on some STP-3 rims with some brand spank'n new tires (= and slam the hell out of it
CarbonFanatic is offline   Reply With Quote
Old 11-13-2012, 12:44 AM   #13743
illestminimike
My Ride: Project Drama
Originally Posted by Nick_M3 View Post
I need to do this mine is stuck open 34 degrees today, no bueno
I hate when it takes forever to heat up in this cold. I'm tryna get the heater on but I'm just freezing my balls off. Much better now. But my dumbas$ friend didn't tighten the top hose all the way and the b1tch started leaking. Luckily it didn't overheat but I still slapped him across the face. By the end of the month I'll have my valves adjusted, new spark plugs and new valve cover gasket. Then I'll be done with the motor for now. Feels good.
Old 11-13-2012, 02:13 AM   #13744
sjacoby112
My Ride: 2002 325ci
i had an issue with my fairing where it was doing that when i first put it on, then realized the inner clips were supposed to be in a different position and it worked perfectly. as for the bars i cut mine so that the end cap is against the outside of the foot where the bar slides through it. looks a lot cleaner now that all the angles match.
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 11-13-2012, 02:37 AM   #13745
Gambitpaul
My Ride: 2006 330Ci E46
Did:
1. New spark plugs
Old Bosch on right. New NGK on left.
The Bosch ones had been on there since I bought the car at 50k miles, but probably before, now has 97,500. Bought on Amazon. FYI: do not use antiseize on these plugs, NGK has a tech bulletin.
2. Strut tower bar
ECS carbon fiber
Probably 15 minutes to install. Instantly tell the difference, whole car feels solid.
3. Sprint booster
Sport mode is perfect for quick, smooth heel/toe downshifts. Race mode turns the car into an animal!
Loving all three already
Gambitpaul is offline   Reply With Quote
Old 11-13-2012, 09:54 AM   #13746
morningisbad
My Ride: E46 M3 Vert
In the past week
Installed
-SuperSprint Race Muffler
-SuperSprint X-Pipe
-K&N Intake (haven't decided if I'm going to keep this yet)
-Goodyear Eagle F1 Asymmetric to the rears
Repaired
-RTABs replaced
-Inside wheel well (drivers front)
-Ambient temp sensor replaced
Updated
-120GB SSD in glovebox now wired to dynavin completely stealth
To come next spring (hopefully)
-SuperSprint Stepped Headers (anyone selling theirs? )
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 11-13-2012, 10:36 AM   #13747
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by morningisbad View Post
In the past week
Installed
-SuperSprint X-Pipe
Repaired
-RTABs replaced
Updated
How are you powering the SSD? Or does it even need external power?
Old 11-13-2012, 10:55 AM   #13748
Dan1el
My Ride: E46 320i '99
Send a message via MSN to Dan1el
Removed the old, nasty cabin air filter and installed a new one.
Replaced the old license plate lights with complete LED inserts.
Dan1el is offline   Reply With Quote
Old 11-13-2012, 12:09 PM   #13749
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 11-13-2012, 12:09 PM   #13750
HyeWarrior
My Ride: '03 325i --> '13 GTI
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 11-13-2012, 12:11 PM   #13751
trj
My Ride: 325Ci
Old 11-13-2012, 12:48 PM   #13752
morningisbad
Had to get an enclosure that allowed for a second power source. Then wired a USB port directly to the fuse box to power it.
Also had to modify some of the dynavin code to auto mount the hard drive by tricking it into thinking it's an SD card.
-Karl Welzein
Old 11-13-2012, 01:22 PM   #13753
WDE46
Nice. So you are a bit of a computer nerd too. Good to know.
Old 11-13-2012, 03:25 PM   #13754
illestminimike
My VCG and spark plugs come Friday. Hope to have my valve adjustment Monday. I have no clue the last time it was done.
Old 11-13-2012, 03:30 PM   #13755
RKiepper
My Ride: 1999 E46 328I x2
The 36F air outside gave me a new idea for the chrome trim.. Anyone ever consider frosted trim?
ID:	478025   Click image for larger version
RKiepper is offline   Reply With Quote
Old 11-13-2012, 03:32 PM   #13756
limpiabota809
My Ride: 330 XI
Ordered brake pad sensors and brake retaining bolts from pelican parts...brakes and rotors come Friday along with sensors hopefully get it done Saturday afternoon
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 11-13-2012, 04:02 PM   #13757
trj
My Ride: 325Ci
Ordered exhaust CPS, o-ring, bolt.
Extra: VANOS line washers, hose clamps for intake boots to reach the free shipping cap(no sense in spending $9 in shipping and receiving it the same day as free shipping does if I can just add $4 worth of stuff).
I
have a ton of extra o-rings, nuts, bolts, screws, clips, washers just because I am cheap and add them for free shipping when I reach near that amount. lol.
Now just praying that the CPS bolt is not stripped, because it felt like it was stripped by PO.
Old 11-13-2012, 04:03 PM   #13758
trj
My Ride: 325Ci
Damn, your door handles are frosted too
Old 11-13-2012, 04:03 PM   #13759
325inthe510
My Ride: 152ci of madness
Prepared my wallet and my anus for a slew of maintenance items
325inthe510 is offline   Reply With Quote
Old 11-13-2012, 05:11 PM   #13760
morningisbad
Haha, yes. However, I was happy to have a mod that I could actually DIY without instructions!
-Karl Welzein
Rate This Thread
