What size wheels do I need for 205/55/R16 snow tires for ZHP? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 11-13-2012, 03:23 PM   #1
Hassouni
My Ride: 05 ZHP coupe
So I bought a winter wheel/tire set from someone with a non ZHP E46 coupe - BBS wheels and Dunlop Pilot Winter Sport 3Ds. The tires are still great, but when I went to install the wheels, I found out they don't fit onto my ZHP hubs. What size wheels should I now be looking for?
Hassouni is offline   Reply With Quote
Old 11-13-2012, 06:31 PM   #2
Ballistic325
My Ride: slow and steady
They should fit if they are off an E46. No difference in hub size or PCD in the E46 range.
Even E36 wheels will fit....
Sent from my V9 using Bimmer App
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-13-2012, 09:08 PM   #3
2003 325i
My Ride: '03 Orient Blue 325i
16s on a 330, only a few select rims clear calipers. Hubs are not your problem. Easiest solution... 17s.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 11-13-2012, 09:21 PM   #4
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
BMW 16s will not fit over zhp/330 calipers
/_________\
O==[][]==O
Old 11-13-2012, 10:37 PM   #5
Hassouni
Thanks guys, I'm looking at some 17s now. What sort of offset can I work with? Stock is 50 rear, 47 front.
Old 11-13-2012, 11:14 PM   #6
2003 325i
Depends on width, assuming no more than 8" wide I'm sure 30-42ish would work. Can go higher and run spacers, don't want to go much lower especially in the front, fender clearance becomes an issue.
READ THREADS, BEEN COVERED A BILLION TIMES. Research dude.
Old 11-13-2012, 11:15 PM   #7
Hassouni
I've spent all afternoon researching, it's not very clear...
Old 11-14-2012, 07:32 AM   #8
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
That's because you can't determine brake clearance by looking at the wheel specs. The specs do not measure brake caliper clearance. Aftermarket sellers like us have to physically test fit the different styles of wheels to determine if they will actually fit.
We have a complete list of which wheels we sell that fit listed here :
Wheels http://www.tirerack.com/a.jsp?a=BN4&...eels/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
