Rating:
Display Modes |
#121 | |
www.starracer.us --------------------------------------------- People believe in Ghosts, UFOs, talking to the dead, advertising, magic, curses, voodoo dolls, Elvis' death faked, the Great Pumpkin, Tupac still lives, the WWF, that all the moon walks were staged, real unstaged audience questions in talk shows, JFK's conspiracy assination theories, TWA 800 shoot down conspiracy theories, the image of the Virgin Mary appearing on a left over pizza, that Dr. Laura has no bias, that homosexuality is a choice, the guests on Jerry Springer, the TV illness of the month, that guns don't hurt people do, that CNN doesn't hype stories, the Osbornes not being staged, that a pill can make you loose weight without ever dieting or excercising, that there's a cure for baldness, aging and being short, that Britney Spears doesn't lip sync, That KFC is a healthy food choice, that the British Royal family isn't disfunctional, that there really were weapons of mass destruction in Iraq, that all Arabs are the same, that Muslims encompass everyone from Indonesia to Morocco and they are all extremists, that all Americans are the same, that's it's always cold in Canada, that cigarettes aren't addictive, that it's ok to drink but not ok to smoke up.........and on and on and on and on...... so what on Earth makes anyone believe that there is something unusual about people fearing the number 13 or astrology? |
#122 |
Pic's very helpfull!
#123 |
#124 |
Great post/thread.
If you observe life from a creative perspective, everything is art
#125 |
My bad...
It was my windshield washer fluid tank leaking. It did this for a few days then stopped. Found the tank empty, filled it with water to see if that was it and Bingo!
![]() - E46 DIY Maintenance Thread - Mechanical Fan Delete - OBD2 UltraGauge - 2005 BMW 330CI ZHP - SPARKLING GRAPHITE METALLIC. ECS WP PULLEY - BEISAN VANOS & GAS DISA - SPRINT BOOSTER. CUSCO STRUT BRACE - BIMMIAN CELL MOUNT - USASPEC PA12. SMOKED LED MARKERS & REFLECTORS - LAMINX - INTERIOR LED'S. |
#126 |
My Ride: M3 & 323Ci (sold)
Oh good, didn't think it was diff leaking
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF |
#127 |
Thought i was leaking changed all of it! Except for the vanos hose. Prob should do that. But im instead burning oil, even more after replacing both Cats entire exhaust and o2 sensors.hate my life
#128 |
These cars have a huge crankcase, so if you are burning oil to the point of it noticably disappearing on the dipstick, then that's probably burning quite a bit. Enough that I would think you would see evidence of an oily tail pipe at the very least, maybe even see some blue smoke in the exhaust. How much oil are you losing?
#129 |
Yes sir. To all the above! Hoeever i changed the plugs twice in this past month and this last time i noticed they were sorta wet, one mechanic suggested i may be running rich. I unplugged maf, and it runs much better period. But I don't know if that will solve my oil burn.
#130 |
This plug was removed two weeks after replacing it. It looks dry there but it was moist previously.
#131 |
vcg leak
"so I just recently replaced my valve cover gasket because I was leaking oil. however it is still leaking. I usually have a lot of oil on top of my oil filter housing, do you think it is my oil filter gasket leaking? is there any other way to tell what the leaking is from. it is definitely the oil that is leaking as my oil is usually low."
**first time i did my vcg it leaked on other side down towards SAP and washer fluid, i torqued it down too much, u might wanna check your torques on the bolts, like 8lbs or thereabouts. Last edited by turnerk2; 11-13-2012 at 11:22 AM. Reason: forgot to include quote |
#132 | |
#133 |
#134 |
No RTV needed for that one, gasket alone is fine. I just did mine about 4-6 weeks ago and it was a bit of a job. The old gasket was so brittle and cracked that I couldn't get it out with the filter housing on, needed to remove the coolant hoses and take it out of the engine bay to get a good angle and good light to get it out. Prior to my fixing it, the oil was leaking about a quart every 2-3 weeks, which is pretty massive. Afterwards, I thought it was still leaking because I was still seeing oil. But in reality, there was so much oil all over everything down there, that it was old oil still dripping to the ground. After a few days of driving it cleared up completely and not a drop now. Overall, maybe 4-5 hours, nothing extremely difficult to get to, and well worth the time.
#135 | |
#136 |
#137 |
#138 |
Leak onto my floormat
anyone know why I would have fluid leaking onto my drivers side floor mat? I would guess it's brake/clutch fluid but do not know. I hope it's not the master cylinder? Could that get into the cabin ? I'd say it's leaking right below and between clutch and brake pedal. Thanks
#139 |
it may be clogged sunroof drains
#140 |
