DME Tuning - TUNERPRO - Page 6 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
Old 11-05-2012, 12:53 AM   #101
daniel_f.
My Ride: 330iC
whats your current software version? i translated the ****55 tunerstudio file to different software versions.
Old 11-12-2012, 10:54 PM   #102
TerraPhantm
My Ride: M3 & ZHP
I have been studying the MS45.1 tunes a little bit - mostly comparing ZHP and standard 330i software. I believe I've located the speed limiter and possibly the rev limiter.
Here are the binaries:
gone
I believe the speed limit is a 16-bit value stored at 5F44 (and repeats again at 5F46). I believe that this value equals speed * 0x7D.
On the 330i, the value at that location is 0x6480. 0x6480 / 0x7D = 0d205. 205km/h is just about 128mph.
The value for the ZHP at that location is 0x7A00, which ends up translating to 250kmh or ~155mph.
For RPM... from 60D4 to 6140 you have the following (ZHP and then 330i)
ZHP
Code:
1A 90 1A 90 1A 90 1A 90 1A 90 1A 90 1A 90 1A 90 1A 90
1A F4 1A F4 1A F4 1A F4 1A F4 15 04 15 04 15 04 15 04
1A F4 1A F4 1A F4 1A F4 1A F4 1A F4 1A F4 1A F4 1A F4
330i
Code:
19 78 19 78 19 78 19 78 19 78 19 78 19 78 19 78 19 78
19 78 19 DC 19 DC 19 DC 19 DC 19 DC 19 DC 19 DC 19 DC
1A90 = 6800
1978 = 6520
Seems to correspond to the RPMs. What I don't quite get are the values in the middle that don't quite match (bolded). 1AF4 and 19DC both correspond to the rev limits + 0x64. And then the ZHP has a couple values in the middle that are way low (1504 = 5380). Not really sure what to make of that. But I do believe that block of numbers has to do something with the rev limiter - the rest of the differences in the tune seem to be either checksums or maps. By and large the tunes are very similar. That block of RPMs is the largest block of differences.
Old 11-13-2012, 12:45 AM   #103
Hornung418
My Ride: '04 MB ZHP
Very cool, TP.
Hornung418 is offline   Reply With Quote
Old 11-13-2012, 04:09 AM   #104
GrafSpee
My Ride: e46 330xi
Is great what you have done.
As you have read the software?
Often the limiters are not in the clear there.
Example:
52000 = 6500 rpm (CB20)
52000 * 0.75 / 6 = 6500 rpm
greeting
Rene
GrafSpee is offline   Reply With Quote
Old 11-13-2012, 01:59 PM   #105
TerraPhantm
My Ride: M3 & ZHP
Example:
greeting
Rene
Well, there are a few more differences, but the changes seem too "random" to signify different rev limits.
btw: 3/4 * 1/6 = 1/8. 52000 / 8 = 6500
Old 11-13-2012, 05:44 PM   #106
GrafSpee
My Ride: e46 330xi
The calculation was an example of a specific control unit.
The ratio can vary as far as I've noticed that.
How did you read the file?
WinOLS the file can not assign the MS45.
greeting
Rene
Old 11-13-2012, 10:34 PM   #107
TerraPhantm
My Ride: M3 & ZHP
greeting
Rene
I converted the 0DA files from the Intel Hex format to a binary. I don't have the OLS277 module so I couldn't verify that all the bits are the same order as they would be in a ROM dump. All the data should be there however. If I could get access to someone else's dump, I could probably figure out how to fully convert the 0da files.
Old 11-14-2012, 02:36 AM   #108
GrafSpee
My Ride: e46 330xi
I wanted a try at GS20, because I can not read the Transmision.
I do not know how to correct for the *. ODA the checksum.
In WinKFP there is an option, because you can get the correct checksum.
Do not know if that works.
If you make an update with WinKFP, for example MS43 ....
From version 430037 to 430037, it only writes to memory. (4 minutes)
From version 430037 to 430066, then it writes memory and system. (25 minutes)
With the same version, only the memory is written.
I think.
greeting
Rene
Old 09-30-2013, 10:25 AM   #109
BMWinLinE6
My Ride: E46 sedan
Sorry to wake up an old thread.. have you folks figured out the rev limiter? Anybody successfully changed that block of value and flashed the module?
BMWinLinE6 is offline   Reply With Quote
Old 06-11-2014, 01:32 PM   #110
3.slow
My Ride: 2003 330Ci
This thread is disappointing at best
3.slow is offline   Reply With Quote
Old 09-27-2014, 11:17 AM   #111
JoeTe
My Ride: BMW 330CiA '04
And no one has a 330ci modified file (.bin)?
The .xdf file is great, but many do not know modify... lol
JoeTe is offline   Reply With Quote
Old 09-27-2014, 11:23 AM   #112
HakenTT
My Ride: 323i with S54
dejalo asi como es,
HakenTT is offline   Reply With Quote
Old 12-11-2014, 12:17 AM   #113
walopower
My Ride: BMW e39 525iA
Subscribed.
I have M54B25 and I will learn how to tune DME.
My current firmware is EU2, updated from US.
I have readed that EU2 binari already.
I also have Damos file for TunerPro.
Damos file is compatible with M54B30.
I have ordered spare DME for testing purposes.
Next step I will update EU3 software to that and then I will compare it to current EU2.
Maybe I will lean cold start map, I think it's very rich and engine run too smoothly with that. I drive short distances I hope that I save gasoline.
Maybe I will also rich hot engine map and adjust ignition to little more advance to getting power.
I am interested also for ethanol tune.
My car runs little lean (-7%), I try to drive with EU3 a while and compare how it will perform.
I think I will ending for EU3 tune, modified by EU2 pedal control map and maybe something else, let's see when I compared maps.
walopower is offline   Reply With Quote
Old 12-11-2014, 01:21 AM   #114
walopower
I like to know that too how to correct checksum for TunerPro edited binary file?
I have some tools, but they are for different BMW ECU's.
I have read that in same case at least, you can correct checksum by fill rest of file using zeros or something.
Maybe with WinOLS or TunerPro?
Old 12-11-2014, 01:34 AM   #115
daniel_f.
My Ride: 330iC
Just have a look at my threads in this section of the forum and youŽll find all you need
IŽm currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 12-11-2014, 02:17 AM   #116
walopower
I will!
I'll go back when I am wiser!
