Old 11-13-2012, 04:11 PM   #1
HBizzo88
My Ride: 2002 bmw 330ci
Crankshaft sensor Blown AGAIN!!!!
2002 330ci
So I don't know what to do. Maybe one of you have ran in to this problem. Car started running rough as all hell, yellow brake light came on along with the dcs light and check engine. So hooked up my peak tool and came up with a couple codes that are common when the crankshaft position sensor fails. So I changed that out, Car ran perfect.
Now after a couple weeks of driving, the lights are BACK on and is running rough, I assume because the timing is off due to the sensor.
I do not want to keep changing these things out. It's somewhat of a bi*ch. I just want to know what's causing the sensors to burn up.
The car does have an aftermarket turbo, and yea I do tend to get on it quite a bit.
Would just like to you guy's advise before i go to the garage and have to spend a heap of cash.
Thanks.
HBizzo88 is offline   Reply With Quote
Old 11-13-2012, 04:18 PM   #2
///MPR77
My Ride: 02 ///M3 Tri-Ped
Sorry to hear.
What are the new codes?
As I remember you replaced the intake cps...what about the exhaust side, has it been replaced too?
Old 11-13-2012, 04:26 PM   #3
HBizzo88
Code:
19
F4-crankshaft sensor
53-flywheel adaption segment timing faulty
I only changed the one on the rear right side of the engine (by the starter).
Old 11-13-2012, 04:28 PM   #4
HBizzo88
Originally Posted by ///MPR77 View Post
Sorry to hear.
Old 11-13-2012, 05:01 PM   #5
///MPR77
Originally Posted by HBizzo88 View Post
Code:
19
I don't know what those codes mean off hand. You already replaced the intake cps, so with some research hopefully you will find that one is the exhaust side which is easy to replace, you probably won't need the girlfriends skinny hands to replace it, but a telescoping mirror will help.
Old 11-13-2012, 05:04 PM   #6
xixixi
Banned User
My Ride: 01 330x-xi
Willing to help ya out man, I can send you out a new crank sensor. PM me.
Old 11-13-2012, 05:06 PM   #7
HBizzo88
Thanks man but i already have a lifetime warranty on this one.
Old 11-13-2012, 05:07 PM   #8
HBizzo88
Ok thanks! Ill do some research!
Old 11-14-2012, 07:07 AM   #9
SweTurbo
Big Pimpin'
My Ride: 323i -98
He replaced the crankshaft sensor, camshaft sensors would throw vanos codes
How was the mounting surfaces of the CPS/block ?
I knw that could cause problems if they're corroded.
Old 11-14-2012, 04:17 PM   #10
HBizzo88
I'm not sure. I don't know if you've ever replaced one before, but you can't really get a good look at the surface.
Old 11-14-2012, 07:16 PM   #11
///MPR77
Are crankshaft sensors and cam sensors not the same; my apologies if they are not.
Old 11-14-2012, 07:36 PM   #12
SweTurbo
Big Pimpin'
My Ride: 323i -98
I've only replaced the sensor with the block out of the car, but removing the intake isnt much work and it can save you alot of problems with issues like this.
They are not, they're both hall effect sensors but they are shaped differently as far as i can remember.
Old 11-14-2012, 08:17 PM   #13
mike@maximumpsi
My Ride: 02M3T
2002 330ci
Thanks.
What ecu/software are you using for your car?
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 11-14-2012, 10:45 PM   #14
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
The crankshaft sensor is a minor PIA to get in and out. I use a mirror. As with the camshaft sensors, aftermarket units are a crapshoot. My shop went through 2 aftermarket sensors until one finally worked (despite my insistence to use an OEM sensor).
Go OEM only on those 3 parts.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 11-26-2012, 04:39 PM   #15
HBizzo88
Ya I guess you're right. Took it to a shop. They said the same thing!
