Thread Tools Search this Thread Rating: Thread Rating: 648 votes, 4.95 average. Display Modes
Old 08-13-2012, 11:13 AM   #121
eksath
My Ride: 02 330ci TopazBlue
Originally Posted by 330ciandr6 View Post
Ok, I have decided to make a thread depicting all of the common oil leaks on the e46 (non m3). There are numerous threads on here asking where your oil leak is coming from so hopefully this will help. Best way to determine where an oil leak is if you can't tell from tracing the oil is to completely clean all of the oil off with brake clean or something similar and and wipe it down to where its completely clean.
This is very useful! Thanks for the detailed info!
www.starracer.us
People believe in Ghosts, UFOs, talking to the dead, advertising, magic, curses, voodoo dolls, Elvis' death faked, the Great Pumpkin, Tupac still lives, the WWF, that all the moon walks were staged, real unstaged audience questions in talk shows, JFK's conspiracy assination theories, TWA 800 shoot down conspiracy theories, the image of the Virgin Mary appearing on a left over pizza, that Dr. Laura has no bias, that homosexuality is a choice, the guests on Jerry Springer, the TV illness of the month, that guns don't hurt people do, that CNN doesn't hype stories, the Osbornes not being staged, that a pill can make you loose weight without ever dieting or excercising, that there's a cure for baldness, aging and being short, that Britney Spears doesn't lip sync, That KFC is a healthy food choice, that the British Royal family isn't disfunctional, that there really were weapons of mass destruction in Iraq, that all Arabs are the same, that Muslims encompass everyone from Indonesia to Morocco and they are all extremists, that all Americans are the same, that's it's always cold in Canada, that cigarettes aren't addictive, that it's ok to drink but not ok to smoke up.........and on and on and on and on...... so what on Earth makes anyone believe that there is something unusual about people fearing the number 13 or astrology?
eksath is offline   Reply With Quote
Old 08-13-2012, 12:05 PM   #122
Dollar-E46
My Ride: E46
Pic's very helpfull!
Dollar-E46 is offline   Reply With Quote
Old 08-13-2012, 12:47 PM   #123
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by Zell View Post
Sticky!!!
+1
OP, great write-up!
Old 08-27-2012, 12:16 PM   #124
323GSR
My Ride: E46CI
Great post/thread.
If you observe life from a creative perspective, everything is art
323GSR is offline   Reply With Quote
Old 10-26-2012, 05:39 PM   #125
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Originally Posted by Alex323Ci View Post
curious, did you ever figure it out??
My bad...
It was my windshield washer fluid tank leaking. It did this for a few days then stopped. Found the tank empty, filled it with water to see if that was it and Bingo!
Build Thread <:> S54 Vanos Thread
-TTFS Engine/SMG Tune- SGT Headers/Sect 1/SCZA- Evolve Eventuri- Sprint Booster V2-
-UltraGauge- Orion V4's- CF Lip/Console/Diffuser- VIS XTS CF Hood- LED Fogs- Valentine One- Turner 15F/12R Spacers-
WOLFN8TR is offline   Reply With Quote
Old 10-27-2012, 02:05 PM   #126
Alex323Ci
My Ride: M3 & 323Ci (sold)
Originally Posted by WOLFN8TR View Post
My bad...
Oh good, didn't think it was diff leaking
Old 11-07-2012, 07:51 PM   #127
Arod0690
My Ride: 2001 BMW 325ci
Thought i was leaking changed all of it! Except for the vanos hose. Prob should do that. But im instead burning oil, even more after replacing both Cats entire exhaust and o2 sensors.hate my life
Arod0690 is offline   Reply With Quote
Old 11-07-2012, 08:37 PM   #128
Itzed
My Ride: 2004 325xi
These cars have a huge crankcase, so if you are burning oil to the point of it noticably disappearing on the dipstick, then that's probably burning quite a bit. Enough that I would think you would see evidence of an oily tail pipe at the very least, maybe even see some blue smoke in the exhaust. How much oil are you losing?
Itzed is offline   Reply With Quote
Old 11-07-2012, 09:08 PM   #129
Arod0690
Yes sir. To all the above! Hoeever i changed the plugs twice in this past month and this last time i noticed they were sorta wet, one mechanic suggested i may be running rich. I unplugged maf, and it runs much better period. But I don't know if that will solve my oil burn.
Old 11-08-2012, 08:27 PM   #130
Arod0690
This plug was removed two weeks after replacing it. It looks dry there but it was moist previously.
Old 11-13-2012, 12:15 PM   #131
turnerk2
My Ride: 02 325i
vcg leak
"so I just recently replaced my valve cover gasket because I was leaking oil. however it is still leaking. I usually have a lot of oil on top of my oil filter housing, do you think it is my oil filter gasket leaking? is there any other way to tell what the leaking is from. it is definitely the oil that is leaking as my oil is usually low."
**first time i did my vcg it leaked on other side down towards SAP and washer fluid, i torqued it down too much, u might wanna check your torques on the bolts, like 8lbs or thereabouts.
turnerk2 is offline   Reply With Quote
Old 11-13-2012, 01:15 PM   #132
Mhnd
My Ride: 2004, 330XI
Check your oil filter housing gasket.
Mhnd is offline   Reply With Quote
Old 11-13-2012, 01:21 PM   #133
turnerk2
My Ride: 02 325i
yeah ima do that this coming week, it looks pretty nasy down there, not lookin fwd to tearing all the other stuff away to get to it.. if/when u did yours did u use rtv or gasket alone?
Old 11-13-2012, 05:08 PM   #134
Itzed
My Ride: 2004 325xi
No RTV needed for that one, gasket alone is fine. I just did mine about 4-6 weeks ago and it was a bit of a job. The old gasket was so brittle and cracked that I couldn't get it out with the filter housing on, needed to remove the coolant hoses and take it out of the engine bay to get a good angle and good light to get it out. Prior to my fixing it, the oil was leaking about a quart every 2-3 weeks, which is pretty massive. Afterwards, I thought it was still leaking because I was still seeing oil. But in reality, there was so much oil all over everything down there, that it was old oil still dripping to the ground. After a few days of driving it cleared up completely and not a drop now. Overall, maybe 4-5 hours, nothing extremely difficult to get to, and well worth the time.
Old 11-13-2012, 08:56 PM   #135
turnerk2
My Ride: 02 325i
hopin i have same results, crazy how much sludge is down in there
Old 11-14-2012, 02:03 PM   #136
Mhnd
I did mine about two weeks ago, no need for RTV only used Gasket.
Good luck!
Old 11-14-2012, 02:16 PM   #137
turnerk2
My Ride: 02 325i
Good luck!
thanks! do u reckon maybe 15lbs torque will be ok for the housing itself?
Old 11-15-2012, 11:28 AM   #138
damian12
My Ride: E46 M3
Leak onto my floormat
anyone know why I would have fluid leaking onto my drivers side floor mat? I would guess it's brake/clutch fluid but do not know. I hope it's not the master cylinder? Could that get into the cabin ? I'd say it's leaking right below and between clutch and brake pedal. Thanks
damian12 is offline   Reply With Quote
Old 11-15-2012, 12:28 PM   #139
scim459
My Ride: 14 328i, 05 325cic
it may be clogged sunroof drains
scim459 is offline   Reply With Quote
Old 11-15-2012, 01:56 PM   #140
damian12
My Ride: E46 M3
It's hitting my rubber floor mats and truly seems like a fluid vs. water. Water would dry up eventually and it hasn't rained in a while.
