WHY should you change your fuel filter? - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-13-2012, 11:10 AM   #61
trj
My Ride: 325Ci
Originally Posted by WDE46 View Post
Pull the fuse for the fuel pump when replacing either one and crank the engine to relieve pressure. You don't want electricity to be able to reach the pump while you have it over an open tank with gas fumes everywhere anyway. Some would even say you should remove the negative battery terminal.
+ dont smoke or let any one smoking come near you.
Old 11-13-2012, 11:12 AM   #62
WDE46
My Ride: '13 128i, '04 330Ci
I recommend wearing all wool clothing and rubbing your feet on carpet and rubbing ballons all over.
Old 11-13-2012, 12:27 PM   #63
FenderGuy05
My Ride: 2002 BMW 325i
A thread a month ago came up, fuel filter cut open. Pretty crazy stuff.
http://forum.e46fanatics.com/showthread.php?t=950552
FenderGuy05 is offline   Reply With Quote
Old 11-13-2012, 12:39 PM   #64
RayPooley
My Ride: 320i SE Coupe
Originally Posted by GSherbs View Post
If I were to do the fuel pump & fuel filter at the same time, does replacing the pump first relieve pressure on the line without having to do this trick with the fuse?
Or is it advised to relieve pressure on the line prior to replacing the pump as well?
-G
The point is to relieve pressure and minimize spillage. If, for example, you were to loosen a clip without any prior action to dissipate pressure the fuel will spray all over the place like an aerosol. It will go all over you as well as the bottom of the car. Apart from the obvious fire hazzard getting a gob, a lung or an eye full of petrol is a very serious and dangerous thing. Pulling the fuse, running the engine and letting the line run dry is the simplesst approach to draining the feed downstream of the pump.
Old 11-13-2012, 12:41 PM   #65
RayPooley
Thanks for that. Saves me doing it.
Old 11-13-2012, 05:43 PM   #66
Lusticles
My Ride: 325Ci
...and a couple of other reasons to change it:
I read here that one fanatic had a no-start issue because of an original fuel filter not being changed up to 130K miles.
Sounds like me. Or someone had the same problem as me.
But yes it just suddenly wouldn't start. I ended up buying a new filter from Tischer and I have noticed no performance problems whatsoever.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 11-14-2012, 03:29 PM   #67
My Ride: Lexus
Originally Posted by ChrisRedmon View Post
Says the guy who just shoved a $700 lighting setup down some guys throat a few threads back because thats what HE used, the man probably had a loose connection therefore had bulb firing problems. You didn't lone star find BMA parts homie, you may have stumbled across it and informed other fanatics.....
Like i said previously, smart guy. Really shitty superiority complex. More and more threads lately have turned into you arguing and trying to demonstrate your dominance. Which clearly has no leverage most of the time...
Nice try. More of my threads lately? Shows you're new to the forum. I've been like this for years. Nothing but the best advice.
BTW, I was not forcing $700 lighting setup down anyones throat. IIRC, that poster did a half-ass chinese HID conversion (as is on your car, admitted by yourself) which is downright ineffective, dangerous, and illegal. The best thing to do is leave it stock halogen or do a real conversion which costs real money.
Don't insult me just because you (self-admittedly by you) can't afford to properly modify your car.
Old 11-14-2012, 03:31 PM   #68
My Ride: Lexus
Originally Posted by ///MPR77 View Post
I'm with Mango.
Preventative Maintenance is definitely a way of life, its addictive, and a pleasure for me.
I get parts at resale, and the parts house gives me a tab that I settle monthly, If this weren't the case it would be much more difficult.
I realize that, not everyone can afford to go through their cars replacing everything, and there is no rule against diagnosing, isolating, and fixing just the problem, but when you have been around these cars long enough, you realize there are certain PM items that are non-negotiable, or that the only negotiation is to be left stranded, or at best waiting for a tow.
My commute is 1 mile round trip, and yet I put roughly 200 miles a week on my car in remote canyons, where cell reception, and civilization is non-existent. That being said I would be an idiot to roll the dice, and wait for problems to surface before fixing.
Does that make me immune from a breakdown? No, however my chances are greatly reduced, and the reward of getting to work on my own car is just a perk.
You can fix it cheap, but it wont be thorough, or You can fix it thorough, but it wont be cheap.
Your uniform is ready.
Old 11-14-2012, 03:45 PM   #69
ChrisRedmon
My Ride: 2002 PY ///M3
Illegal? My lights are just fine they are 5k in projectors. Nothing illegal about them. Nice try though. I cost effectively modify my car. Not because i cant spend 700 dollars on some light bulbs....but because its moronic. If you have money to waste. Sure! But as far as im concerned you are some internet nazi with a run of the mill base model 10 year old BMW. Congrats, you do indeed give good advice. But the moment anyone goes against the grain of your advice you get butt hurt. Grow up man.
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 11-14-2012, 04:01 PM   #70
My Ride: Lexus
Apparently, you've never heard of the Department of Transportation.
Your $20 DDM HID KIT CONVERSION whatever the heck you did is cheap, dangerous, stupid, all of the above. You are trying to force your bad and cheap habits on people.
It's not about being hurt or going against my advice, it's about people (like you) giving false, fraudulent, or dangerous information.
Not happening. I'll catch it.
Stay stock halogen or go full proper OE quality HID.
PERIOD.
NO DDM
NO KHOALTY
NO GENERIC
when it comes to lighting, especially.
Enjoy your $20 special
Old 11-14-2012, 04:16 PM   #71
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
I have had a new fuel filter rolling around in my trunk for a couple of days now. Think I will change it tomorrow.
Encryption76 is offline   Reply With Quote
Old 11-14-2012, 05:28 PM   #72
WDE46
Mango chill. You should probably be a little more open minded and stop getting offended when people don't like your attitude. If his headlights are adjusted properly and they don't catch the car on fire, then there is no problem.
Old 11-14-2012, 05:54 PM   #73
ChrisRedmon
PERIOD.
NO DDM
NO KHOALTY
NO GENERIC
Wow....just. Wow.
Internet policia take their job to serious.
Old 11-14-2012, 05:55 PM   #74
tock172
My Ride: '12 135i Dinan S2
I suggest you refrain from giving others advice regarding their maturity when you clearly haven't any yourself. Remember when you previously insulted me for having 130,000 miles on my e46? Or has your memory not fully developed yet?
You're a joke
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 11-14-2012, 05:59 PM   #75
ChrisRedmon
You're a joke
You and mango should change each others fuel filter. Probably about 20 times in a row. Just to make sure its properly maintained. You know?
Old 11-14-2012, 06:01 PM   #76
tock172
My fuel filter is still within it's generally accepted service life.
Old 11-14-2012, 06:01 PM   #77
ChrisRedmon
Lulz. They were had
Old 11-14-2012, 06:14 PM   #78
My Ride: Lexus
Wow....just. Wow.
I like how I do things the proper way and guys like this come around all angry, jealous, and upset.
You bought such a nice car, M3. But insist on installing poor quality stuff on it? Important stuff such as lighting??
Poor cars! poor public!
DDM/generic HID bulbs= poorer quality, low-cost copies of the real thing. Bulbs that burn hotter, have a small fraction of the life, and display inconsistent and other wise poorer pattern, color, and projection than a quality OE/OEM bulb pair that would have only cost $80 more than the copies so proudly purchased.
It only costs a little more to do it the safe way!
Old 11-14-2012, 06:15 PM   #79
My Ride: Lexus
Oh and if i'm not mistaken, the chinese HID bulbs tend not to filter out damaging ultraviolet light that can yellow your housings. just saying!
Old 11-14-2012, 06:20 PM   #80
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
This thread is full of LOLz
I will second the Cold-start issues contributed to a bad fuel filter/regulator. At around 54k miles I had cold start problems. It would start, die, then I'd restart it and it'd be cool. After replacing the filter, problem has been solved and never returned. I'm @ 107k now.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
