#61 | |
#62 |
Weagle Weagle
#63 |
A thread a month ago came up, fuel filter cut open. Pretty crazy stuff.
http://forum.e46fanatics.com/showthread.php?t=950552
#64 |
The point is to relieve pressure and minimize spillage. If, for example, you were to loosen a clip without any prior action to dissipate pressure the fuel will spray all over the place like an aerosol. It will go all over you as well as the bottom of the car. Apart from the obvious fire hazzard getting a gob, a lung or an eye full of petrol is a very serious and dangerous thing. Pulling the fuse, running the engine and letting the line run dry is the simplesst approach to draining the feed downstream of the pump.
#65 | |
#66 | |
But yes it just suddenly wouldn't start. I ended up buying a new filter from Tischer and I have noticed no performance problems whatsoever.
number one Audi Fan
#67 | |
Platinum Plus Quality
BTW, I was not forcing $700 lighting setup down anyones throat. IIRC, that poster did a half-ass chinese HID conversion (as is on your car, admitted by yourself) which is downright ineffective, dangerous, and illegal. The best thing to do is leave it stock halogen or do a real conversion which costs real money. Don't insult me just because you (self-admittedly by you) can't afford to properly modify your car.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#68 | |
Your uniform is ready.
#69 | |
#70 | |
Your $20 DDM HID KIT CONVERSION whatever the heck you did is cheap, dangerous, stupid, all of the above. You are trying to force your bad and cheap habits on people. It's not about being hurt or going against my advice, it's about people (like you) giving false, fraudulent, or dangerous information. Not happening. I'll catch it. Stay stock halogen or go full proper OE quality HID. PERIOD. NO DDM NO KHOALTY NO GENERIC when it comes to lighting, especially. Enjoy your $20 special
#71 |
I have had a new fuel filter rolling around in my trunk for a couple of days now. Think I will change it tomorrow.
#72 |
Weagle Weagle
Mango chill. You should probably be a little more open minded and stop getting offended when people don't like your attitude. If his headlights are adjusted properly and they don't catch the car on fire, then there is no problem.
#73 | |
Wow....just. Wow. Internet policia take their job to serious. |
#74 | |
100% star stuff
You're a joke
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#75 | |
#76 |
100% star stuff
My fuel filter is still within it's generally accepted service life.
#77 |
Lulz. They were had
#78 | |
You bought such a nice car, M3. But insist on installing poor quality stuff on it? Important stuff such as lighting?? ![]() Poor cars! poor public! ![]() DDM/generic HID bulbs= poorer quality, low-cost copies of the real thing. Bulbs that burn hotter, have a small fraction of the life, and display inconsistent and other wise poorer pattern, color, and projection than a quality OE/OEM bulb pair that would have only cost $80 more than the copies so proudly purchased. It only costs a little more to do it the safe way!
#79 |
Oh and if i'm not mistaken, the chinese HID bulbs tend not to filter out damaging ultraviolet light that can yellow your housings. just saying!
#80 |
This thread is full of LOLz
I will second the Cold-start issues contributed to a bad fuel filter/regulator. At around 54k miles I had cold start problems. It would start, die, then I'd restart it and it'd be cool. After replacing the filter, problem has been solved and never returned. I'm @ 107k now.
- 2002 Steel Blue 325Ci -
