Australia
Old 03-22-2010, 09:56 PM   #41
Gee Emm
My Ride: 2000 325Ci Auto :(
I run 36psi all 'round on my 18's
Gee Emm is offline   Reply With Quote
Old 03-23-2010, 08:56 AM   #42
JohnMate
My Ride: What work gives me!
running the diff through the back seat and 0 in the left rear.... I miss my car
JohnMate is offline   Reply With Quote
Old 11-13-2012, 07:41 AM   #43
wc325i
My Ride: stick 330
reviving thread....
What tyre pressure should i run on oem 18" m3 wheels?
wc325i is offline   Reply With Quote
Old 11-14-2012, 12:31 AM   #44
forzamilan10
My Ride: '04 325Ci Sport
I usually run 40 all around on 19" cheap nasty ATR Sport tyres...
'04 325Ci + MYSTIC BLUE + EISENMANN RACE EXHAUST & MID-PIPE
forzamilan10 is offline   Reply With Quote
Old 11-14-2012, 12:53 AM   #45
steve.k
My Ride: 05' 325Ci, 13' WRX
^same!... Twins!
steve.k is offline   Reply With Quote
Old 11-14-2012, 12:30 PM   #46
johnca
Modded ///Member
johnca's Avatar
My Ride: E46 Slow CSL
38 all round for me..
johnca is offline   Reply With Quote
Old 11-14-2012, 03:26 PM   #47
Brissyjohn
My Ride: 2007 MX-5
What the tyre placard shows. 220 kpa front 260 kpa rear or 260 kpa front and 310 kpa rear depending on load and conditions. I mostly use the high pressures
Brissyjohn is offline   Reply With Quote
Old 11-14-2012, 06:00 PM   #48
N4NOOK
My Ride: 323ci
48f/46r
N4NOOK is offline   Reply With Quote
Old 11-14-2012, 06:04 PM   #49
Hazey82
My Ride: M3
place card says 33f 35r I run 36 all round
Hazey82 is offline   Reply With Quote
Old 11-14-2012, 06:12 PM   #50
zabalzae
My Ride: 01 330ci
36 all around
zabalzae is offline   Reply With Quote
Old 11-14-2012, 06:41 PM   #51
Chewy
My Ride: '03 LSB M3 Vert SMG
40 all round
Chewy is offline   Reply With Quote
Old 11-14-2012, 07:50 PM   #52
Worx
Euro tuner
My Ride: BMW
I run 8PSI most of them time.
Worx is offline   Reply With Quote
Old 11-14-2012, 08:14 PM   #53
DamoBMW
My Ride: '02 325Ci M-Sport
260kpa front, 305kpa rear (psi is about 38 and 44)
It's between minimum and maximum on the placard for my tyres.
'02 BMW 325Ci 5MT M-Sport Individual Stratus Grey
DamoBMW is offline   Reply With Quote
Old 11-14-2012, 08:15 PM   #54
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
35rr 33 fr on 18s
Bemwe_03i is offline   Reply With Quote
Old 11-14-2012, 11:47 PM   #55
trive2
My Ride: 1989 BMW 535i
38 front, 42 rear.
Car understeers so I like the extra bite in the front, plus its good for fuel economy.
trive2 is offline   Reply With Quote
Old 11-15-2012, 12:08 AM   #56
steve.k
All up 160Psi
Old 11-15-2012, 02:01 AM   #57
Mitch E46
My Ride: M3 Convertible
Usually 38 Psi all round on 19x8.5 square set up. Although I've been trying out 40 Psi all round and I'm liking it.
Mitch E46 is offline   Reply With Quote
Old 11-15-2012, 02:36 AM   #58
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Originally Posted by YGOAMG View Post
TAAXED - i was under the impression that less pressure = more grip..
It's all a balancing act. You want the tires to have enough air to always have the contact patch on the pavement. Anything less than 40 psi cold in my car will cause the tires to roll slightly.
Too much is a bad thing and too little is a bad thing. This goes with tire pressure, suspension softness, alignment, etc... It's all a crazy balancing act
Keep in mind this stuff really isn't relevant in street driving
Old 11-15-2012, 03:20 AM   #59
DamoBMW
^ What air pressures do you use in your watermelons?
Old 11-15-2012, 04:44 AM   #60
mkodama
mkodama's Avatar
On a mountain bike or rock crawling truck, yes. Not the case with an E46. Less pressure does guarantee more rolling resistance though.
