E46 Xi Forum
Old 11-14-2012, 10:55 PM   #1
Iggy27
My Ride: 2003 330xi
Headlight washers aren't working? Any ideas why?
I bought my 2003 330xi. I never has a reason to use my headlight washers. But since winter is coming I wanted to test them out and see how I like them. But they won't turn on. Any main causes why they won't work?
Iggy27 is offline   Reply With Quote
Old 11-15-2012, 01:11 AM   #2
cityjohn
My Ride: 2001 M3
Disuse could be one reason. They have a separate pump which may have gone years without being activated. Also, they can only be switched on when your wipers and headlights are on, and even then it's every 10th pull of the stalk.
cityjohn is offline   Reply With Quote
Old 11-15-2012, 01:44 AM   #3
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
^^^ +1. Very likely the washer pump. Very easy and cheap DIY job.
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 11-15-2012, 02:07 AM   #4
Iggy27
My Ride: 2003 330xi
The pump is the one on the front top side of the windshield fluid tank right?
Old 11-15-2012, 07:49 AM   #5
jeepo23
My Ride: 2008 X3, 6 Speed
They come on every 6th time with your windshield wipers.
The pump is the one that is closer to the front end of the car at the washer bottle.
Easy way to test if its the pump. Have someone activate the washer and listen if you can hear the pump running. If the pump doesn't run its dead, if you can hear the pump what might of happened is the actual gear inside has failed not providing enough pressure to pop the headlight washers out.
I just had mine replaced earlier this year. I even managed to find a pump on ebay for $12 compared to what everyone else charges for these of $40+..
Ill find the link to my old post where it had a bunch of troubleshooting steps.
jeepo23 is offline   Reply With Quote
Old 11-15-2012, 09:55 AM   #6
SamDoe1
My Ride: 4cyl of fury
You're not missing out on anything by having it broken. All the headlight washers do is make a huge mess and run through washer fluid like a drunk on Saturday night.
Other people are right though, get a cheap pump and swap it out. Mine stays disconnected 100% of the time to prevent it from running.
Old 11-15-2012, 10:10 AM   #7
Iggy27
My Ride: 2003 330xi
Like during the winter I think it would be nice to have them. During the summer I would unplug them. And I never heard the pump click on at all. I think my pump is dead.
Old 11-15-2012, 10:24 AM   #8
jeepo23
Here is the headlight pump troubleshooting.
http://forum.e46fanatics.com/showthr...dlight+washers
Cheapest I found by quickly doing part number search is $18 on ebay.
http://www.ebay.com/sch/i.html?_sop=...8377430&_rdc=1
Reason I was able to find one for $12 was because I searched an old headlight washer pump part number and it came up and was swap.
Old 11-15-2012, 10:35 AM   #9
Iggy27
My Ride: 2003 330xi
Yea sounds like I need to change my pump first and are if that's the problem.
Old 11-15-2012, 10:58 AM   #10
SamDoe1
I drive around all the time in one of the worst winters in the US. Trust me, the headlight washers do jack squat.
Old 11-15-2012, 03:23 PM   #11
stingray71
My Ride: 2005 325xi
Have you checked the fuse? It is possible that it was removed by the previous owner trying to avoid the typical problems.
stingray71 is offline   Reply With Quote
Old 11-15-2012, 04:51 PM   #12
Kubica
My Ride: 2003 325xi
Do they use liquid magnesium chloride on the roads in MN? That stuff does cake on to the headlights pretty good.
Old 11-15-2012, 05:02 PM   #13
Iggy27
My Ride: 2003 330xi
Yea the fuse is still it. Just nothing is workin or clicking
Old 11-15-2012, 05:07 PM   #14
jeepo23
Wonder of the option was disabled by code. I could be a possibility
** Removed **
Old 11-15-2012, 05:33 PM   #15
Iggy27
My Ride: 2003 330xi
I think the pump it burned out I tried to buy one today but it was way too much for a used one. Ill have to get one online
Old 11-15-2012, 06:51 PM   #16
SamDoe1
FWIW I bought mine from Pelican parts. I got the cheapest one and it was like $15 for a brand new part.
Old 11-15-2012, 07:15 PM   #17
E46er75
My Ride: 323i Vert, 330xi
I'm surprised that anybody even uses the washers. I had them on my Audi and really couldn't understand why anyone would want this option. Just like headlight wipers on a Volvo, it just doesn't make sense. I wouldn't even waste my time fixing these unless you actually use them. But hey, that's just me...
E46er75 is offline   Reply With Quote
Old 11-15-2012, 07:30 PM   #18
jizzzoe
My Ride: is no longer E46 :(
Send a message via Yahoo to jizzzoe
sub'd
My Steel Gray '03 330Ci... I miss you, baby!
MODS: Purely aesthetic… Shadowlined, Smoked and LED'd out!
jizzzoe is offline   Reply With Quote
