Old 11-15-2012, 10:51 AM   #1
KADL7124
My Ride: 1999 323i
Lighting
I have a 99 e46 323i and from time to time the little indicator in the dash instrument cluster will show a tail light is out and then either turn off or require me to disconnect the tail light cluster and it will resolve that way.
Also my turn signal will flash quickly and then at a normal pace. This will happen either with the dash indicator or not.
Anyone have experience with this.
KADL7124 is offline   Reply With Quote
Old 11-15-2012, 02:08 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Check the wire harness going to the tail lights. Most likely the area by one of the pins is melted.
Old 11-15-2012, 02:43 PM   #3
haurelio
My Ride: 2001 bmw 325i
there's a fix on this about the ground melting as jake pointed out.. Just search for the diy
Contact me if you need to unlock your phone.
Also can code your car
