Old 11-11-2012, 04:27 PM   #1
thefrog1394
My Ride: e46- 1999 323i
Steering Rack Boot Replacement
Under the car to replace the alternator and I saw both my steering rack boots are completely torn . Hope no damage has been done to the rack.
Anyways, the boot on there now appears to be non-OEM (not that). Since they are so expensive, I would not be opposed to putting something similar to the one I have on there now on again. Anyone know where I could get a cheap non-oem boot that would work?
Also, has ANYONE successfully separated the inner and outer tie rods or do I basically have to plan on replacing these as well? I replaced them about 50k miles ago so they aren't really due...
Photo in Cleveland, Ohio
1999 323i - Totaled at 265,000 miles.
Now an e30 & e90 owner.
thefrog1394 is offline   Reply With Quote
Old 11-11-2012, 04:30 PM   #2
thefrog1394
ID:	477740 that's what my current one looks like. Really shouldn't have cheaped out and reused it when I replaced my tie rods.
Old 11-11-2012, 05:40 PM   #3
thefrog1394
Answered my own question. Looks like it is an updated design that allows the boot to be slipped on without separating the inner and outer tie rod. Awesome! http://forum.e46fanatics.com/showthr...ring+rack+boot
Old 11-12-2012, 12:17 PM   #4
thefrog1394
Posted this in the other thread, but:
Bumping an old thread, sorry. Anyone know if this boot will fit over the steering rack nut side of the inner tie rod instead of going over the outer tie rod? I know last time I removed my tie rods I couldn't get the outer side out without destroying them. The steering rack side was far easier.
Old 11-12-2012, 12:32 PM   #5
WDE46
My Ride: 2004 330Ci OBM
Yeah, the new ones that I had purchased seem like they will fit over the 34mm nut on the steering rack side. They have a little rubber circle that fills the in gap created by the large diameter boot as shown in your picture.
Old 11-12-2012, 12:53 PM   #6
thefrog1394
Post
Ok, thanks. I will probably try that first then and report back. If anyone else has actually tested this and can report in before I receive the part that would be great.
Old 11-12-2012, 12:55 PM   #7
Zell
Zell's Avatar
My Ride: so turbo wow
4:08 shows exactly how to do this
Old 11-12-2012, 01:05 PM   #8
WDE46
I can when I get home. I have new tierods and boots in my living room right now.
Old 11-12-2012, 07:05 PM   #9
thefrog1394
Just watched Zell's video, confirms it does! So don't worry about it. Thanks for the offer though!
Old 11-15-2012, 07:23 PM   #10
thefrog1394
I just got the part and the o-ring thing has no slit in it, so I would have to take the tie rod apart to get that on anyways. Anyone have any luck cutting a slit in it or do you think that would just leak? Really really dont want to have to separate the tie rods, I have a good feeling it will end in me buying new ones. And also not in the mood to get an alignment.
Old 11-15-2012, 07:25 PM   #11
Zell
Zell's Avatar
You can probably safely cut a slit into it if you want to
Old 11-15-2012, 07:43 PM   #12
thefrog1394
Yea I'm probably going to try it and maybe put some heavy duty glue or gasket maker or something to seal it up if I have some lying around.
Old 11-15-2012, 07:49 PM   #13
WDE46
If you cut it like this it will self seal. It will probably be hard to do this though.
Old 11-15-2012, 07:56 PM   #14
thefrog1394
Did yours come cut like that?
Old 11-15-2012, 08:51 PM   #15
stevodotorg
My Ride: 02 325i - Manual
do an ebay search for Z3 steering boots (they use the same boots), there is someone on there selling them quite cheap, need to get some soon myself
Thanks to all e46fanatics and other BMW forum users, without the community, our wallets would be more empty than they already are.
I do ECU Coding, contact me.
stevodotorg is offline   Reply With Quote
Old 11-15-2012, 11:09 PM   #16
WDE46
Yes. That is a photo of mine straight out of the bag.
