Old 11-15-2012, 08:14 PM   #1
jM2.me
My Ride: BMW
Some issues with trunk
So started up a car today for a drive. Noticed trunk wouldn't open with key, inside button or trunk button.
Opened it with the key and then closed. Tried again to open with key, trunk button and interior button. Bam! Worked just fine.
After 10 minutes (or engine off and on) whole thing re-occurs.
General electronics module?
jM2.me is offline   Reply With Quote
Old 11-15-2012, 08:27 PM   #2
jfoj
My Ride: '06 330CiC, '03 M5
Originally Posted by jM2.me View Post
So started up a car today for a drive. Noticed trunk wouldn't open with key(DID YOU MEAN KEY OR KEYFOB??, inside button or trunk button.
Might be in Valet Mode?? and remember that the trunk will not open from the outside trunk button unless all doors are unlocked.
Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619
Lower hose fan switch O-ring - BMW #13621743299
Old 11-15-2012, 08:42 PM   #3
FastHackem
My Ride: 2002 330i
Check for broken or almost broken wires in the wire harness between the trunk lid and trunk. Very common problem.
Sent from my Nexus S 4G using Bimmer App
The Mind Is A Terrible Thing.
2004 Cayenne S
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 11-15-2012, 08:50 PM   #4
Stinger9
My Ride: '04 330Ci
+1
And fix is to splice new section of wire into the line as harness is prohibitive and impossible to install. Not literally.
DIY's have been written.
Old 11-15-2012, 08:59 PM   #5
jM2.me
My Ride: BMW
Had no idea what Valet Mode is until googled it. Turns out that's not it.
Going to check wire harness between the trunk lid and trunk tomorrow
Old 11-15-2012, 09:02 PM   #6
Stinger9
My Ride: '04 330Ci
Intermittent electrical problems are the most difficult to find.
