Sponsored by BimmerWorld
Old 09-24-2012, 07:01 PM   #1
always-there
My Ride: 2002 BMW 330I
Struts
I was online at bmaparts attempting to price the strut mounts which I found for $33, but I can't find the shock mounts? Are there no shock mounts for the front? Only rear?
Old 09-24-2012, 07:04 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Strut mounts are equivalent to rear shock mounts. They have bearings in them that allow the mount to twist and such.
Old 11-15-2012, 12:48 PM   #3
always-there
The parts came in from bma. I ordered Bilstein struts and meyle strut mounts; anything else I need? I don't know if I should buy the rubber boots?
Old 11-15-2012, 12:56 PM   #4
Zell
Zell's Avatar
I'd get a new rubber boot since it's gonna be off anyway.
Old 11-15-2012, 12:58 PM   #5
always-there
So that's all I need ? What about bump stops?
Old 11-15-2012, 01:01 PM   #6
Zell
Zell's Avatar
Sorry I forgot you were doing struts as well.
Are you getting Bilstein HDs? If so, no bump stop or boot required. Boot is supplied.
Old 11-15-2012, 01:03 PM   #7
My Ride: Lexus
I would recommend against Meyle mounts. The bolts are too short so you won't be able to mount a brace.
Old 11-15-2012, 01:03 PM   #8
My Ride: Lexus
Bilstein struts have internal bump stops.
Old 11-15-2012, 01:03 PM   #9
always-there
I bought the Bilstein touring class struts and meyle mounts. I thought that's all I needed but I see I need more things ? Don't wanna' be stuck halfway through the job. Any help is appreciated!
Old 11-15-2012, 01:07 PM   #10
My Ride: Lexus
See sig, second link. Scroll to bonus.
Old 11-15-2012, 01:08 PM   #11
always-there
Dang it, I had in mind to install braces in soon after I fixed this. I already bought the mounts..
Old 11-15-2012, 01:08 PM   #12
always-there
Thanks!
Old 11-15-2012, 10:18 PM   #13
always-there
$30 at Autozoneee, can't beat that. It's even better than the $50 versions.
Old 11-22-2012, 07:59 AM   #14
always-there
I just replaced the struts and I completely hate them! The ride height is waay too high! They are bilstein Touring's...I officially hate Bimmers; waay too much effing plastic.
Old 11-22-2012, 08:16 AM   #15
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Your ride height should not have changed. You did something wrong
Old 11-22-2012, 01:43 PM   #16
always-there
The new strut has more travel the the Sachs
Old 11-22-2012, 01:46 PM   #17
always-there
Anyone here use the same brand ???
Old 11-22-2012, 01:58 PM   #18
ryannel2003
My Ride: '04 Cadillac Deville
I read in another thread about this happening with the Bilstein Touring's. I was going to put the same set-up on my 323, but I'm going to go with the Koni's instead.
http://forum.e46fanatics.com/showthread.php?t=916794
It's common with the Bilstein's. I'm gonna have to stick with them because with everything I need, my budget doesn't allow for Koni. I don't mind a little bit of a bigger gap so I'll let you know how my car turns out.
ryannel2003 is offline   Reply With Quote
Old 11-22-2012, 07:46 PM   #19
always-there
They're not bad, It's just that I hate the huge wheel gap. I stayed up all night outside replacing the struts, mounts, end links, front tires, expansion tank and what not. I'm so freaking tired and just having second thoughts about having a Bimmer..it needs too much. Other than that I just found out my lcab's are gone so I just placed an order. I swear this car is nothing but a wallet beheader. To cure the huge wheel gap I'm going to purchase lowering springs. I know it's not the best idea but I don't have 2-3k to spend on a full suspension lowering kit. Bash or flame me if you want.
Old 11-22-2012, 07:47 PM   #20
always-there
I'll take a pic if you want to see the results.
