BMW E46 3-Series DIY: Valve Cover Gasket Replacement - Page 9 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 87 votes, 5.00 average. Display Modes
Old 11-15-2012, 09:36 PM   #161
farukh
My Ride: BMW 325i 2002
Originally Posted by edbubuli View Post
BMW in N.J is quoting me for the VCG for $600.00!!!! I'll try to check Bimmer Clinic near Avanel...
Not surprised! Why not DIY?
farukh is offline   Reply With Quote
Old 11-16-2012, 03:02 PM   #162
edbubuli
My Ride: 325i
Yeah...probably you're right...I just don't want to mess up when it
comes to the engine...
edbubuli is offline   Reply With Quote
Old 11-16-2012, 03:04 PM   #163
Rickna
My Ride: '01 330xi - '09 IS-F
Just follow the DIY carefully, ask questions if you have to-you'll be ok.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 11-16-2012, 03:05 PM   #164
edbubuli
My Ride: 325i
Okay Thanks! I'll do that...
Old 11-16-2012, 03:15 PM   #165
farukh
Yea! And make sure you have a torque wrench... Don't make my mistake (I actually made it 3 times in a row)
Old 11-21-2012, 05:21 AM   #166
ncord
My Ride: 06 BMW X3
Did you have any oil up the sides of your plugs?I have it on one plug ,and will replace seals today.
ncord is offline   Reply With Quote
Old 11-22-2012, 08:30 PM   #167
klikster
My Ride: 325xi
Round two tomorrow. Hopefully the cover pops off this time...
klikster is offline   Reply With Quote
Old 12-08-2012, 04:44 PM   #168
Amoeba
Amoeba's Avatar
My Ride: his: zhp hers: 325ci
Send a message via Yahoo to Amoeba
Can't get the cover off for the life of me. It's stuck on there like glue. Any suggestions?
Amoeba is offline   Reply With Quote
Old 12-08-2012, 04:59 PM   #169
lowesdown
My Ride: 2003 325i Wagon
I was very delicate with a flathead screwdriver around the whole thing.
lowesdown is offline   Reply With Quote
Old 12-08-2012, 05:08 PM   #170
Nyl777
My Ride: 2004 325xi
Maybe it will help if you assemble it back then start the engine and warm it up for a few minutes then disassemble it again. Just a thought.
Nyl777 is offline   Reply With Quote
Old 12-08-2012, 05:19 PM   #171
farukh
My question might sound stupid, but did you remove all the screws/bolts?
Is it your first VCG replacement? Anyone did it before? Maybe they used the RTV? In that case, a flathead screwdriver will help.
Old 12-08-2012, 05:20 PM   #172
lowesdown
Because the rubber gets brittle it you can free it near the oil fill hole and use that as your pull poin.
Old 12-08-2012, 08:31 PM   #173
trj
My Ride: 325Ci
+1 on both
Warm up the engine a little to make the rubber pliable.
Make sure you have all 15 capnuts out. Lift the VC straight up.
And use a small flat head slowly on the VC end, not the engine block end. You can easily replace the VC if scratched but the block is a whole different story.
Old 12-08-2012, 08:41 PM   #174
Amoeba
Amoeba's Avatar
After heating with hair dryer, I had to use a screw driver to slowly pry it up near the vacuum hose. After that Ianaged to get it off.
There were some minor superficial scratches on the block. Hope that's still okay.
Now I just have to get this friggin strut tower bar off.
Old 12-31-2012, 06:49 PM   #175
quiklilrex
My Ride: '02 330xi
Doing mine right now, and damn it was over due. Oil in all spark plugs took an hour to get the broken pieces of gasket out of the valve train. I do need help with one thing though. There is a strange whitish grease in the valve cover. It is also on the bottom of the oil cap. Here are a couple pics I took.
Anyone know what this is??
quiklilrex is offline   Reply With Quote
Old 01-01-2013, 12:46 AM   #176
Nyl777
My Ride: 2004 325xi
That could be the result of a moisture build up from the condensation of the oil from the engine since you have a leak or assuming you have one due to an old valve cover gasket. Heat builds up inside the engine when car is running or engine is idling then if there is a leak cold air outside gets inside your engine especially in your case (Minnesota, as what your profile states). Heat meets cold equals oil turning into a milky white stuff. Changing the VCG should address this issue.
Old 01-01-2013, 05:49 AM   #177
oc330cic
My Ride: 2002 330 CiC
Moisture - possibly coolant?
Definitely moisture contamination. Has that classic "cappacino" look. Hopefully, the other poster is right and it's from the leaky valve cover gasket. A more ominous possibility is engine coolant from something like a cracked head.
Clean all that stuff off, change the oil after you change the valve cover gasket, and check again in a few thousand miles for more whitish stuff. If more appears, you should be very concerned.
Also, check for signs of trouble in the coolant. Unexplained continual loss of coolant, engine oil in the coolant, ...
oc330cic is offline   Reply With Quote
Old 01-02-2013, 02:03 AM   #178
Zardoz33
My Ride: 2001 325xi
What's everyone's recommendations for the brand of valve cover gasket? Genuine BMW, Elring, Goetz, Victor Reinz?
Zardoz33 is offline   Reply With Quote
Old 01-04-2013, 09:15 PM   #179
dasblack
My Ride: M2
For the RTV and the half moon placement, do you apply RTV to the sides of the U as shown in the previous pages or the sides + and U as shown on page 1?
dasblack is offline   Reply With Quote
Old 01-08-2013, 01:45 PM   #180
projectmayhem713
My Ride: '04 325i - '90 535i
I did my VCG and spark plugs about 10 months ago following this DIY. Used RTV in the mentioned places, however I have been smelling that burning smell again and when stopped on a hill smoke enters the cabin through the vents, just like before. This problem was solved. Should I just pop the cover and torque it down a little more?
projectmayhem713 is offline   Reply With Quote
