I'm pretty sure this isn't normal, camshaft bearing destroyed. - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-15-2012, 09:19 PM   #21
Stinger9
My Ride: '04 330Ci
Originally Posted by stevodotorg View Post
I did change the valve cover gasket 3 months ago, but shows no sign of leaks, is it possible something fell down in there during the process?
Unlikely a blocked return would cause this. You'd still get pressure to the bearing.
+1 on Zell's hypothesis of oil pump nut.
Gotta check all the others for pre-fail.
Old 11-15-2012, 09:23 PM   #22
stevodotorg
My Ride: 02 325i - Manual
But will the car run without an oil pump nut? And how would an oil pump nut cause all of this to happen?
Thanks to all e46fanatics and other BMW forum users, without the community, our wallets would be more empty than they already are.
I do ECU Coding, contact me.
stevodotorg is offline   Reply With Quote
Old 11-15-2012, 09:44 PM   #23
stevenluczynski
My Ride: Is Steel Blue
I thought the oil nut issue only effected 330I engines....
stevenluczynski is offline   Reply With Quote
Old 11-15-2012, 10:07 PM   #24
Stinger9
My Ride: '04 330Ci
Not the expert on this, but heard others say there is an oil pump nut that loosens rarely and causes low oil pressure. If you have low pressure, should not drive your car at all. Could cause way more damage than you have now.
Then need whole new engine.
Old 11-15-2012, 10:22 PM   #25
lcoleman
My Ride: '79 Massey Ferguson
I'm pretty sure the oil pump nut backing off results in 0 oil pressure, ie an all-or-nothing failure.
I also think that if an engine was ran with no pressure, you'd have similar wear on all parts, not just the one cylinder. There's no telling what the bottom end looks like if the cam bearing (and the lobes, by the look of it) looks like that. My gut feeling, however, is that there is more here than meets the eye. If you're unable to dismantle things any further, you should probably take it to a shop. I would say that the oil pan needs to come off to have a look at the bare minimum, and a used head is probably cheaper than repairing that one.
Old 11-15-2012, 10:24 PM   #26
stevodotorg
I don't know about only 330I's but they are more prone from what I have read.
Old 11-16-2012, 01:58 AM   #27
stevodotorg
Only things I could find in relation to this..
http://forums.bimmerforums.com/forum....php?t=1305170
http://forums.bimmerforums.com/forum....php?t=1615386
http://forums.bimmerforums.com/forum....php?t=1879013
http://www.7machine.com/bmw/40361.html
No causes other than what the DIS says on various posts..
CAUSE
The VANOS faults can be caused by an insufficient oil pressure supply to the inlet VANOS adjustment unit. To effectively move the camshafts to the target positions in the specified time and under all engine conditions, sufficient oil pressure supply to the VANOS control pistons must always be available. When the engine operation requires that the VANOS quickly advance or retard the intake or exhaust camshaft, fault 2A82 or 2A87 may be set if the camshaft is “late”, or does not reach the target position. In this situation, engine power may be reduced and a check control message is displayed. The consequential fault 3100 can also be set in the DME fault memory as well.
PROCEDURE
Perform all applicable test plans for the faults stored. A mechanical restriction or electrical failure of the VANOS solenoid and/or the electrical circuit can cause insufficient oil supply to the VANOS assemblies as well. If the results of the test plans are inconclusive then proceed to step 2.
The oil filter cap insert may have been inadvertently removed during the vehicle’s last oil service. If this insert is not installed, it will result in non-filtered engine oil being supplied to the engine, thus possibly clogging or damaging the VANOS solenoids.
Replace both VANOS solenoids and change the engine oil and filter. Drive the vehicle to verify effectiveness. If this repair is inconclusive and the fault returns, continue to step 4.
If the oil filter cap is found intact, it is possible that the camshaft hook ring seals (3) have worn a groove into the camshaft bearing ledge (1), causing a drop in oil supply to the VANOS unit.
Camshaft bearing ledge
Intake camshaft
Hook ring seals
Note the deep grooves worn into the intake camshaft bearing ledge by the camshaft hook ring seals.
Acceptable camshaft bearing ledge – minor wear marks from the rotation of the camshaft are normal.
If the oil filter cap insert is found to be missing, then the entire oil filter housing cap must be replaced (refer to the EPC). If excessive wear to the camshaft bearing ledge is found, it is only necessary to replace the camshaft hook ring seals and the affected camshaft bearing ledge.
I figure, perhaps if I did replace the camshaft and the camshaft bearing ledge, everything might end up okay. I still think I should take it in though, does anyone know of anyone reasonable in the LA / Orange County area to take it in to?
Old 11-16-2012, 02:01 AM   #28
stevodotorg
You are probably right about the head, it surely would probably be cheaper.. Not sure about the oil pan though, why would it need to be dropped?
Something interesting to add, when I removed the bolts to the camshaft bearing cap that was black, the bolts were already way loose.. which is very strange.. perhaps part of the problem?
Old 11-16-2012, 03:01 AM   #29
lcoleman
Were any of the bolts loose on the other caps?
You need to pull the oil pan because you don't know if you have issues on the bottom end as well. If the cam bearings look that bad, you may have issues with main and rod bearings too....assuming it's an oil-pressure-related problem. I would look, if only for peace of mind.
Old 11-16-2012, 08:22 AM   #30
GSherbs
My Ride: 2002 330 xi
I'm thinking the bearing failures were due to some foreign material getting into the head when the VCG job was done.
An brief intermittent oil pressure issue probably wouldn't result in the amount of damage that you have. More likely, the disintegration of the bearings lead to the intermittent oil pressure problem. Bearing #3may have lead to the failure of #4 or both may have been subject to some foreign material.
Whether the problems are independent or related, you still need to do your due diligence and investigate every bit of the engine that you can for additional damage. Drop the pan as others have said - you have to take a look. You may also want to do compression & leak down tests to determine the health of your cylinders & valves - those metal flakes seen in your pictures are very disturbing - who knows what bits have traveled where in the engine at this point.
Also check the entire oiling system. Look for debris in the pan, the oil filter, everywhere!
You have a lot of investigation to do before you even consider what direction to go in.
GSherbs is offline   Reply With Quote
Old 11-16-2012, 09:56 AM   #31
RayPooley
My Ride: 320i SE Coupe
Especially with the swarf from those knackered bearings floating around in the oil. That metal had to go somewhere and it has to go via the sump before it gets to the oil filter.
Old 11-16-2012, 10:05 AM   #32
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
That was pretty isolated to only effect that one bearing the way it did. It looks like something got clogged in the oil feed to that bearing, not the return. With that bearing spun and getting as hot as it did probably accounts for the loose nuts. The metal looks like it got so hot it's tempered.
+1 on dropping the pan. Something blocked that oil supply, more of it may be in the bottom of the pan. As said there may be more damage on the bottom end too.
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | BMW Performance LCA | Mishimoto Intake Boots | GruppeM rep CAI | Shark Injector | 5000k Xenarc CBI 66240 HID | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 11-16-2012, 12:35 PM   #33
stevodotorg
Thanks much for your input, I really appreciate it, now I just have to decide if I should go to a shop or just drop the oil pan myself and further inspect it. I mean, would an indy shop look further into it than I can do myself?
So far on the inspection list:
-Check intake cams
-Compression test
-Check oilpan for foreign objects
I agree on that accounting for the loose nuts, simply makes sense, and it's definitely tempered, not to mention, charred.
Again, thanks for reading this whole mess, I really do appreciate your input.
Old 11-16-2012, 12:42 PM   #34
stevodotorg
Also, should the vanos look dark like it does? It looks as perhaps the vanos got hot too..
https://www.dropbox.com/s/x9006wwrn5...2010.43.30.jpg
https://www.dropbox.com/s/plkytxs1q3...2010.43.45.jpg
Could the vanos have been going through oil starvation as well? or is it normal to be a little dark over there..?
Old 11-16-2012, 01:08 PM   #35
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
If you have an engine brace to hold the motor up and dont mind being aggravated for a few hours then you can save a ton of money if you drop the oil pan yourself. If you would like to just do it yourself and need the brace then you should be able to get one for about 70 - 80 bucks.
Wrestling with the sub-frame is probably the worse part of it.
Good luck.
Encryption76 is offline   Reply With Quote
Old 11-16-2012, 01:21 PM   #36
trizzuth
My Ride: 234k, 16yr old B3AST
perhaps that little bit of metal got in there during the VCG change and got stuck under that particular cam bearing holder. and if it got stuck in there maybe it would grind the grooves into the came like in your pic and cause it to heat up a lot due to the friction that is not normally there.
The darkened vanos units looks normal to me, check other valve cover gasket replacement threads to see some pics of other people's cars to compare, but from what I recall, both my and my wife's vanos units looked dark like that.
2001 BMW 330i - Current at 235K
1996 Mitsubishi Galant S - gone at 121K
1993 Volvo 850 GLT - gone at 89K
1987 BMW 325 - gone at 238K
trizzuth is offline   Reply With Quote
Old 11-16-2012, 01:28 PM   #37
stevodotorg
Good luck.
Couldn't be any worse than manhandling the transmission.. my friend and I replaced my clutch, flywheel, rear main seal, pilot bearing, throwout bearing etc.. putting the parts in was chump change compared to taking the transmission off and putting it back on.. but it worked out great once we finished (I still need to make a thread on the process with some tips).
Dropping the oil pan seems like it wouldn't be terrible, but installing the new camshaft is a completely new animal him and I have never messed with yet.
Any DIY links would be greatly appreciated
Old 11-16-2012, 02:25 PM   #38
Encryption76
My Ride: 2000 328i
http://forum.e46fanatics.com/showthr...oving+camshaft
Old 11-16-2012, 03:08 PM   #39
GSherbs
add compression leak down to your list also...
compression test is good, but you'll want a compression leak down test also - can help you diagnose bad cylinder/piston/rings vs just bad valves...
Old 11-16-2012, 03:34 PM   #40
Stinger9
My Ride: '04 330Ci
Harbor Freight is the place to look for this tool.
