#1 |
E46 is strong with this one
Help Me Diagnose Driveline Noise
Hey Fanatics,
I have been trying to diagnose a oscillating noise from my driveline. I have a 2001 325i Auto and the sound increases proportionally with increasing RPM's. (More RPM's, the faster the repetition of the noise) It happens in P,R,N,D so I doubt it has to do with the wheels or suspension components. For example, when I start the car up, in P, I can hear a ticking noise coming from under the passenger seat side of the car. It is not coming from the front of the engine for certain. In my opinion it could be anything from the rear of the engine all the way to the rear of the car. Transmission is fine. No slips, no gear failures that I know of, and I just got my transmission fluid changed the correct way, with the correct fluids from ZF and etc etc back in July. What could this be? Hopefully the guibo.
#2 |
My Ride: M3 & 323Ci (sold)
well if its in park and the driveshaft isn't moving I don't see how it could be the guibo??
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF |
#3 |
I guess it wouldn't be then. What could it be then?
#4 |
Stay stock my friends!
Alex is right...driveshaft isn't moving in park.
...and not to argue with you, but it's very hard to figure out where a sound is coming from. If it's definitely not under the hood (you should listen with a stethoscope or hose), then the only other things I can think of is fuel pump. There's nothing else moving when you're in park. Try filling up the car above 1/2 full and see if that quiets the noise down (if you happen to be low on fuel)...
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#5 | |
Replaced Fuel Pump in August with Siemens VDO Could be my exhaust leak that I have probably?
#6 |
It could be an exhaust leak too. Why do you think you 'probably' have one though?
#7 |
Heat shield possibly. Also check the exhaust bracket that mounts to the trans, sometimes it breaks and rattles against the exhaust
#8 |
Thanks for all the thoughts guys. I'll check the heat shield. But yes, I have a visible crack on the resonator, causes the exhaust to be hoarse between 1-3 RPMs...saving up for a catback system
#9 |
If the sound is RMP dependent, meaning if the sound increases in repetition as the RPMs increase then it has to do with engine and engine driven parts. You have to start diagnosing by the process of elimination. Take the bets off and start the car and listen to that same sound that you heard with the belts on. Obviously start the car when its cold so you have a good 10min of safe engine running time before it'll start overheating.
It could also be as simple as an exhaust leak or a loose heat shield.
#10 | |
But back to the topic, I have diagnosed it as a exhaust leak. I covered the crack up with some rags and the noise became muffled.
#11 | |
someday this could be me
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF Last edited by Alex323Ci; 11-16-2012 at 03:40 AM. |
#12 |
My Ride: gobbles oil like a B
might be the exhaust heat shield that goes over the exhaust manifold. Mine is a bit loose and it starts to "tick" every once inawhile. All you need to do to confirm it is or is not that is to touch it with something to hold it steady.. if noise goes away, that's it. it is on the passenger side of the car too.
Or maybe a leaky exhaust/bolt/exhaust rubbing against one of the heat shields down there? or could be valve lifter tick
#13 | |
#14 |
#15 |
#16 |
Platinum Plus Quality
Alex is definitely on my list. (And not my block list--I took him off)
One day I'll place my hands underneath Alex's intake manifold and feel around to make sure everythings OK. I'll also touch other parts of the engine bay. If I see any dirt on my hands after an engine rub down, his name gets erased off the list. Same goes for any of the other few on my list. Anyone else down for an engine rub down? beagle killer?? hip hop boy?
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#17 | |
"Beware of any man who keeps a Love Kit in his trunk."
