E46 Xi Forum
Old 11-16-2012, 08:02 AM   #1
akilism
My Ride: 325xit
2003 325xi leaking coolant
my 325xi just started leaking coolant massively the other night. I'm pretty sure its the expansion tank. I was under the car this morning and couldn't tell for sure though. I pour coolant in and it just pours back out of the bottom of the tank and not in a trickle its just flowing out.
video 1:
video 2:
I'd like to overhaul the cooling system but right now I can't even drive it anywhere so I was hoping to just replace the expansion tank asap if that looks like the culprit.
its all coming from here
akilism is offline   Reply With Quote
Old 11-16-2012, 08:11 AM   #2
Rickna
My Ride: '01 330xi - '09 IS-F
Might be time for a cooling system overhaul depending on the mileage.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 11-16-2012, 11:17 AM   #3
SamDoe1
My Ride: 4cyl of fury
It's either the expansion tank or the radiator. Once you pull the tank out, you should be able to figure out where the leak is.
Probably stating the obvious but do NOT turn the car on in this condition.
Old 11-16-2012, 12:32 PM   #4
akilism
My Ride: 325xit
it seems like its coming right out of the tank. like its not even flowing into the radiator at all.
Old 11-19-2012, 10:16 AM   #5
STiGLiTZ
My Ride: 325i
Possibly a bad thermostat causing the pressure back up, if its not able to close the loop and get back into the radiator.
STiGLiTZ is offline   Reply With Quote
Old 11-19-2012, 10:43 AM   #6
SamDoe1
The tstat won't block the flow of fluid if it fails.
Old 11-19-2012, 10:45 AM   #7
Rickna
+1 Every bad tstat I've seen was locked in the full open position.
2001 BMW 330xi
2009 Lexus IS-F
Old 11-19-2012, 11:08 AM   #8
STiGLiTZ
My Ride: 325i
good to know, learned something new today
Old 11-19-2012, 01:22 PM   #9
akilism
My Ride: 325xit
got the expansion tank out on saturday. pretty good crack running down it. automatic transmission thermostat broke taking the tank out. so im just going to overhaul the cooling system this week.
Old 11-19-2012, 01:34 PM   #10
Rickna
Good plan.
2001 BMW 330xi
2009 Lexus IS-F
Old 11-24-2012, 10:00 PM   #11
717bimmerboym3
My Ride: 02 330xi, 98 m3 coup
fcpeuro.com has really good prices. Just ordered a overhaul kit from them.
717bimmerboym3 is offline   Reply With Quote
Old 11-25-2012, 08:16 AM   #12
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Do yourself a favor and order the tank mount as well as the tank. And +1 on the TSTAT, they most often fail in the open position, thus not letting the coolant and engine get to full operating temperature.
tomoyer is offline   Reply With Quote
Old 11-25-2012, 09:56 PM   #13
io14
My Ride: 05 325XI
bimmerzone has very good prices as well for the E46 cooling system overhaul.
io14 is offline   Reply With Quote
Old 11-26-2012, 08:52 PM   #14
Thotfulspot
My Ride: 2003 330Xi
I just had a thermostat fail in the closed position.
Thotfulspot is offline   Reply With Quote
Old 11-28-2012, 09:16 PM   #15
tomoyer
No one stated that the Tstat CAN NOT or DOESN'T fail in the closed position, just not common with BMWs, BUT it does happen.
Old 11-28-2012, 09:51 PM   #16
Thotfulspot
My Ride: 2003 330Xi
Sorry, I didn't mean it that way. I was just saying they can get stuck in either position. When it gets stuck closed, it heats up really fast.
Old 11-29-2012, 10:21 AM   #17
SamDoe1
Even if the tstat fails in the closed position it still won't totally block the flow of coolant, it only will block the flow into the engine block. The rest of the system will still receive coolant flow.
Old 11-29-2012, 11:33 AM   #18
Thotfulspot
My Ride: 2003 330Xi
The temp gauge goes from normal to overheated in a matter of minutes. We just dealt with one on a trip from Chicago. It would stick closed intermently. All of a sudden the temp light would go on and the needle would be pegged. Let it cool down and it would work fine for hours. As time went on it would happen more and more often. When I found an independent he changed it and you could see marks on the thermostat where it had been sticking. It rarely got hot when driving because of the air flow at higher speeds. Sitting at idle it would happen almost every time.
Old 11-29-2012, 11:42 AM   #19
e46alfonso
My Ride: 330xi MT, mustang gt
Replace everything and never worry again. I'ts an easy diy.
Old 11-29-2012, 12:01 PM   #20
Thotfulspot
My Ride: 2003 330Xi
It's been replaced. Tank and hoses were replaced before the trip. Just need to replace the water pump.
