California
Have you seen another BMW while driving around in your area? Maybe you can find their car in the E46Fanatics Garage! Northern California Southern California If you don't have your garage setup, sign up today HERE |
Rating:
#280721 |
My Ride: E46 332i,M3;E30 325i
-Kalim
(klx photo studio) ![]() M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings |
#280722 |
![]() Just got home from Drewski's. new tstat replaced under BavAuto warranty, new fan clutch, old one looked like poo, and a new upper intake boot because my old one was cracked |
#280723 |
Could you tell where the t-stat was leaking?
-Kalim
#280724 |
Town Clown
Knowing Briangle, probably eeerrrrywhere.
Sent from my HTC Flyer P512 using Bimmer App
Bay Area Top Dropper Orient Blue 330 Ci Vert ********************** ![]() |
#280725 |
From the electrical connector. It was actually diagnosed by BMW the 1st time it was in. It was a Whaler although I had ordered a Behr. Bav sent me a Behr replacement though. I've heard that spot is a weak point for both brands with the Whalers more commonly leaking there.
#280726 | |
-Kalim
(klx photo studio) ![]() M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings Last edited by cyberkaa; 11-16-2012 at 10:22 PM. |
#280727 |
#280728 |
I know right? My typical flailing...i forgot my water and coolant at home
Had to borrow some from Drew and pick up some water. Aside from that everything went smoothly. My fan clutch is hooking up a lot better. That's the second part that's gone bad from Bav btw. My ET cap was bad too. It didn't seal right. They refunded my money for that after I found it leaking. |
#280729 |
![]() BCRacing - CCW Classics - Muteki - 6 sp M/T EDM to JDM dailydriven S T E V E N |
#280730 |
#280731 |
My Ride: my favorite two feet
#280732 |
-Kalim
#280733 | |
-Kalim
#280734 |
#280735 |
My Ride: 330cic & R6
Is this fifi posting or mini fifi
EUROPROJEKTZ - Director, NorCal Chapter ![]() |
#280736 |
Wat
-Kalim
#280737 |
I met the minififi while u were out of the country.
I was dissapoint minififi's stroller needed clears & a drop.
#280738 |
Town Clown
Tobeh! When do you move?
#280739 | |
gooo ga boo ba drool poop nom nom
![]() Quote:
i sold that stroller! and got a doper one. its red
#280740 |
| Tags |
| >implying the e9x is good, '07 og's, '08 n00bs, 01, 02, 03, 04, 05, lgtss >kyle, mkodama was not here, norcal, norcal general chat, pshaw pshawn, timesharing drew |
| Rate This Thread | |
