Tips for top CCV hose connection? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-22-2011, 07:07 PM   #1
welcher330xi
My Ride: 2001 330xi
I finally got my new CCV loosely mounted (in hopes of making the hose connections easier) and the top hose (the one that comes up through a gap in the intake manifold and requires spinning) seems nearly impossible to connect with the manifold in the way. Is there a special way to do this? Or is it just go until you get lucky? In hindsight I would have probably saved time in the long run just taking the intake manifold off for this install.
I have way too many hours in this project
Originally Posted by ODEHBOY View Post
why are u holding ur camera like a douche?
Originally Posted by Attaus View Post
Twice as much profit? Yeah, maybe in Canadian dollars.
welcher330xi is offline   Reply With Quote
Old 02-22-2011, 07:10 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Lube the ends off the separator and inside of the hose with fresh oil and have fun. That is the part where you WILL cut yourself up lovely
Old 02-22-2011, 07:17 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You have the cold weather package, no doubt.
I gave up with the foam, but what worked for me was a loose ccv and twisting the hose enough to getting it to click on...you 'pre-load' it with twist and that seemed to do the trick...but with foam, not as simple.
Some have tried with the top hose connected already...but I think I gave up on that idea too.
Maybe a lubricant...even water...to help it spin better. I didn't try that, but that might help.
Also, now that I'm thinking about it, I think maybe I didn't have valve connected when I did that connection...and slightly turned ccv one way and the hose the other.
I know I did pull it out to practice the connection a few times. I don't think you can just muscle it on straight.
Have fun...hth!
Doug
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 02-22-2011, 07:25 PM   #4
N95
My Ride: 330i
That return hose twists onto the separator. Position the hose, under the manifold, at about 90-degrees counter-clockwise to the installed position. push the hose-end over the separator and then rotate the hose clockwise to lock it in place, and bring it up the the manifold connection. I test connected it first b4 intallation to see how it will fit..hope this helps
N95 is offline   Reply With Quote
Old 02-22-2011, 08:07 PM   #5
Hector45
My Ride: 2002 OB 330i
+1 My hands were nice and chewed up after this part
Good Luck OP keep at it, you will get it on eventually, took me a good hour and a half of cursing, drinking, cursing, and more drinking
Hector45 is offline   Reply With Quote
Old 10-25-2012, 08:10 AM   #6
onebad328i
My Ride: BMW 328i
im on to do this, its my turn now, will see how it gos, i already started drinking, so im way ahead of the game.... hickup....
onebad328i is offline   Reply With Quote
Old 10-25-2012, 08:55 AM   #7
trizzuth
My Ride: 234k, 16yr old B3AST
Yeah, make sure the valve is either not bolted in, or loosely bolted before you try to connect that hose. I did it with the cold weather shield and it can be done, just take your time, and if after awhile it won't go on, step away from the car, catch your breath, punch something other than your car, calm down and go back at it. You'll get it. Watching the bav auto video on youtube will really help you out.
2001 BMW 330i - Current at 235K
1996 Mitsubishi Galant S - gone at 121K
1993 Volvo 850 GLT - gone at 89K
1987 BMW 325 - gone at 238K
trizzuth is offline   Reply With Quote
Old 10-25-2012, 12:16 PM   #8
rbalazsi
My Ride: 323iT, 330Cic
We're talking about part labeled 3 in the attached picture, right?
If so, I mounted the CCV itself so it was stable and proceeded to simply push the hose on until it clicked.
I had tried the whole spinning it around bit and didn't really get anywhere with it.
It's been about a year and a half since and it's been perfectly fine.
rbalazsi is offline   Reply With Quote
Old 10-25-2012, 12:53 PM   #9
Minnetonka
My Ride: 03 330CI
I just remember it was a major PIA. Just keep trying..
Minnetonka is offline   Reply With Quote
Old 10-25-2012, 02:32 PM   #10
trizzuth
I am not sure this will work, it's a push in and twist 90 degree type of connection, not a simple push and click connection. You should double check that.. ha.
Old 10-25-2012, 02:44 PM   #11
Wh33lhop
My Ride: douchemobile
After peering at it to make sure I had the orientation right and it slipped on, I used a small flathead to press down on the near side of the connector while I pulled up with my hand (snaked in behind the hose) on the far side to twist it. Was a bit of a bitch but it wasn't too bad. I think I only got it to 45 degrees or so but it was enough to lock it on:
Wh33lhop is offline   Reply With Quote
Old 10-25-2012, 03:47 PM   #12
rbalazsi
Yes, I know that; but I also looked at it outside of the car and confirmed that if you already had them oriented in the turned position and simply pushed them together with some force, it would click and they would be connected properly. As I stated though, it's been over 1 1/2 years and I've had no issues at all.
Old 10-27-2012, 06:16 PM   #13
onebad328i
My Ride: BMW 328i
yeah i started to have the common leak codes set off my CEL, the line from the secondary air pump to the back of the engine was in pieces, then i checked the vacumes behind the engine and they had holes everywhere, replace those too, then the most common ccv bottom hose to oil deepstick tube was completely in two pieces i replace that bottom hose by itself since i really couldnt see anything in their, and from the outside they looked ok, yeah right, thats the common problem they look ok, but if you take them apart you can see that they are cracked or have small holes in the bottom , of course i forgot to mention that i replace also both intake elbows, those had more holes and craks than the moon, lol , so im waiting for the new ccv and complete hose set, should be in by wednesday, than im gonna tackle this puppy, i can wait to drive th car because i know she will ride so smooth after finding out the ccv was so f@cked up and the connections, i got the BAV auto code reader so i will clear the CEL and pray to the VACUME GODS that this is the end of my vacume knightmare, plzzzzzzzzz let me b done with it, i just wanna drive without having to look at that damn CEL..... thanks for all the info guys i really appreciate it,
Old 11-17-2012, 04:35 PM   #14
onebad328i
My Ride: BMW 328i
CCVV cran case vent valve
Well the VACUME GODS did not answer my prayers, i replace the ccvv with all the hoses, and triple checked all connections, but im stil getting code 8d or obd2 1477, reed switch did not open, i did reset the light after swapping the ccvv, and all its hoses, but the light came back after 3 cycles, somebody told me to go ahead and change the fuel breather valve, i looked at it the lines looked good, but i dont know about the valve itself it will probably be my last swap part before i take it to a professional, unless you guys have any more clues, any info will be greatly appreciated.... onebad328i out.
