Rating:
#13841 |
New tstat - the Whaler (sp?) was leaking from the electrical connector. I was sent a Behr as a replacement although I ordered a Behr the first time around lol. Also a new upper intake hose and a new fan clutch. Tomorrow we'll start on a new OPG. Mine is weeping from the front right corner.
Still waiting on the front diff tool. Now back ordered until late December We have another one lined up though, which should hopefully be here in a week or so. |
#13842 |
Pics. nothing like a clean engine bay.
![]() Want a handmade shift knob or custom vinyl stickers? PM me I'm sixteen and like cars with three pedals. My ever small company... www.facebook.com/StgFabricationAndMolds |
#13843 |
ew no don't even say that around me hahaha
#13844 |
Drove it down to San Diego and met with some forum members. Ran good!
![]() -2003 M3 Vert -1967 Mini Cooper |
#13845 |
Mod
One of my led license plate bulbs went whacky. Thing is flickering like the strobes on a cop car lol.
Ordered Morimoto Mini projectors, a hid kit with 3000k bulbs and E46 shrouds. Going QUAD XENON
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 Pics from post 505 on! ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#13846 |
AA Stg2+ 325xiA? Are you stupid? Maybe a little. I can program cars fo' freeee near Salt Lake City. PM for details. |
#13847 |
100% star stuff
How does your car stack up against that thing?
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One Last edited by tock172; 11-17-2012 at 09:52 AM. |
#13848 |
The results are surprisingly positive. From 60 it has me because of gearing, but at any other time...
Though at 6900 I'm hitting 10.7psi with an altitude density of 7000ft. I think I'll need to detune it a bit if I go to sea level or else risk engine damage. Idle vac at my pressure is -16 which is -18/-19 at STP, so the engine is definitely healthy! The entire top end looks like this (90k miles): ![]() BTW, RE050A's in the snow? Puckered anus.
#13849 | |
100% star stuff
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#13850 |
Good luck. Should be awesome.
Sent from my A500 using Bimmer App
#13851 |
Result of adding piezo buzzer with a white fleece *edit* da wife will be upset...now just have to code her to actually have it work
#13852 | |
But there's also a broken window regulator (driver's window), a squeaking pulley (A/C idler probably, hopefully not one of the AA idlers, though their support has been fantastic so far), and I still don't have wheels of my own. I am using my friend's 193M summers because he loves seeing them on my car and I do too! But they're so insanely heavy. I think Sportlines are for me. Here's some AA exhaust goodness. Major props to Viral for putting up with my friend and making sure things arrived on time. If I had one suggestion for the system though, it would be regarding the clamps. The clamps that came on the mufflers are super weak and strip easily. IMO all four clamps should be the incredibly beefy midpipe clamps. We also encountered the section 1 or 2 being about .5" too short, resulting in the pipe not covering the slip fit cuts at the section one-two junction. Luckily some clever fiberglass taping and clamping over the tape over the gapped areas then heat treatment cured it and ensured it should last for at least a couple years. Not sure if there are any weld junkies here, but here are some shots of the system. I've been impressed with AA's stuff. ![]()
#13853 |
Keep or remove colors?
#13854 |
Remove.
#13855 |
My Ride: '03 325i --> '13 GTI
Traded lm reps for stockers, time to make a for sale ad
#13856 |
Replaced the coolant, its getting colder out!
lol. |
#13857 |
Found a coolant leak, still trying to fix it
#13858 |
Waka Waka Waka
:'( I really wish I could've traded my 119s...
Sent from my SGH-I777 using Bimmer App
-Spencer
#13859 |
100% star stuff
Installed an M3 steering wheel and replaced my C pillar cover.
#13860 |
| Rate This Thread | |
